How to strengthen signal with the R170 Antenna - Mercedes Benz SLK Forum
 9Likes
#1 Old 12-05-2007
dsb
Vehicle: '06 slk55
What:
How to strengthen signal reception with the R170 Antenna
Who:
For those of us that can't stand the look of the R171 long whip antenna but do not wish to sacrifice a ton of reception using just the R170 short antenna.
Why:
Why not? I for sure hate being limited to a few feet when I want to lock/unlock my doors. Plus, I spent good money on a Roof Module. From 50+ feet away, I want to walk to my car all the while it's roof is being lowered. By the time I get there, it's ready.
When:
How about now? It only takes about 20 minutes.
Disclaimer:
I am not an electrician and realize there's probably a better way to do this mod. Then again, this worked for me and that's what counts. Right? I was introduced to this mod from another member, (thanks Ikarus), and decided to put a quick tutorial together. I can say that I've already noticed a vast improvement in signal strength. Please note, I have only tested the lock/unlock range. I really don't listen to radio but I'm sure that signal has improved as well. What was the difference? Well, prior to the mod, I was able to lock/unlock at a maximum of 25 feet. That has grown to 120ft! So, in my experience that's 5 times better!
Tools required:
-Soldier gun and solder (RadioShack Model: 64-2802 $7.99)
-22 gauge wire (RadioShack Model: 278-1224 $5.99)
-R170 Antenna (MB part#A170 820 06 75 approx $70)
-Allen Wrench
-Pen
-Ruler
-Razor Blade
Steps
1) Assuming you already have the R170 antenna installed, remove the antenna's upper section. This upper section is hollow plastic and is simply pulled off the base. I found that it's easier to leave the lower section screwed onto the vehicle. Pry the upper section off while slightly bending it. It should come off fairly easy.
2) Remove the lower section using the supplied Antenna 'Gear'
3) Take two strands of wire and begin wrapping them in a spiral around a small pen or allen wrench. The top section can be folded over. As you proceed, switch to a thicker pen. I used my child's paintbrush. The idea is to have a wire spiral that fits into the antenna cavity. I was able to utilize about 15" of length.
4) Next, strip the ends of the wire. Also, strip a small section of the antenna. Solder one piece to the inner section of the antenna and the other to the lower section.
5) Carefully fit the spiral wire onto the base of the antenna. Next, snap the Antenna's upper section back into place.
6) Reattach the antenna to your vehicle. Again, use the 'gear' to get a tight fit.
That's it! Test it out and see the results for yourself. So far, I am happy with the improvement. I will conduct so more tests if I get the urge. For now, I am done. My biggest gripe with the small R170 antenna is now gone.
dsb is offline
The Following 4 Users Say Thank You to dsb For This Useful Post:
#2 Old 12-05-2007
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
Very nice mate.
viscouscoupling likes this.
#3 Old 12-05-2007
-1-
Don - Founding Member #4
-1-'s Avatar
EXCELLENT photos and documentation DSB. I reviewed the thread that Ikarus referenced from the German site last night. I was intrigued with how easy this mod was. I recently added a aftermarket amplified antenna to my R170 antenna set up. No increase in range with the SmartTop module so I removed it. Thanks for your detailed photos and "how to". This appears to be the answer to acceptable increased range with the R170 antenna. Thanks again for your contribution.
-1- is offline
#4 Old 12-05-2007
-1-
-1-'s Avatar
WOW, it works like MAGIC! I just completed the R170 antenna mod. Thanks (again) to DSB for his detailed instructions and photos. Doesn't get any easier. Takes less than 30 minutes. I used some wire left over from my garage door opener. I just checked the range (car in the garage) and I'm getting over 200 feet. Might even be better than the factory antenna. I checked from the rear, and then the opposite side (away from antenna) and still getting 200 feet plus, even in the woods. Both AM-FM reception are excellent with the car in the garage. The design of the R170 antenna is a joke. No wonder the range is terrible. You have a 1" section of wire as the antenna and as DSB stated, the rubber portion of the antenna is hollow. With that in mind, the factory R170 antenna mast could be 2" in length max. Thanks to the original modifier for this great tip. Identify yourself. This ranks only behind the SmartTop module as BEST, most useful mod for the SLK.
