Is your PSE Pump damp ? - Mercedes Benz SLK Forum
 5Likes
  • 5 Post By ixion
#1 Old 04-25-2017
ixion's Avatar
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 41 Post(s)
Unhappy Is your PSE Pump damp ?
Damp in the PSE
I finally got round to doing one of those job's that are on the everlasting list of "need to's"
Making sure that my PSE waas fully protected.
Removing & Installing the PSE.
Clear everything from the Boot including Spare Wheel. It's at the bottom on the Right if viewed from the rear.
Tight Squeze
Covering gone - Only Sponge left
The PSE pump is the pump located in the trunk/boot that controls the central locking, alarm, rear demister, interior dome light etc in the r170 models.
It is prone to getting damp/wet and failing if not looked after.
The problem being that in its normal position all the Electrical Connections are at the bottom.
It is enclosed in a foam container with a foam lid. This can be in a rough state (See above).
Replacement is available very cheaply. PtNo# A1708000135. About Ł12
You can see the comparison between one in good condition and one that is not above. The second one has actually turned into a "Sponge"
Yoy can use the Mk1 finger to feel if there is any dampness around the bottom of the unit.Mine felt quite dry but as a preventative measure I decided to do the recommended mod's to it.
That is if necessary replace the foam container, Turn the Unit Upside down and wrap some ventilated plastic (IE.A plastic bag) around it
Fair warning it's a tight fit in the compartment when it's in the foam container. Persevere and it will come out and go back
I slid my PSE out from it location and gave it a good examination. Everything OK.
Then I Inverted it (Pipes and Wires at the Bottom) without using any wiring extension mods, wrapped it up in ventilated plastic bag (holes at the top)to allow it to breath.
Put it back in the foam container. Everything has been running OK since.
Do check the vacumn pipes are not crimped.
Bye the way - I managed to invert the PSE without any wiring or pipe extension and It's been ok since.
If this unit fails it costs New over Ł400 or a good one from a scrapper goes for about Ł150.
jbanks15, curro101, Pictor and 2 others like this.
ixion is offline
The Following 2 Users Say Thank You to ixion For This Useful Post:
How to replace water pump R171 SLK55 thirteendog AMGs 22 02-26-2015 11:21 AM
Central Locking System (PSE Pump) jznation SLK R170 General Discussion 4 03-20-2014 01:47 PM
Replaced PSE Pump, Horn Chrips when Ignition in Position 2 MZeraldo SLK R170 General Discussion 2 10-30-2013 03:26 AM
PSE pump MGMGrand SLK R170 General Discussion 2 05-26-2013 07:11 PM
