Replace Brake Booster Vacuum Hose SLK 320 - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By DIYGirl
#1 Old 09-09-2013
Vehicle: 2001 SLK 320
Attached is a DIY to replace the Brake Booster Vacuum Hose.
The brake booster vacuum hose is the line that connects the brake booster to the intake manifold on the engine. Due to the location of the connection on the intake manifold, the ridged piece of plastic inside the hose (connector) often gets broken due to pressure placed on the hose while working on other items in the area such as the MAF and Crank-case breather hoses.
Woolly, jbanks15 and CruzerDave like this.
DIYGirl is offline
The Following 4 Users Say Thank You to DIYGirl For This Useful Post:
#2 Old 07-18-2014
question
i have the same exact problem and was wondering what if little broken off bits of pieces get down the brake manifold?
pkim4321 is offline
#3 Old 07-18-2014
Quoted: 6496 Post(s)
pkim4321,
Please update your lvehicle (year,ie 2007 ) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
#4 Old 01-31-2018
Thank you to DIYGirl for the great explanation on replacing the brake booster hose. I broke it while replacing the valve cover gaskets.
However I am unable to extract the yellow tube. Inserting a screw continues to crack and remove a little of the yellow tube. I'm afraid if I keep going I will end up with bits of plastic in the intake manifold. My question is, can I pry out the Clamping ring with the yellow tube and O ring still in it. I don't want to dig this hole any deeper but I need to fix this. Thanks Larry
lmcalee is offline
#5 Old 01-31-2018
Quoted: 2246 Post(s)
Sorry, Larry. @DIYGirl has not been here since 2014. That mention may work but I'll press the clever folk button too:
@Mn car guy
@efair
@stu32
@savcom
@Padgett
@Turdo2
Replace ROTORS and PADS 05 SLK mrdougie SLK R171 Class DIY 27 01-11-2015 10:49 AM
SLK 320 to SLK 32?! NAC Tech. LLC. New Members Introduce Yourself Here 6 10-14-2012 08:22 AM
How to replace tail light lens on 2001 SLK 320 bcondit SLK R170 General Discussion 4 09-20-2012 11:48 PM