-1- is offline
#5 Old 12-05-2007
dsb
Vehicle: '06 slk55
Don,
I'm happy to hear your results are even BETTER than mine! Isn't this so much better than before?! One of the best mods for sure. I have a feeling I'll be using my Roof Module a lot more at the parking lot. BTW, I wonder if you're getting better distance because of a thinner and thereby longer wire? Perhaps, it's just interference around my house? Either way, it's all good. I did this install late last night and only did a quick test. I'll be testing radio reception (for the wife) today.
dsb is offline
#6 Old 12-05-2007
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
If the signal is not totally up to scratch after the mod you could always add the booster from the facelift car to it.
You would probably end up with a range increased even over the whip.
Remember to test it with a phone if you have one.
#7 Old 12-05-2007
Thank you DSB, IKarus and to the person in Germany.
Would a thinner wire work better because of the longer length that may be accomodated than Gauge 22?
#8 Old 12-05-2007
Vehicle: 2009 Mars Red SLK55
Dan do you think the r170 antenna will fit the facelift model? BTW this is an awesome mod and definitely a solution to the ugly stock antenna...
smoothbnzf4n4tc is offline
#9 Old 12-05-2007
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
Yeah probably or if not I'm sure a similar mod could be carried out on the facelift stub.
#10 Old 12-05-2007
Other Toys: 15 Audi S7, 16 MB GL 350, 2015 Porsche 911 GTS, Maxum SR 2200, Zone E Electric Car
Great Mod...Only thing I need now is an R170 antenna Can these only be purchased at Dealer?
Thanks again to dsb and the original source...
nevets is online now
#11 Old 12-05-2007
Vehicle: 05 SLK 200
Is there a better solution for SL antenna? That would be really great!
diclehana is offline
#12 Old 12-05-2007
Vehicle: 2006 SLK 280 w. 6M
You're most welcome. I had found a great description of the idea on this page, but the publisher himself credits an mbslk.de member named mac67. It seems the whole thing got started by him in this thread.
In that original thread at mbslk.de, there is a lengthy discussion about what the optimal length would be. The original proposal by mac67 was to solder a single wire to the stub. By experimentation, he found that the best length was about 75cm. Incidentally, this is about a quarter of the wavelength in the FM reception band @ 100MHz. Then, someone else pointed out that an antenna of half the wavelength would work even better, but that the antenna would have to be tapped in the middle in order to maximize the electric field strength. This eventually led to the described design.
So, ultimately, the best FM reception should be achieved with two wire branches of about 75cm length each. If you cannot fit as much with a particular wire, it may indeed be better to pick a thinner one.
Darn, I really need that antenna now. It looks so much better!
Ikarus is offline
#13 Old 12-05-2007
Thank you Ikarus for the explanation. I have called the parts dep't at MB. The antenna should be available in one to two days. I will attempt to do the same mod this weekend with a thinner insulated wire and try to get 75 cm if possible.
#14 Old 12-05-2007
dsb
Vehicle: '06 slk55
Ikarus,
Thanks for the links... of course I didn't understand any of it. So, I take it you're German. Are there any other easy mods we should be aware of? Looks like lots going on in those links?
dsb is offline
#15 Old 12-05-2007
MarkR171's Avatar
Vehicle: '07 SLK55 030
Quoted: 12 Post(s)
Aww man, now I have to go and spend money on a roof module! The only thing that was keeping me from getting one is that I'd have to be near the car to use it anyway because of the range with the R170 antenna. I guess now I really want that module!
Thanks for posting this dsb, I'll be making a trip to Radioshack today
Sold: '07 SLK280 | 18" TSW Bremmas | Toyo T1-R 225F/245R | SmartTop V.3 | Green Filters
Sold: '07 SLK55 AMG | 030 Package | Custom X-Pipe | Secondary Cat Delete | SmartTop V3.33 | Mod R170 Antenna | BC Racing Coilovers | Racingbrake Two-Piece Rotors | Enkei Pf-01, Michelin Super Sport 245F/275R
Current: '15 Alfa Romeo 4C | Black on Red | Track Package
MarkR171 is offline
#16 Old 12-05-2007
Money well spent...believe meSometimes I just sit in the garage and watch..... up and down, up and down....mezmerizing...
#17 Old 12-05-2007
MarkR171's Avatar
Quoted: 12 Post(s)
Went to Radioshack, got the supplies and did the mod. Works perfectly! Kinda makes you think which idiot designed the R170 antenna with so little wire!
With xmas just around the corner, a roof module might be a fine present Just need to decide on which!
