Engine stops on my 2003 SLK320 - Mercedes Benz SLK Forum
  • 1 Post By slk320chick
  • 1 Post By thunderstorm
#1 Old 11-08-2013
NEW issue.. HELP PLEASE !!!!!
Parked the car,, got out 2 minutes later car wouldnt turn over.. PLENTY of battery. After a few minutes it started.. 20 minutes later engine died while driving.. 5 minutes later it started... HELP PLEASE.. Thank you..
03SLK320 is offline
#2 Old 11-08-2013
Any codes?
#3 Old 11-09-2013
I dont know how to check for codes.
03SLK320 is offline
#4 Old 11-09-2013
cobra8272's Avatar
Vehicle: '05 SLK350
Other Toys: Fender Strat, Fender Tele
Take it to an Auto shop and get them to hook it up to an OBD2 reader and it will indicate the fault codes and show what is wrong.....
Smart Top
Daytime LEDs
LED Lighting pack
MB Door lights
cobra8272 is offline
#5 Old 11-09-2013
If the check engine light is on there are current fault codes. Any auto parts store (autozone) will read them for free.
#6 Old 11-10-2013
OK I took it to my mechanic and he put it on the computer.. It showed no codes.....And there are no engine warning lights on the dash lit up...
03SLK320 is offline
#7 Old 11-10-2013
That's odd. I would look into things like the plugs,fuel filter,K40 solder joints,Cable connections,and battery.
#8 Old 11-11-2013
Oct 15th it completed it's yearly major service at Tampa Mercedes.. :-) What on Earth would make the car dead one minute with full battery then 5 minutes later let it function as if nothing was wrong........
03SLK320 is offline
#9 Old 11-11-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Alternator dying?
Faulty battery?
OffLineR likes this.
slk320chick is offline
#10 Old 11-11-2013
OK folks I took it to Tampa Mercedes and it was the Crank Shaft Position Sensor.. Replaced it and all is well...
03SLK320 is offline
The Following 3 Users Say Thank You to 03SLK320 For This Useful Post:
#11 Old 11-11-2013
Minion
Quoted: 148 Post(s)
reaaaaaaaaaaaally.. thank you for the follow up. Now we'll have a reference solution for future members with similar issues.
#12 Old 11-12-2013
RoboRob's Avatar
Vehicle: 2002 SLK320 6 speed
Quoted: 17 Post(s)
same problem/symptoms here about 2 months ago. Turns out this crankshaft pos. sensor is a part that will need replacing after awhile, common maintenace thing or else you car may just die, then restart 20 plus minutes later never knowing when it will happen again. Part can be had on-line for $60 but in a tight spot to get at. How much did it cost you to replace it? Parts? Labour?
RoboRob is offline
#13 Old 11-12-2013
Vehicle: 2000 SLK230
For this problem when you turn the key:
If the car turns over but doesn't start its the CPS,
If it doesn't even turn over its the K40.
Good to hear you got it fixed
RoboRob likes this.
thunderstorm is offline
#14 Old 11-12-2013
Vehicle: 2003 SLK320 Magma Red
Other Toys: 2001 Vulcan 1500
I replaced my CPS right after buying the car, it was a cheap 'fix' at the moment. It didn't solve the problem (I found out that I had a faulty alternator) but there are 3 advantages to having done this:
1) I have a spare in the car
2) I have the tools in the car to fix the issue
3) I have done the repair and so when it does fail, I'll be experienced
spclk is offline
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 56 3 Weeks Ago 05:35 AM
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 10 11-23-2014 11:14 AM
