R170 Boot/trunk gas struts - Mercedes Benz SLK Forum
 36Likes
#1 Old 05-22-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
Found a procedure for the R171, but nothing for the R170. Until I can redo the job and take some pictures, here is a link to the R171 procedure
Just done my R170 boot/trunk gas struts, using a procedure almost indistinguishable from the R171 procedure.
Some points:
  • R170 boot/trunk gas struts are 170-750-00-36
  • R170 do not have the extension limits buffers; you can just push the boot lid up a bit and the struts will fit without compression.
  • As usual, worth comparing the new struts with the installed ones before you start. And replace them one at a time to allow you to check the other side for comparison.
  • You can pull off the clips from each end quite easily; when under pressure, the ball joints do not pop out. Probably best to do both end of one strut, fit the replacement, and then do both ends of the other strut, to be safe. I pulled mine off completely, using a straight blade screwdriver and levering against the back of the ball joint. (If you are pulling, rather than levering, then the ball joint *could* separate)
  • Remove one, and then fit the replacement, then repeat for the other side.
  • You don't need to ease the clips at all to install; they spring on with moderate pressure. Key thing; don't press on the clip (which needs room to "spring") but press on the body/shaft adjacent.
  • Your new struts probably have both ball joint entrances facing in the same direction; once you have fitted one end (easier with the rod end first), turn the other end (the cylinder, so easier to grip and turn by hand) clockwise (ie to tighten) until you have reached the alignment for the other ball joint. If you don't, you may slacken the mounting thread in the plastic ball housing, and that is often a weak point; they have previously broken on another car I have.
Hope this helps; the task is so quick, finding the screwdriver and opening the packaging takes longer than fitting the struts.
dzieba, dixie and Michael Gerard like this.
Tolak is offline
#2 Old 05-26-2013
Tolak's Avatar
Pictures at last!
Some pictures of the change process.
Simple one to start; check the new and old gas struts match.
Release the top spring clip to ease removal.
Release the bottom spring clip to ease removal. (Note strut will stay in place without spring clip)
Lubricate the ball before fitting the new strut. (Using a lithium grease will avoid degradation of the plastic)
When fitting the new strut, hold by the gas cylinder, so the spring clip has room to move, but you do not need to release the clip to install it.
For me, once the first strut was installed, the boot lid stayed up on that one alone, so made the photographs much easier with the second strut.
(BTW, kudos to the guys who do a proper DIY sequence; getting the camera, spanners and everything in the right place and cleanliness increases the complexity no end)
lyc, JaysonM, slk320chick and 5 others like this.
Tolak is offline
The Following 9 Users Say Thank You to Tolak For This Useful Post:
#3 Old 06-21-2013
JollyJack's Avatar
Vehicle: SLK 230
Other Toys: VOLVO V70 T5
Smile
Nice one mate! 'Big help' with pictures...Thanks very much.
JollyJack is offline
#4 Old 06-23-2013
Vehicle: 2004 SLK320 R170 Special Edition
Other Toys: I own some leggos aswell ;)
Brilliant! thank you very much, order my new struts the other day and have been stressing after looking at my current ones on how to take off, big thanks man
BRC_4 is offline
#5 Old 07-10-2013
lyc
lyc's Avatar
Vehicle: 2014 Ford F250
Send a message via AIM to lyc Send a message via Yahoo to lyc
This is extremely helpful information! When my SLK32 broke down in May of 2012 the dealer gave me a list of things that needed to be replaced and the struts happened to be on that list.
Dealer Cost to replace: $220.23
Actual part Cost: under $40
Time Spent: 30 minutes?
http://www.mbonlineparts.com/parts/2...icleid=1417081
Michael Gerard likes this.
lyc is offline
#6 Old 07-24-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
follow up, can I use this for the ball joint?
white lithium grease
slk320chick is offline
#7 Old 07-24-2013
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Yes, that is the recommended potion
Woolly is offline
#8 Old 07-27-2013
Vehicle: SLK 230K -99
Great info! I actually just performed this mod yesterday without seeing this but I managed anyway.
