Replaced PSE Pump, Horn Chrips when Ignition in Position 2 - Mercedes Benz SLK Forum
#1 Old 10-29-2013
Vehicle: 98' Mercedes SLK230, 95' Cadillac STS, 78' MGB
I just replaced my PSE pump (new OEM part from Germany) today in my 98' SLK230. My original PSE was not worth saving (broken resistors on circuit board, extensive corrosion etc..). Everything is now functioning correctly however, when I turn the ignition to position 2 the horn chirps! It seems like it is doing some sort of safety check.
I have read somewhere that the PSE pump may need to be 'coded'?
Anyone have any idea how to disable this horn chirp?
Any advice is appreciated.
MZeraldo is offline
#2 Old 10-30-2013
Vehicle: 2001 SLK320 Sport
I replaced the PSE on my 01 SLK320 last spring when it wouldn't work properly because of the extensive corrosion. I never had it "coded" and I have never had the chirping that you are describing.
Have you thought of disconnecting the battery for a while and see if it somehow resets things when you reconnect? Not sure if our MB electronics work that way or not.
BluBenz is offline
#3 Old 10-30-2013
Vehicle: 1999 SLK230
I know this has been discussed in several threads; and I'm trying to recall since it's been a while since I read about it - but, and please correct me if I'm wrong, I think this single horn in position 2 happens whenever one of the 2001 or newer PSE's are used in a 98, 99, etc. Everything will work fine, but it will give a single horn since it's not properly coded, or something to that effect. Supposedly, the dealership can 'code' them properly in about 30 minutes.
Here's one post that references it -
http://www.benzworld.org/forums/r170...eeps-once.html
LoveMeSomeSLK is offline
Will CLK430/320 pse vacuum pump work in SLk320? wasatchmountains SLK R170 General Discussion 26 12-01-2015 01:45 PM
Working R170 PSE door lock actuator pump BSK SLK Parts For Sale 6 02-03-2015 12:11 PM
Working R170 PSE Door Actuator Pump BSK SLK Parts For Sale 10 10-18-2011 10:18 PM
