Transponder Cover Change Cheat - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By mightycpa
#1 Old 02-20-2016
Vehicle: 1998 SLK230, 2000 SLK230, 2012 SLK250
Other Toys: Tennis Racquet
Quoted: 45 Post(s)
This forum has been very helpful to me with a variety of posts, so I thought I'd give back a little bit. My transponder cover looked terrible - dingy gray and dirty. So I tried staining it. It looked even worse.
So, without thinking too much about it, I found the part locally for around $10. When I got the part, what I found out was that to install this part, you had to disconnect the transponder wire which runs behind the instrument panel. A couple of posts on SLKWORLD confirmed what I was seeing with my own eyes. Hours of work! I called a couple of dealers, and found that the transponder is not VIN coded. I deduced that this meant that it is basically just a little radio that doesn't care what data it is transmitting. The destination takes care of the decoding. This meant that I could probably cut the wire and reconnect it after I switched the cover.
Snip. Now I'm committed to this.
The first thing I tried was to use plug connectors. Bad idea. They were too bulky, and it was going to be more than difficult to get them plugged together, because of the shape.
Much better idea. Who needs a plug on a transponder anyway, amirite?
I connected it without too much trouble. Notice the shielding to reduce electronic noise.
Then I finished the installation. Pretty nice, don't you think? I went with black.
Then came the moment of truth.
Success! It works!
And that's how you save yourself several hours or several hundreds of dollars at the dealership. I hope this helps someone.
etyu, jbanks15 and freealta like this.
mightycpa is offline
The Following User Says Thank You to mightycpa For This Useful Post:
#2 Old 02-20-2016
Vehicle: None
Other Toys: Boat
Nice job, thanks for the photo's.
SteveVa is offline
#3 Old 02-20-2016
Photo-tutorials are best
SLK R170 Valve cover refinishing ITAdrian SLK R170 class DIY 7 07-21-2019 05:29 AM
Replaced oil separator, Drain Pan and Housing Cover Crank081 SLK R171 Class DIY 2 10-09-2015 04:34 PM
DIY : R170 : '98 Benz SLK 230 How to exchange engine cover gasket and valve gaskets w PIC dr.Benz SLK R170 class DIY 13 08-06-2013 01:40 PM
Automatic Car Cover Tummy General Discussion 2 01-09-2010 02:41 PM