MarkR171 is offline
#18 Old 12-06-2007
I'm definitely keeping an eye on this site, but the antenna mod is hard to beat. The one other mod I had found there and posted about here was the DIY AUX for Audio 20.
Ikarus is offline
#19 Old 12-06-2007
This antenna was originally meant for cell phone reception only, so I wouldn't say it's justified to call the poor guy an idiot.
Ikarus is offline
#20 Old 12-06-2007
Vehicle: SLK280
this looks like a fantastic mod!! I've been planning to do the whole bumper extension thingy with the SL antenna, but have been putting it off because of having to take apart parts of the car, etc..soldering to circuit boards and whatnot. This is infinitely simpler..while the R170 antenna is, IMHO, not as good looking as the SL antenna, its still miles better than the R171 antenna. And now with this mod, I won't lose much, if any range!! Antenna is on order right now
thanks dsb and original modder, as they say in australia, THATS GOLD!
ghostdunks is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.slkworld.com/slk-r170-class-diy/4404-how-strengthen-signal-r170-antenna.html
Posted By For Type Date
Antenna solution.... - Page 3 - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 10-21-2008 03:57 PM
Whips and stubs: antennae - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 10-13-2008 09:32 PM
Antenna solution.... - Page 2 - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 10-13-2008 11:05 AM
BRICO: Instalar en un SLK la antena modificada de un SL This thread Refback 10-03-2008 05:44 PM
SLK55 Parting Out - MBWorld.org Forums This thread Refback 09-24-2008 01:41 PM
SLK55 Parting Out - MBWorld.org Forums This thread Refback 09-18-2008 03:10 AM
Stupid Aerials | Facebook This thread Refback 08-30-2008 08:35 PM
Cruddy radio and a long antenna - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 08-26-2008 12:00 AM
Antenna ?? - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 07-15-2008 02:00 PM
$107 for A170 820 06 75 MB Antenna! Please Help! - MBWorld.org Forums This thread Refback 07-07-2008 08:24 PM
SLK200,280,350,AMG,nos essais et commentaires - Cabriolets Essais Particuliers - FORUM Cabriolets - FORUM Automobiles mythiques et d'exc This thread Refback 07-05-2008 10:30 AM
SLK200,280,350,AMG,nos essais et commentaires - Cabriolets Essais Particuliers - FORUM Cabriolets - FORUM Automobiles mythiques et d'exc This thread Refback 07-05-2008 02:54 AM
Stupid Aerials | Facebook This thread Refback 07-03-2008 09:47 AM
$107 for A170 820 06 75 MB Antenna! Please Help! - MBWorld.org Forums This thread Refback 06-28-2008 02:28 PM
$107 for A170 820 06 75 MB Antenna! Please Help! - MBWorld.org Forums This thread Refback 06-22-2008 07:13 PM
$107 for A170 820 06 75 MB Antenna! Please Help! - MBWorld.org Forums This thread Refback 06-21-2008 10:22 AM
Untitled document This thread Refback 06-21-2008 05:06 AM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 06-19-2008 11:59 PM
Shorty SLK Antenna - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 06-08-2008 09:20 PM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 06-07-2008 11:11 AM
Mercedes-SLK, le site... This thread Refback 06-02-2008 01:50 PM
Mercedes-SLK, le site... Forums-viewtopic-Antenne SL This thread Refback 05-31-2008 12:43 PM
Mercedes-SLK, le site... Forums-viewtopic-Antenne SL This thread Refback 05-31-2008 03:59 AM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 05-10-2008 12:40 PM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 05-08-2008 04:02 AM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 05-06-2008 11:28 AM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 05-06-2008 09:19 AM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 05-04-2008 10:29 PM
Antenna stolen, need replacement - MBWorld.org Forums This thread Refback 05-04-2008 10:20 PM
Antennas - Page 3 - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 05-03-2008 02:09 AM
SLK55 AMG (R171) Picture Thread - Page 5 - MBWorld.org Forums This thread Refback 04-29-2008 07:26 PM
Searching for??? - Benzworld.org - Mercedes Benz Discussion Forum This thread Pingback 04-22-2008 12:20 AM
R170 Antenna Mod??? WhyBeGood General Discussion 8 02-09-2009 07:44 PM
Part Number For R170 Short Antenna MDS General Modifications R171 7 05-01-2008 10:00 AM
loose exterior antenna R170 leeco SLK R170 General Discussion 0 03-21-2008 12:04 AM
