2002 320 engine dies - Mercedes Benz SLK Forum
#1 Old 11-18-2013
Vehicle: 2002 320 sport automatic
Other Toys: 54 speedeter,66 mustang conv
Three weeks ago I went to start my 2002 320. When I turned the key to start it was dead. There was no fuel pump sound and no starter. It was as if the battery was disconnected. All the electrical worked and the battery was fine. An hour later when I went back all was fine. Today while driving the car the engine stopped. I coasted to a stop and had the same indications as before. Turning the key to start had no effect. All electrical was working(dash and headlights, radio, door locks) After about 3 minutes I tried the key and then the car started as normal. Any suggestions would be welcome. Will this intermittent problem show up as an error code?
Robert320 is offline
#2 Old 11-18-2013
Quoted: 6496 Post(s)
How old is the battery?
Did you have the battery tested?
#3 Old 11-18-2013
Vehicle: 2001 SLK 320
Had the very same issue with mine for over a month now. When I first had the battery tested, it came back good but no charge. Charged it, worked fine for about a week. Then intermittently, it would not crank. Sometimes no sound at all, sometimes the click, click, click. Jump start it and when I would get to the end of the street, it would die. Sometimes it would recrank, but most times, I would have to jump it again. Had battery tested again. Battery=good. Charging systems all working properly. Finally this morning, I just decided to replace the 6 year old battery and see if that corrected the problem since nothing else has presented itself as the issue. Too soon to tell if this has solved my issues or not, but I was unable to find any other sources of the problem.
DIYGirl is offline
#4 Old 11-18-2013
I will check the battery again but what does not seem right is I was going about 45 mph when the engine shut down. So the engine was running fine then it was like I turn the key off except I did not lose the radio or any lights. After stopping is when I had the no joy trying to start. Also when I tried to restart the car the headlights did not dim. I would think with a weak battery the lights would go dim when trying to start the engine. After 3 minutes it cranked fast and started and ran as if nothing had happen.
#5 Old 11-18-2013
I agree. I misunderstood when your car was cutting off. Sorry
DIYGirl is offline
#6 Old 11-18-2013
EPerk's Avatar
Vehicle: 1999 SLK 230 Kompresser
Other Toys: 2000 Nissan Altima GLE
What do the gauges do? Drop to zero, stay where they are? If they do drop to zero check the ignition switch, maybe the crankshaft position sensor. If they don't die might want to look into a fuel pressure issue (pump, filter, ect).
I'm no expert, its just what I found when I looked up this problem on Google.
EPerk is offline
#7 Old 11-19-2013
Thanks for the inputs. For now I need to wait until the next time it happens to see what happens. Its good to have a list of thing to check when it happens.
#8 Old 11-20-2013
tricolour's Avatar
Vehicle: 2006 SLK 55 Designo Graphite, 2005 SLK 350 Black, 2001 SLK 320 Black.
Other Toys: 3.2 Boxster S, XJ 40 Jaguar, Bimota DB9C, Triumph Bonneville SE & Thruxton R.
Quoted: 34 Post(s)
I would check the K40 module first off.
No fuel pump or starter motor are prime symptoms IMO.
If you were in Oz I'd send you my repaired unit.
tricolour is offline
#9 Old 11-20-2013
Thanks. Were is the k40 module located and do you have a picture of it? thanks again.
#10 Old 11-20-2013
Thanks Again I found its location.
#11 Old 11-20-2013
Quoted: 1136 Post(s)
If not k40
Poss look at CPS. !
Delucas is online now
#12 Old 11-20-2013
RoboRob's Avatar
Vehicle: 2002 SLK320 6 speed
Quoted: 17 Post(s)
Most likely the crankshaft position sensor. I had the EXACT same problem/symptoms. Replaced it, no problems.
RoboRob is offline
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 56 3 Weeks Ago 05:35 AM
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 10 11-23-2014 11:14 AM
