Alarm keeps going off - Mercedes Benz SLK Forum
  • 1 Post By Pujol007
#1 Old 11-03-2013
Vehicle: Mercedes slk 230k 2001
Other Toys: Vw golf tdi super charged
Hi I have a 2001 slk facelift and since 31st of October my alarm keeps going off I have disconnected the car battery in between driving the car it's a pain is the a fuse I can take out to just stop alarm ? Also any ideas what could be causing the problem ? Thanks also when the alarm goes off the interior light comes on is this normal
Deane is offline
#2 Old 11-03-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Sounds like a problem with your PSE pump , getting damp/wet , do a search , there should be plenty of info !
I think you'll find if you pull the fuse you'll stop other stuff , try disconnecting just the siren until you get it sorted ?
I also remember some comments on the siren having a seperate battery , try s search on that just in case ??
curro101 is offline
#3 Old 11-03-2013
JiminFL's Avatar
With tongue firmly planted in cheek--"It sounds like you picked up some goblins on Halloween". Perhaps an exorcism is in order?
JiminFL is offline
#4 Old 11-03-2013
Vehicle: 2001 SLK230
I'm having the same issue too. But I don't think it's the PSE in mine. I've always had a problem with the alarm randomly going off. Sometimes it only happens once, sometimes it will happen every 10 minutes from 1am until 4am...
I'm pretty sure it's not the PSE in mine because I had to have that replaced after Sandy; water got all up into the rear bumper, exhaust, and trunk, but the slope of my driveway kept it JUST out of the engine bay and is the only thing that saved it from being totaled out. And when I brought it in for repairs after all the repainting that had to be done they said that was the only part that needed replacing.
I had the problem before that though, and honestly it's only happened once since the hurricane; yesterday in fact. But I think that's because I leave the car unlocked at all times when home. I did start locking it again recently to get me back in the habit because I'm going to put in a new headunit so I can get some bluetooth audio.
So if it's not PSE what else might it be? My mechanic said it's not worth having him tear through it unless I want to spend a couple grand on finding the problem on a car that's only worth a couple grand...
Seawolf is offline
#5 Old 02-10-2017
I have a 2001 SLK230. Thanks to this forum I was able to solve mystery malfunctions. Found the PSE, open and indeed had very light corrosion on both sides. With a toothbrush I gently brushed it away. Dust spray any reside. Used CRC contact cleaner to finish cleaning and then CRC Lubricant that I bought at Home Depot. Now all is working fine: Locks don't engage and disengage without reason, dome light is working now at it should when you open the door or when you turn the alarm off. Trunk light works now. Door lock control in center console works. Alarm does not go off for no reason anymore. THANKS SLK FORUM!!!! you have a lot of knowledge here!!!
Pujol007 is offline
#6 Old 02-10-2017
Quoted: 6495 Post(s)
First please update your location in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ . Info in your garage does not update your profile.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
SLK230 Alarm. Don't have instruction manual. cartoony SLK R170 General Discussion 4 07-20-2013 04:21 PM
R170 (SLK 230 2003) SmartTop alarm issues =( JaysonM General Modifications R170 9 03-10-2013 06:53 PM
Help! My alarm keeps going off randomly lombrozo SLK R170 General Discussion 6 05-09-2012 05:52 PM
230 slk Alarm went off now, it keeps going off. ryan2022 SLK R170 General Discussion 0 09-25-2011 02:16 PM
