Budget R170 stereo upgrade... ($475 bucks) - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By LeonardoDaBenz
  • 1 Post By ImMostlyHarmless
#1 Old 07-07-2017
Vehicle: 2001 SLK320 w/ Sport Package.
Hello all,
I've been lurking here quite a while and just wanted to thank everyone here for all of their (unknown to them) assistance with all of my 2001 slk320 related needs over the past year and a half. I actually did this install on the quick and spent about...475$ total. Some of the tips provided by the other threads on installing were extremely helpful. Thank you so much.
Parts list:
$100 Pioneer MVHX560BT digital media receiver headunit (NO CD!) Old model, Out of Stock on Amazon.
$10 Metra Harness
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
$5 Metra Antenna adapter
$10 USB and AUX jack extender
$75 JBL GX600C 6 1/2" components
https://www.amazon.com/JBL-GX600C-2-...rds=jbl+gx600c
$120 Rockford Fosgate Prime R300X4 amplifier.
https://www.crutchfield.com/p_575R30...r300x&skipvs=T
$90 6.5 inch earth quake subs
https://www.sonicelectronix.com/lp/10-ride/sws65x
10$ Couple of sheets of Noico deadener. (bought an entire large box for 35, only used 6 sheets)
10$ 50 Amp breaker on EBAY.
30$ Additional wiring
Head unit install with the adapter was pretty much a no brainer. Offhand I can't remember if I had to swap the constant/keyed power leads on this harness or not. I'm thinking I didn't.
Power for the amplifier was sent down through the relay/fuse box to the amplifier mounted behind the rear seat. It does take up a small amount of room, but I never have anyone over 6 foot or so in my passenger side anyhow. I wasn't worried about losing an inch or two of travel. The USB and aux wires were relocated to the middle console in place of what used to be the cigarette lighter. (Though I'd recommend the smaller 6 feet lead, the 12 foot was way too long and HAS given me issues with connection. It will be replaced soon). Noico sheets were used opposite the mounting holes in the doors as well a decent section under the matting/plastic section of the doors. It helped to create a bit more thunk when the doors close as well. All new wiring was run to the speakers from the amp, the pull throughs for the doors weren't too bad, but I recommend opening the doors ALL the way up, it will help with the passing of the wires immensely. Microphone was routed to the original location but needed a muff to make it usable at in town speeds with the top down. At highway speeds. LOL, Ain't happening. I wasn't fond of the idea of a mic sticking out of some place obvious so I'll deal with it.
I've heard some talk about the earthquake shallow subs being a tab anemic, and I agree, but only in the much lower end of the volume spectrum. I have mine set at the head unit to let anything under 200Hz go through on a flat EQ and the amp passthrough set to though. The components up front are using an 80hz crossover point, also from the head unit. It's not going to win any competitions, but if I want the guy 2 cars ahead of me to know what I'm listening to that's not going to be a problem either.
https://youtu.be/bLmAKhDk6p0
*edit* will have to add more to this post later. Need to get to work, sorry!
ImMostlyHarmless is offline
#2 Old 06-30-2018
Vehicle: 2004 Special Edition SLK320 Black
Other Toys: 2013 Harley Davidson Night Rod Special, 2014 E350 Sport Coupe, 2014 CLA250, 2017 GLC300, 2004 SLK320
In comparison to the stock Bose, other than power, how is the quality/clarity? Last night I just put in a Kenwood Digital Receiver KMM-BT522HD, today I order the JBL GX600C that you installed. I was curious how the installation of the tweeters went?
Time4Tini is offline
#3 Old 06-30-2018
LeonardoDaBenz's Avatar
Quoted: 1044 Post(s)
OP has not been back since Oct 2017.
Maybe he'll see this @ImMostlyHarmless
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#4 Old 07-03-2018
I found the clarity to be on a par with the stock system with the ability to go *much* louder. The JBL tweeters fit right into the stock location using one of the cup adapters that came with the speakers. I did use just a dab of hot glue to ensure they didnt wriggle out of location.
I did end up adding a sealed polk 10 inch sub in the trunk on a 150 watt mono Fosgate amp which really helped the low end, but I do like a lot of bassy music. It wasn't neccesary.
LeonardoDaBenz likes this.
#5 Old 07-03-2018
Welcome back @ImMostlyHarmless Don't be a stranger
LEN
(Moderator)
#6 Old 07-03-2018
6007.us
Padgett's Avatar
Quoted: 568 Post(s)
Just a personal opinion but for the R170 this year I would prefer a Clarion CZ505 - it has variable dial colors to match the dash and Bluetooth for smart phone integration/handsfree.
Padgett is offline
The Following User Says Thank You to Padgett For This Useful Post:
#7 Old 07-05-2018
Thanks for the info, greatly appreciated!
#8 Old 07-05-2018
The Pioneer unit I replaced this with also had RGB color options for the head unit. I was able to match the factory dash orange back lighting pretty darned closely on my unit.
DIY stereo upgrade to the '05 SLK-350 Audio20 (Hertz, Audison, McIntosh) linuxpro SLK R171 Class DIY 81 06-04-2015 09:51 AM
Project: My proposed AV upgrade 1998 R170 gringott General Modifications R170 5 12-25-2009 01:35 PM
upgrade SLK R170 alloys wcdp General Discussion 13 07-23-2009 06:26 PM
Stereo Upgrade MaKEuhigh SLK R171 General Discussion 8 06-22-2009 11:24 AM
Stereo upgrade install fleep SLK R171 General Discussion 40 12-13-2008 10:05 PM
