turns over but won't start? - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By fastdawg1
  • 1 Post By jbanks15
#1 Old 10-27-2013
Vehicle: 1998 SLK 230
Other Toys: kayaks
Question turns over but won't start?
Hi. My 1998 slk230 won't start. Been running fine forever and this morning just turns over with no hint of firing!??! Checked for spark and it's good. Fuel pump is humming so it's OK??? Any thoughts?
Joel230 is offline
#2 Old 10-27-2013
Vehicle: 2003 SLK320 Magma Red
Other Toys: 2001 Vulcan 1500
CEL lit?
Codes?
Search returns many results (high on the list, CPS)
spclk is offline
#3 Old 10-28-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
How old is that battery?
slk320chick is offline
#4 Old 10-28-2013
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 94 Post(s)
Fuel filter?
fastdawg1 is offline
#5 Old 10-28-2013
Other Toys: kayaks
No codes prior to the car dieing. won't start so can't tell if light will stay on or not. I don't have a code reader just take it to Autozone for free.
As for the CPS (both crank and cam) I'll look into them, thanks!
Joel230 is offline
#6 Old 10-28-2013
Other Toys: kayaks
Battery is 3 years old and I tried jumping it thinking it might be weak but that didn't help either. Thanks.
Joel230 is offline
#7 Old 10-28-2013
Other Toys: kayaks
Might be, but no signs of hesitation or problems prior to yesterday morning?!!?
Joel230 is offline
#8 Old 10-28-2013
Other Toys: kayaks
Sorry, I meant to say that it might be the fuel filter but had no symptoms prior to yesterday morning. Thanks
Joel230 is offline
#9 Old 10-28-2013
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
In the old day of carburetors, you could just throw some starter fuel down it and if it fired up, even just temporarily you knew it was a fuel starvation issue. I don't wish to go backwards, but there was some advantage to that.
DAVIETHESCAFF and ajberrow like this.
#10 Old 10-28-2013
Other Toys: kayaks
How true Fastdawg!
Joel230 is offline
The Following User Says Thank You to Joel230 For This Useful Post:
#11 Old 10-28-2013
Quoted: 901 Post(s)
Nowadays you have to use an aerosol can of starter fluid into the air ducts -- but the idea's the same -- to answer the question "is it missing fuel or is it missing spark".
efair is offline
#12 Old 10-29-2013
Other Toys: kayaks
Just wanted to update the issue.... fortunately I didn't have to have it towed to the dealership for service!!! I kept cranking it over morning noon and night for a few minutes with no results but then this morning she kicked a bit so I kept cranking and it started! Not sure the cause but suspecting a fuel clog that blew through. I'll change the filter soon but in the mean time it's running like a clock again and no CEL lights or codes were ever thrown. Again, thanks to all that replied and may all our car problems be self healing!
Joel230 is offline
#13 Old 10-29-2013
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
If you're not using it, get some Techron concentrate plus and stick in with a full tank of gas. It may help. Don't use with every tank of gas, but maybe every two or three.
#14 Old 10-29-2013
Quoted: 6488 Post(s)
techron is every 3000 miles, but when used, if one bottle does not fix it, try another per the bottle instructions.
https://www.slkworld.com/general-disc...esitation.html
fastdawg1 likes this.
#15 Old 10-31-2013
Other Toys: kayaks
Thanks for the additive advise. I'll pick up bottle and add it after i change the fuel filter. She's still running fine
Joel230 is offline
#16 Old 11-01-2013
AND MABEL
DAVIETHESCAFF's Avatar
Vehicle: 2008 AMG 55
Other Toys: "Red Mist" 2004 Battistini Hardtail Chopper
Quoted: 586 Post(s)
Smile Basil's solution !!
Just in case it happens again, this may help. (maybe not with the problem, but will sure get rid of the frustration!!)
.........Happiness is not getting what you want, it's wanting what you have.........Daviethescaff
DAVIETHESCAFF is offline
#17 Old 11-02-2013
Other Toys: kayaks
changed filter and added cleaner. Running great and Thanks for the video link !!!
Joel230 is offline
#18 Old 11-02-2013
Great news, glad it was just a filter and nothing more.
Tags
won't start
my SLK doesn't want to start!!! SuzaFan SLK R171 General Discussion 20 06-06-2015 08:12 PM
low idle / intermittent rough idle at start up? gertie SLK R172 General Discussion 10 11-13-2012 06:03 PM
Black & Dekker simple start Dimi190E General Discussion 5 11-11-2010 07:07 PM