JaysonM likes this.
nostalgi is offline
#9 Old 09-16-2013
Minion
Quoted: 148 Post(s)
I've ordered these from my dealership [$19 a piece] and can pick them up tomorrow. This is an easy fix yes? How long does it take? like 10 minutes I would assume?
#10 Old 09-16-2013
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
10 minutes if you take a 5 minute break.
slk320chick and Tolak like this.
Len
1999 E300D 215,000 miles
sokoloff is offline
#11 Old 11-21-2013
gringott's Avatar
Vehicle: 1998 SLK230 R170 Stock
Other Toys: 350Z TT
Thanks for the write up. Couldn't believe how weak the old ones were. Took 5 minutes with applying grease and cleanup.
slk320chick likes this.
gringott is offline
#12 Old 11-21-2013
EPerk's Avatar
Vehicle: 1999 SLK 230 Kompresser
Other Toys: 2000 Nissan Altima GLE
Got to have the union break in the middle
gringott and ethana like this.
EPerk is offline
#13 Old 11-21-2013
Minion
Quoted: 148 Post(s)
Yep.. best thing I ever did. And because of this, I also realized that the jeep liftgate needed it done too. But cost 2x as much as the mb oem parts..can you believe that.
#14 Old 11-22-2013
Vehicle: 2000 SLK 230 R170
Other Toys: MG TF 160 Sprint
A GREAT thread Thank You! Once I knew it was so easy I bought a pair of new struts from eBay for under 20 ($30) and took the full 5mins to fit them. Now the boot (trunk) doesn't try to slam on my head anymore!
ethana likes this.
dzieba is offline
#15 Old 12-19-2013
Tolak's Avatar
In amongst the replacement of the struts, I have seen no mention of the idea of oiling the hinges of the complex mechanism that supports the boot lid.
If you can get just a drop into each of the hinge points, the strut will have an easier life, and so will hold up more robustly. However, the movement will have less friction, so the movement will be more "extreme" and hence either upwards or downwards (either side of the blance point).
And there should be no squeak, groan or other untoward noise; the silent boot-lid of death will get you before you hear it coming!
Tolak is offline
#16 Old 01-06-2014
Vehicle: 1999 SLK 230 automatic
Other Toys: Old Honda's CB 350/CB 750
Wish I could get them for $19 each. Just called my MB dealer. $75 for the pair. Maybe cause it's Canada? Things are more costly to transport by dog sled.
legendary620 is offline
#17 Old 01-06-2014
Minion
Quoted: 148 Post(s)
Why would you get them from the dealer? They're only struts! try the local autozones or auto parts stores
legendary620 likes this.
#18 Old 01-07-2014
Tolak's Avatar
Generic strut source?
Or even eBay.
Once the loading and throw have been determined, you can then use any source of struts. (I bought some from eBay for up-and-over cupboard doors, and then fitted them to get the correct force; in this case, you need to get (at least) the correct force to hold up the boot lid, since you cannot adjust the locations)
Interesting that nobody has reported the strut length, throw and nominal force.
Tolak is offline
#19 Old 01-08-2014
Smile
Or even eBay.
OR.....
You can just look on eBay for SLK boot/trunk struts!
dzieba is offline
#20 Old 01-09-2014
Tolak's Avatar
Or even eBay.
Originally Posted by dzieba View Post
OR.....
I need to edit for emphasis:
Or even eBay.
Once the loading and throw have been determined, ...
Certainly, I got my struts from eBay in the manner you describe. Approx 20 GBP for the pair.
Tolak is offline
R170 Fuel Filter replacement/change JaysonM SLK R170 class DIY 13 02-16-2017 02:02 AM
How to strengthen signal with the R170 Antenna dsb SLK R170 class DIY 5 02-12-2013 05:56 PM
Boot/trunk lock querry Kylinski SLK R170 General Discussion 8 09-24-2012 02:49 PM
Does Basset Slooper counts 4 a R170 Problem Berliner Heckflosse SLK R170 General Discussion 3 03-16-2012 12:22 AM
