Safe way to remove paint from plastic - Mercedes Benz SLK Forum
  • 1 Post By Carl Beck
  • 1 Post By Motodr
#1 Old 10-30-2013
I need a safe way to remove paint from plastic and vinyl. I'm redoing an interior on my SLK.
TIA,
Randy
randy993 is offline
#2 Old 10-31-2013
leapyfish's Avatar
I used Isopropyl alcohol.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#3 Old 10-31-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Yes, many people just use alcohol.
slk320chick is offline
#4 Old 10-31-2013
Vehicle: 1999 SLK 230 "Sport"
Quoted: 28 Post(s)
I've always wiped automotive plastic and vinyl down with lacquer thinner, on a soft cloth. Good and damp, but not dripping. It should remove old paint and grim - while at the same time preparing the surface of the plastic/vinyl to provide a good base for the new die or paint.
FWIW,
Carl B.
Carl Beck is offline
#5 Old 10-31-2013
Motodr's Avatar
Take care, thinner will melt plastic! Alcohol is safe and the paint will peel off like a baked chicken skin.
Motodr is offline
#6 Old 11-01-2013
Quoted: 28 Post(s)
I suppose that if you left a piece of plastic in a bucket of Lacquer thinner - it would dissolve it. Or if you left a dripping wet rag soaked in lacquer thinner on the plastic for a period of time it would soften it.
But wiping automotive plastics and vinyl down with a damp cloth to clean the surface and remove old paint with lacquer thinner - won't hurt a thing. At least is hasn't over the past 40 years I that use it, during the restoration of dozens of cars.
Using alcohol won't leave the plastic/vinyl with as good a base to apply dye or paint to. If your going to re-dye or paint the plastic/vinyl - use Paint Thinner to clean it {aka lacquer thinner}.
If you use Alcohol - be sure to clean the plastic/vinyl after with clean water, then dry completely.. any residue left will let your new paint peel off like a baked chicken skin.
Carl B.
ajberrow likes this.
#7 Old 11-05-2013
Isopropyl alcohol worked for me in about 90% of the areas I was working on. Brake fluid took care of the rest.
Remember ventilation, gloves and goggles whatever the chemical you decide to work with.
Raindog is offline
#8 Old 11-05-2013
Motodr's Avatar
Hi Friends, for who is introuble to take paint off, i used ordinary alcohol, the one we use at home cleaning, 96gl.
http://youtu.be/QymNl_URZ1c
slk320chick likes this.
Motodr is offline
#9 Old 11-05-2013
Quoted: 6496 Post(s)
Motodr,
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already.
Interior Freshening up! XOFMOT SLK R170 class DIY 38 05-22-2018 09:53 AM
Latex paint removal Raindog SLK R170 General Discussion 7 03-24-2015 04:53 PM
Towing sensor, how to wire? JudgeMing SLK R171 General Discussion 5 10-11-2013 11:10 AM
Product Review: Adam's Paint Correcting Polish DetailersDomain Caring for your SLK 1 08-22-2013 04:44 PM
Annoying Rock Chips AIR44 General Discussion 30 12-02-2010 12:09 PM
