Intermittent seat adjustment problem. Seat relay fix. - Mercedes Benz SLK Forum
 20Likes
#1 Old 09-22-2012
Quoted: 43 Post(s)
Hi folks!
It's been a while since I've been to DIY section. I thought we should have a dedicated thread to the following issue: Intermittent seat adjustment problem. I have replied to the thread on Benzworld
http://www.benzworld.org/forums/r170...ent-relay.html
but thought I'd share my experience with SLKWorld members
I performed this repair a while ago and still have some pics.
The problem I came up with is that sometimes my both seats wouldn't adjust out of a sudden. I was cleaning the car and has folded both of my seats, opened the roof and was busy busy cleaning =) Then, when I was done I had to go and pick up my wife. And guess what... My seats would not adjust!!! They stayed in this awkward position where I wasn't even able to drive... That was awful! After some jiggling wiggling - turning ignition on/off, starting the car, kicking the tires, cleaning the headlights.. I just gave up and went home. Couple minutes later I came up to the car and... Both seats started working!!! I immediately adjusted them in the comfortable position and the same evening went to research the problem!
The problem is that over the time the contacts on the seat relay get "cracked" and it causes intermittent failure.
There are two solutions:
1. Buy a new seat relay $35-50. Part #: A 002 542 22 19
2. Solder cracked connections! (Really cheap and easy)!
Tools needed:
a. Solder iron
b. Solder
c. Solder cleaner (optional). I used wet sponge.
d. Patience =)
So, to fix that you first need to disassemble the lower dashboard.
For the instructions, please follow these directions all the way to step 9.
http://www.buellwinkle.com/r170/dash1.htm
And you will be able to get to the seat relay:
Simply pull it out:
Now you need to open it. Use a flat-head screwdriver or any other similar tool. Be careful to take a note how the contact board is located so you don't damage when sticking your screwdriver in!!!
After you managed to disassemble it you have the following:
I pointed to the cracked contacts on the picture. Mine had about 5-7 of them!!!!! I think it happened due to extensive heat here in Texas.
Here's another picture so you can see it:
Inspect your relay for cracked contacts! It may contain 1 or many!
Now, all you have to do is solder it! Really easy! I'm not a professional solder-man and this was my first time too =)
Get a solder iron. (You can borrow one from your friend or buy one at Radioshack). Then get some solder. DO NOT buy cheap one in a dollar store! Get one from Radioshack. Will cost you $3-5.
Then just get to work! Here are some of the tutorials which helped me!
1.
2. http://www.aaroncake.net/electronics/solder.htm
3. http://www.instructables.com/id/How-to-solder/
Make sure all cracks are covered with solder!
After you're done assemble the relay and plug it back in. Test if your seats work!
As I've said I did mine couple months ago and it works fine!
P.S. saved money was spent on LED bulbs =)
The Following 10 Users Say Thank You to JaysonM For This Useful Post:
#2 Old 09-22-2012
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
See now Jayson.........If you had Manual seats like i do, you wouldn't have this problem! Also it cuts down on some major weight, so therefore my car is faster than yours because of the weight reduction (; Have a great day!
Btw, great DIY post as usual, I'm sure this will be helpfull to some people!
JaysonM likes this.
Bradley61496 is offline
#3 Old 09-23-2012
Quoted: 43 Post(s)
Bradely, I just can't live with it anymore... It means your car will start couple milliseconds faster on a red light... LOL!!! Can't beat you anymore! Well, hopefully I'm not a racer I did kickstart may be once or twice when I first bought it =)
Hope it will help somebody to save a buck! You have a good day too!
#4 Old 09-23-2012
Hahaha yeahh, im not a racer either and our cars aren't really meant to be drove like one either!
#5 Old 03-18-2013
Vehicle: 2003 SLK 320 (VIN: WDBKK65FX3F280089)
Other Toys: 72 Corvette Conv. (purchased in 72) & Cadillac STS
Post Intermittent seat adjustment problem. Seat relay fix.
