How to change SLK320 spark plug - Mercedes Benz SLK Forum
 10Likes
  • 5 Post By profmbo
  • 1 Post By profmbo
  • 1 Post By BluBenz
  • 1 Post By AndyW
  • 1 Post By AndyW
  • 1 Post By jleeo
#1 Old 03-31-2013
Vehicle: SLK320 R170 Auto argent
Other Toys: Grand Cherokee 4.0 Aprilia Mana XT350
hi all,
I have changed my 12 spark plus 2 weeks ago
who invented the twin spark
I would say it is easy provided you have the good tools
dismantle the cover with air filters (the whole simply clipsed)
I think nobody tried without removing it
dismantle the 3 spark coil on each side the wires A & B are well marked
the plugs cover were very difficult to remove after 12 years & 79.000 km
the tools
in Mecatechnic 15 € +15 €
Douille articulée pour bougies 16mm sur carré 3/8" | UO20097
Douille articulée 3/8 | UO20040
in Facom 100 € (new on Ebay)
FACOM ratchet ref J.6PB 3/8" with rotating lever
it is important that the plugs be locked in (bush) tool
here are some pictures
spark plug 4a LHD
spark plug 6b LHD
articulated bush & new FACOM 3/8 ratchet
the old the new box for the spark plug...
the screw of the coil is not of "captive" type
I did not remove the metal sheet for heat protection
I have read on other forum that it is HELL with standard tool
after hand washing, cold beer recommanded not mandatory
profmbo is offline
The Following 3 Users Say Thank You to profmbo For This Useful Post:
#2 Old 03-31-2013
Quoted: 6498 Post(s)
Thanks and great pics! Moving to R170 diy section and sticky
#3 Old 03-31-2013
Nice stuff! Need to do mine shortly - found this write up as well. Has been tricky finding things for the 320.
(Not sure on linking so name has been removed. Mod please correct if that is ok)
BW
http://www.<otherforum>.org/forums/r170-slk-class/1586740-spark-plugs-transmission-fluid-change-slk320.html
Ohhshoot is offline
#4 Old 03-31-2013
putting the post in the right place
sorry for not putting the post in the right place...
English is not my mother tongue
DIY meant nothing to me I guess it is a "do it yourself"
there was a SLK230 spark bulb topic there...
tools are French e shop, but you should find equivalent in US, you have more choice there
to mount the spark plug exhaust system etc I use the same type of grease as this photo. My container as this pic is 30 years old...
this grease is used with steam in steam plant (I started to work there in maintenance dpt) it is available (new container) at Amazon.com
profmbo is offline
#5 Old 06-09-2013
Vehicle: 2001 SLK320 Sport
Plugs replaced!
I replaced the plugs in my '01 320 yesterday. Wish I would have had that socket drive tool! I struggled a bit using a 3" extension and a wobbly adapter, but it worked well enough to get the job done.
The local dealership wanted almost $500 to change the plugs; I did the job for less than $70 in about 4 hours time and performed some cleanup while I was at it. I'm pretty sure the old plugs were the original ones.
I found this tutorial to be helpful as well: http://www.pelicanparts.com/techarti..._and_Coils.htm
Jim
Ohhshoot likes this.
BluBenz is offline
#6 Old 03-13-2014
Just to add...the idea is to pull the plug wires straight out as possible, not on an angle. The wrench method works well as long as it's leveraged to pull the wires in-line with the plugs. Do that and it's a 45 minute job. Hope that helps.
kuh pahl is offline
#7 Old 04-25-2015
AndyW's Avatar
Other Toys: 2008 335i
First, Thx for this thread. Was helpful for doing my sparkplugs. I do want to add somthing I think will be helpful for those who replace their spark plug wires as well...if you get these:
Amazon.com: NGK (58410) EUC071 Spark Plug Wire Set: Automotive
They are good quality and less expensive than stock, but I wish I had looked more closely at the pictures. They do not have the "lip" that the factory cables do, which means there is nothing for the factory tool to grab to remove them when it is time...so I will have "fun" in 50K getting these off. YMMV.
simplyslk likes this.
AndyW is offline
#8 Old 04-25-2015
AndyW's Avatar
Apparently I cannot edit my own posts...anyway, I also wanted to add two more points:
1. I used these plugs. http://smile.amazon.com/gp/product/B...?ie=UTF8&psc=1
2. I also replaced all the crankcase breather hoses...they definitely needed.
Overall, I think the engine is running much smoother now and am glad I did it. (did all this at 75K).
AndyW is offline
#9 Old 05-18-2015
Vehicle: 2003 SLK 320
I called a few local shops and you are right. its a $500 job. I didn't want to do it because I read that the engine had to be raised on the 320. I actually saw video of the guy underneath disassembling the motor mounts. after reading this thread I think i'm going to try it. my old 98 slk230 was simple. if I can find that funny looking tool the guy posted would it be even easier? who sells them? i can barely read this
the tools
grown_sexy is offline
#10 Old 05-18-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
With two plugs/cylinder, you'll probably never need to remove the plugs. I believe they are good for 100K miles?
In any case, just checking your MPG and seeing it is reasonable would defer this task for years. I'd buy the NA 4-cylinder anyway. Much easier to service.
DSSG is offline
#11 Old 05-19-2015
Well recently my 320 has developed a slight shimmy when I'm at the light with my foot on the brake or if I'm sitting in park at idle.them mechanic did a quick observation and said it could be plugs ands wires.its like every 15-20 secs you can feel it give a little shake.the car has 138k on it.
#12 Old 06-03-2017
Vehicle: 2002 SLK320-G3
5 years - but only 5,000 miles.
Last plug change was in 2012 by dealer and it ran $500+
We don't drive the car much - seasonal usage. Five years have passed, but we've only driven 5,000 miles in that time. We have slightly over 30,000 miles on this 2002 SLK 320.
Any thoughts on the five year limit on plugs. Is it possible they deteriorate even with little sparking? Guess I'm looking for an excuse to avoid the project!
jleeo is offline
#13 Old 06-03-2017
fyi this post is 2 years old
some members do not go into old threads
want me to move it to your own new thread?
https://www.slkworld.com/new-members-...d-how-fix.html
also, mark your calendar
https://www.slkworld.com/u-s-florida/...keland-fl.html
#14 Old 06-04-2017
AndyW's Avatar
If it runs fine, I'd say you are good.
AndyW is offline
The Following User Says Thank You to AndyW For This Useful Post:
Tags
6 cyl, maintenance, service work, slk320, spark plug
2005 SLK55 Spark Plug Change shark AMGs 17 04-28-2019 09:56 AM
Spark plug change Polarbear AMGs 5 04-24-2019 09:56 AM
DIY: R171 spark plug change (M272 engine) Iridium SLK R171 Class DIY 32 06-22-2016 08:50 PM
Spark Plug Change UK-C200 SLK R171 General Discussion 53 06-30-2013 06:45 AM
How to change SLK230 Spark Plugs SLKman Performance MODS for the R170 17 08-09-2012 05:15 PM
