SLK320 Starter replacement - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By thtguy
#1 Old 10-18-2016
Vehicle: 2002 SLK320
Let me Preface with - sorry no pics. but I will try to detail the best I can quickly.
1. Disconnect the Battery
2. while car is on ground remove Top starter bolt. it is easier to get to from the top.
3. Jackup front of car, put jack stand under car, remove passenger side wheel.
4. disconnect starter trigger cable, smaller of the 2 cables.
5. remove bottom starter bolt. kinda a pain to reach behind CAT, but it can be done without removing.
6. slide out starter from bell housing manipulate it to face up so you can remove the Main Lead.
7. use a ball joint remover, to disconnect tie-rod end from passenger side spindle.
8. remove bolt from passenger side idle arm (do not have to disconnect from track rod) bult uses a #12 E-Torx on top.
9. turn steering wheel all the way to the right. after you do this you should be able to manipulate it out without removing any exhaust components, or the motor mount.
to put in do in reverse order.
jbanks15, Idiot101 and john hannon like this.
thtguy is offline
The Following User Says Thank You to thtguy For This Useful Post:
SLK320 replacement mmitchellSLK55 New Members Introduce Yourself Here 25 12-16-2013 02:59 PM
SLK320 Harmonic Balancer / Crank Pulley / Vibration Damper replacement BluBenz SLK R170 General Discussion 6 06-17-2013 09:05 AM
radio replacement 2001 SLK320 kevinjordanpe New Members Introduce Yourself Here 10 08-10-2011 05:15 AM
DIY starter replace 2003 SLK320 tomdavisdotcom SLK R170 General Discussion 8 04-29-2011 12:54 AM
