SLK 230 Key Issue - Mercedes Benz SLK Forum
  • 1 Post By jbanks15
#1 Old 11-18-2013
Vehicle: 2001 SLK230
SLK 230 Key Issue
I'm sticking my key in the ignition but it won't turn. It seems as if the wheel is locked it won't move to the left but will move slightly to the right. I don't know what to do. It was working fine last night.
sacred is offline
#2 Old 11-18-2013
Any help is greatly appreciated.
sacred is offline
#3 Old 11-18-2013
I can unlock and lock the doors with no problem. I don't think it's the batteries?
sacred is offline
#4 Old 11-18-2013
The battery is fine. The ignition will not physically turn.
sacred is offline
#5 Old 11-18-2013
Did you try and turn the wheel slightly to remove the preasure off the pin while turning the key?
#6 Old 11-18-2013
Quoted: 6492 Post(s)
some r170 steering lock hits:
https://www.slkworld.com/slk-r170-gen...on-switch.html
https://www.slkworld.com/slk-r170-gen...ition-key.html
https://www.slkworld.com/slk-r170-gen...dont-work.html
https://www.slkworld.com/slk-r170-gen...99-slk230.html
https://www.slkworld.com/slk-r170-gen...wont-turn.html
slk320chick likes this.
#7 Old 11-18-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Unfortunately there are many threads here that start with the same issue in the R170 but none of them that I can find have a resolution in them.
https://www.slkworld.com/slk-r170-gen...-key-prob.html
The more I read, the more problems I see with the ignition tumbler.
slk320chick is offline
#8 Old 11-18-2013
Ya iv'e tried all of that Livefreeordie. I really don't know what to do other then bring it to mercedes.
sacred is offline
#9 Old 11-18-2013
That's to bad, I only other thing to try is messing with the key in the lock, put it in all the way then slowly turn it as you slide it out little by little.if th3 key or lock are worn it may have enough play to do the job.
#10 Old 11-18-2013
Ya looks like i'm going to have to get it taken to the dealership.
sacred is offline
#11 Old 11-19-2013
PaulXLE's Avatar
Vehicle: SLK 230 Kompressor R170 auto 1997 in Imperial Red
Other Toys: Mostly computers, lots of them, opening a museum one day, maybe.
Quoted: 8 Post(s)
this happened to me the other day, when I had accidentally engaged the steering lock by turning the wheel as I got in the car
the key would not turn... I went into a bit of a panic, and eventually I gave the key fob a BIG twist, and it did the trick, key turned
I hesitate to recommend this, as I guess it could end in disaster!
I am now very careful not to engage the steering lock... I might not be so lucky twice!
PaulXLE is offline
#12 Old 11-19-2013
Vehicle: 2003 SLK320 Magma Red
Other Toys: 2001 Vulcan 1500
Not having looked at the pointers to other posts, did you turn the wheel to the right and, while holding it there, try to turn the key?
My car seems to be far more prone to this malady than any other car I've ever owned. Panic moments are more common than usual
spclk is offline
The Following User Says Thank You to spclk For This Useful Post:
#13 Old 11-20-2013
Yes I have tried all of that. It seems as if the steering wheel lock is on though because it won't turn to the left and only slightly to the right. I really don't know what to do.
sacred is offline
#14 Old 11-20-2013
JiminFL's Avatar
Try to center the wheel in the lock mechanism so it is touching neither the left nor the right. Just move it a little bit so it is centered in the free-play area. Then give the key a good turn. It should work.
JiminFL is offline
Manually Lowering Top on SLK 230 Ah Ping"s Toy New Members Introduce Yourself Here 12 06-25-2018 05:00 AM
Programming used FOB 1998 SLK 230 pghazi New Members Introduce Yourself Here 13 07-17-2013 10:40 AM
My slk stop recognizing the key fob hoangcao243 SLK R171 General Discussion 27 07-01-2013 08:32 AM
Key Unblocking An SLK R171 Mike Maddox General Discussion 3 06-04-2009 04:39 PM
