winter is coming , - Mercedes Benz SLK Forum
  • 1 Post By thecreator88
#1 Old 11-10-2013
Vehicle: 1999 SLK 200 Kompressor
winter is coming ,
hello
i have a 99 slk 200k , i have a yard where i keep the car but no garage , the slk i have i dont drive in the winter , so could you tell me your tips & tricks for winter , basicaly the car will stay unmoved & upstarted for 5-6 months , i want in the spring to be no problems
thanks
thecreator88 is offline
#2 Old 11-11-2013
Vehicle: 2001 SLK 3.2 V-6
Other Toys: 2012 Infiniti EX35
Quoted: 11 Post(s)
Send a message via Skype™ to Simprof
Hi I live in Canada and like you it get vert cold so I will not drive my SLK 320 passed the middle of November.
Just make sure you use a fuel stablizer in the fuel tank.
Use a battery float charger (Trickle) in or out of the car.
Put a little more air in the tires I use about 34 psl
Make sure the antifreeze is adequate for your areas temps.
That's about all I will be doing on mine.
I'm sure others will have other ideas along with the above.
Simprof is offline
#3 Old 11-11-2013
JiminFL's Avatar
Protect it from mice. Dryer sheets, moth balls, physical barriers. Anything that works.
JiminFL is offline
The Following User Says Thank You to JiminFL For This Useful Post:
#4 Old 11-11-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Dryer sheets keep away the mice?!?
slk320chick is offline
#5 Old 11-11-2013
JiminFL's Avatar
Yup, spread them around in the engine compartment, trunk and on the carpets inside. Don't be shy with using them, more is generally better than 1 or 2. I prefer mothballs and physical barriers like good fitting garage doors, etc. Of course a hungry barn cat is ideal. But he is storing his car outdoors, probably the worst place for mice. And for cats
JiminFL is offline
#6 Old 11-12-2013
Vehicle: 2005 SLK350 MT
Quoted: 19 Post(s)
I would change the oil if its almost due.
Cover it with a breathable cover. You might want to arrange the cover so it does not touch paint.
gdb069 is offline
#7 Old 11-12-2013
i am going to change the oil , the bag thing is that in romania you cant find fuel stabilizer
#8 Old 11-12-2013
Minion
Quoted: 148 Post(s)
You don't need it local, just get it from amazon.
#9 Old 11-12-2013
Air Suspension Manager
OffLineR's Avatar
Vehicle: 2010 Grand Edition SLK200 Kompressor
Other Toys: AirMadZ - Air Suspension, Audi A4 Cabrio, GOLF IV Highline
Quoted: 62 Post(s)
It is usually quite difficult to import fluids in many countries.
Because in customs it is very difficult to prove what really is in these cans\packs.
OffLineR is offline
#10 Old 11-12-2013
Minion
Quoted: 148 Post(s)
hrm...I forgot about that.. is there anyone on ebay locally that could do it? Surely someone must be able to get it. Have you called the dealership and asked them? Have you contacted the local auto parts stores for stabilizing solutions? Someone has to be able to help you out there..
#11 Old 11-12-2013
Vehicle: R170 230
Hi, my recommendation is get some large Silica Gel packs to leave in the interior and the boot. You can buy huge ones in Camper Van Centres. They will help Lessen the anount of moisture from condensation. Just dry them out in the oven once a month and put them back in the car.
Also if even with a fuel stabiliser make sure the tank is full, less chance of condensation.
Gummi Pfledge or similar all your rubber seals.
JackD is offline
#12 Old 11-12-2013
Minion
Quoted: 148 Post(s)
I thought I had a line on secured garage parking, but it was not heated. That kind of defeats the purpose. I'll keep searching though.
#13 Old 11-12-2013
Quoted: 19 Post(s)
Although I recommend and use a fuel stabilizer, it is not critical as most gasolines are able to be stored for 6 months to a year. If you cannot get a stabilizer, you will want your pre-storage fill to be from a high volume gas staion so the gas is "fresher". I am not sure if any brands are considered better quality but better quality may help. Do the fuels contain ethanol?
Gordon
gdb069 is offline
#14 Old 11-12-2013
Dolau's Avatar
Vehicle: SLK 200 kompressor 2003
Other Toys: Yamaha FZ6S2
Have to run mine through the winter as it is my one car
Last night driving home late the glitters had been out and the temperature was 1.5 C in places.
Better start on the weekend hose under the car regime to keep the salt at bay
Dolau is offline
#15 Old 11-13-2013
good news , found some fuel stabilizer at a boat shop
next week i will start to prepare for the winter
OffLineR likes this.
#16 Old 11-13-2013
OffLineR's Avatar
Quoted: 62 Post(s)
Those boat shops are life saver for a cabriolet.
Especially for soft tops.
OffLineR is offline
#17 Old 11-13-2013
Vehicle: 1999 slk 230
Quoted: 519 Post(s)
Stoli always worked for them long Russian Winters in Germany.......It worked in the Gas Tank in the Radiator and as Washer Fluid as well for them cranky Bettys during the long German Winter Month. The down Side your Car might smell like an Alci in Spring.... Explain that to the s..... that it is the Car that smells like Vodka and you have not been drinking. I would stay away from the Stoli Fruit Flavors straight Stoli in the Tank is just fine........
Berliner Heckflosse is offline
#18 Old 11-13-2013
Quoted: 19 Post(s)
[QUOTE=Berliner Heckflosse;987617]Stoli always worked for them long Russian Winters in Germany..../QUOTE]
But don't waste it. You let it do its fine work on you and then recycle it into the car. Don't forget you can use the recycled Stoli to top up your battery acid level when low. And the Stoli "recycling" would contain both alcohol and ammonia so makes an excellent cleaner.
Gordon
gdb069 is offline
#19 Old 12-29-2013
Vehicle: 2003 slk 230
Other Toys: toyota tacoma
recycled?
Oh, ?Damn, piss on that!
widglid96 is offline
Winter options... Spudmuffin General Discussion 37 11-03-2013 05:05 PM
Winter Month are Tuff Berliner Heckflosse Off Topic 0 02-25-2012 06:16 AM
Put the SLK into Winter Mode (w/ pics) Firm SLK R170 General Discussion 26 01-01-2012 08:29 PM
Winter is coming - time for new wheels. Help? Jezper Tires, Wheels, Brakes & Suspension 11 10-02-2009 07:52 PM
Winter is Coming - 17 inch Winter Wheels with Blizzak LM22 Silver_Lana Where to get R171 SLK Items 3 09-12-2007 01:33 AM
