Weird Sensor Coming Up On Console - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By sacred
  • 2 Post By alexgdelcg
#1 Old 11-05-2013
Vehicle: 2001 SLK230
So I was driving home tonight and this weird light came on. It's the light that normally comes when another sensor is active. Just this one light is showing. Anyone have any ideas? Just bought this car Saturday. It's a 2001 with 107k miles on it.
sacred is offline
#2 Old 11-05-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Picture? any codes? Have you had service at all lately? Have you changed out any parts lately?
slk320chick is offline
#3 Old 11-05-2013
I had the brakes done today but that light was not on after. It came on randomly like hours later. I just updated the post with a picture.
sacred is offline
#4 Old 11-05-2013
The dealership had it serviced before I bought it. I need to go get it checked out with a computer and maybe have some more service done to it.
sacred is offline
#5 Old 11-05-2013
Here are some pictures of the car.
Dolau and Bezgreshen like this.
sacred is offline
#6 Old 11-05-2013
Minion
Quoted: 148 Post(s)
This is what your owners manual says:
Exterior lamp failure indicator lamp
With the key in steering lock position 2, an
indicator lamp comes on. It should go out
when the engine is running.
If the warning lamp does not go out after starting the
engine, or if it comes on while driving, this lamp
indicates a failure in the parking lamp, taillamp, stop
lamp, or low beam headlamp.
If an exterior lamp fails, the indicator lamp will come on
only when that lamp is switched on.
If a brake lamp fails, the lamp failure indicator will
come on when applying the brake and stays on until the
engine is turned off.
Note:
If additional lighting equipment is installed (e.g.
auxiliary headlamps etc.) be certain to connect into the
fuse before the failure indicator monitoring unit in
order to avoid damaging the system
#7 Old 11-05-2013
Minion
Quoted: 148 Post(s)
Check the lighting connections, chances are there is something loose.
#8 Old 11-05-2013
Will do. I don't know much about cars to be honest. This is my first one.
sacred is offline
#9 Old 11-05-2013
Minion
Quoted: 148 Post(s)
170 owners-please chime in. It may be something as simple as a loose tail light connection? I'm not good with cars, I just google and read a lot LOL.
Boys, help the gent out please.
The Following User Says Thank You to slk320chick For This Useful Post:
#10 Old 11-05-2013
Mensra's Avatar
Quoted: 385 Post(s)
If you're really stuck, I told you there's my Indy in Hollywood!
Mensra is offline
#11 Old 11-05-2013
Ya I talked to Ross. I'm going to see him next week. Have to get the money together first.
sacred is offline
#12 Old 11-05-2013
Mensra's Avatar
Quoted: 385 Post(s)
Did you get the red carpet treatment?
Mensra is offline
#13 Old 11-05-2013
Minion
Quoted: 148 Post(s)
These cars cost a fortune.. in every sense of the word. Search for threads in regards to loose wiring in the tail lights. I can't imagine it being that hard to open the trunk and check some wires. Also, check the headlight connections. You have a facelift model. Everything should be pug and play.
#14 Old 11-05-2013
Ya he offered a lot of friendly advice. He said I made a wise decision on the model and year that I got, that they are very reliable. He also mentioned for a general tuneup and service would cost me about $500.
sacred is offline
#15 Old 11-05-2013
Vehicle: 2001 Mercedes-Benz SLK230
Other Toys: 1997 Ford Taurus GL
AAAAAAAHHHH!!! Your car is IDENTICAL to mine! I even get that weird light sometimes, too! (Rarely, but it happens and goes right off.)
LIComedyFan is offline
#16 Old 11-06-2013
Vehicle: SLK 200 Kompressor
Other Toys: Seat leon FR 170HP, Ford Mondeo MK2 136HP, Hyundai Getz XD
Send a message via Skype™ to alexgdelcg
I have the same car and that light means you have a blown bulb. In my case it was the number plate bulb.
It only turns on when you switch the lights on.
Check all the lights and you'll find the faulty one.
BCoolidge and slk320chick like this.
alexgdelcg is offline
The Following User Says Thank You to alexgdelcg For This Useful Post:
#17 Old 11-06-2013
Quoted: 11 Post(s)
woah $500 without even seeing the car !!!!!
beerbelly is offline
#18 Old 11-06-2013
He didn't say that it would cost me $500. He said the general range depending on what has to be done is around $500.
sacred is offline
#19 Old 11-06-2013
Mensra's Avatar
Quoted: 385 Post(s)
He has always gone above and beyond for me. All the "little" things that can nickel and dime the bill way up he has just done. Any Star Diag stuff, N/C. Setting the lights to HID for my self install, free. Bulbs that are simple, did along with other stuff. So I have and will not question either his findings or bill. He is more then fair, and is mod-friendly, likes to help and try new things.
Mensra is offline
Rear Center Console Removal lilred320SLK SLK R170 class DIY 29 08-02-2016 03:40 PM
Refurb console and a cheat wallew SLK R170 General Discussion 3 06-07-2013 04:36 PM
Squeaky Console BACnSLK SLK R172 General Discussion 10 07-27-2012 02:55 PM
Center console removal questions . . . lilred320SLK SLK R170 General Discussion 3 05-23-2012 06:42 PM
Center Console Light BrianS SLK R171 General Discussion 14 08-05-2009 12:08 AM
