[FIX] Heater blower fan speed regulator - Mercedes Benz SLK Forum
 5Likes
  • 3 Post By oldmanhouse
  • 2 Post By Avel Du
#1 Old 09-17-2018
Vehicle: SLK 230K, 6 speed manual, 2001
Quoted: 11 Post(s)
Hi all. I had some trouble with my heater blower fan recently, when set on speed #1 the speed of the fan would vary wildly. It would come on very weak (so weak the motor whined and squeaked from lack of movement) and then all of sudden it would blast air out like i'd set it to #5 . This also happened when set on speed #2 , but no others, which were working OK.
So I measured the voltage going to the motor using a multimeter, and it was all over the place (between 2v and 10v) rather than constant. So I figured the resistor/regulator to the motor was bad and bought another one. For completeness i also checked the control dials themselves (removed the control unit from the centre console, took it apart, and cleaned it with electrical contact spray) and also lubed and cleaned the motor itself.
So I got around to installing the new resistor/regulator today and it has fixed the problem
hope that might help someone out as i didn't find loads of info about my variable-speed problem, mostly just fans that were completely dead or dead on certain settings, but the cause seems to be the same thing. I think some of the resistors in the regulator are faulty, but not all of them, which is why it works on some settings
FYI part number for new regulator is 2108206210 / A2108206210, at least for the facelift R170. It is the same as a C-class W202 too i believe. I got a cheap no-brand one from ebay but the OEM one was Valeo i think
M4rCu5, Idiot101 and Avel Du like this.
oldmanhouse is online now
The Following User Says Thank You to oldmanhouse For This Useful Post:
#2 Old 09-17-2018
Quoted: 2243 Post(s)
https://www.slkworld.com/slk-r171-cl...ml#post4423089
Excellent stuff.
I've added this to the original fan diy thread above.
M4rCu5 and oldmanhouse like this.
Tags
blower motor, heater, problem, resistor
New member with 2007 slk heater lower regulator Lee J New Members Introduce Yourself Here 10 05-07-2015 02:01 AM
blower fan problems/no long wave on radio/remote problems jexrab SLK R171 General Discussion 4 08-23-2011 02:24 PM
Blower fan speeds are not working properly bcondit SLK R170 General Discussion 2 02-09-2010 12:44 PM
Speedtronic to limit valet drivers speed? nmslk General Discussion 9 01-03-2008 07:27 PM