Jayson, Thanks again for such a great post ! With your instructions and photographs, the process of locating and accessing the seat control relay was greatly assisted. (I believe that MB designers went way out of their way to position that relay into nearly the most inaccessible location possible). As luck would have it, Saturday I was able to schedule time for the repair task, and the seats were working fine. Knowing the problem would reoccur - at probably the most inopportune time, I went ahead and removed the relay to "fix it". Unfortunately, all the solder connections looked fine - even checked fine with a VOM. So I cleaned the contacts and reseated the relay into its socket. Again, everything worked great - until the next day. The only thing I can imagine is that the actual relay contacts themselves have become worn to the point that the connection is intermittent. I suppose I should go ahead and purchase a replacement relay - I found one for $36.43 including shipping - which is probably not too bad.
At least, thanks to you, I know where it it and how to get to it !
A GREAT BIG THANKS AGAIN FOR YOUR TERRIFIC POST!!!
- Rob
Rob7412 is offline
The Following User Says Thank You to Rob7412 For This Useful Post:
#6 Old 03-18-2013
Quoted: 43 Post(s)
You're welcome Rob! Glad you sorted it out! Indeed, the location of the relay is not the most convenient one (: I'm not good with electronic boards so I can just keep wondering what can go wrong with the relay. It's been a long time since I fixed mine and it works just fine! Well, at least $35 is not that bad!
#7 Old 03-29-2013
nimbusgb's Avatar
Quoted: 236 Post(s)
I got my 'new' slk 320 this morning and one of the faults I had on delivery was a lack of any life in the electric seats.
Read through this thread popped out the lower panel and removed a really crummy hands free kit and it's mic and buttons and stripped and resoldered the seat relay.
I must add here that I have been soldering stuff for more than 30 years and I know what a dry ( cracked ) joint looks like but visually my relay looked good so I wasn't too hopefull that this was going to fix things.
Plugged the relay back in and hey presto! Working seats.
JasonM as the kids say .......... Legend!
jbanks15 and El_Murcielago like this.
nimbusgb is offline
#8 Old 03-29-2013
Quoted: 6084 Post(s)
Jayson is truly a whiz kid!
Wavetrac LSD thread here:
#9 Old 03-29-2013
Quoted: 43 Post(s)
First of all, congratulations on new car! Hope you like it!
I'm glad that it resolved your problem!
You all are making me blush =) LOL!
I don't know who had this in his signature but I liked these words: "Everything can be fixed with a little patience!
#10 Old 06-21-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Bumping the thread
So the other day, I get in the car in the morning, and I noticed, my power seats wouldn't move forward [they were both working fine the night before]. Let me clarify, they weren't working AT all. So I immediately thought ok Ill check the fuses, but after about 5 minutes of driving, suddenly both worked fine. The mechanic/lawyer at work said it wasn't a fuse issue, it was a connectivity issue.
And while today I have no problems with the seats I wanted to look through the threads to see what it possibly could be.
The first thread I found was here:
https://www.slkworld.com/slk-r170-gen...t-problem.html
And this was the second thread. I thought it was worth bumping even after all this time. Thanks for the great DIY J.
slk320chick is offline
#11 Old 05-29-2014
VTBlade's Avatar
Vehicle: 2002 SLK 230k
Quoted: 14 Post(s)
Like a charm
Cheers for the easy tutorial... I have been putting this job off for over a year; I had to drive around for over half an hour before my last mot, last July, til they decided to work (its came on the UK mot that seats must adjust).
Five minute fix as I already had my lower dash off to modify the ignition to keyless, and didn't want the same rigmarole this year for mot.
Removed, opened, one dry joint soldered, closed, replaced and tested. Job done.
JaysonM likes this.
VTBlade is offline
#12 Old 06-22-2014
Vehicle: 2004 slk 230
Thanks, the power seats on my SLK quit working. With your instructions I just might be able to fix it.
gletson is offline
#13 Old 08-22-2014
hamrt's Avatar
Vehicle: 2004 SLK320 Special Edition
Other Toys: 1991 Mercedes-Benz 300CE 24 W124, 1982 Mercedes-Benz300D TurboDiesel W123
Post Dead Seats Only With Door Open, Key Off
My dead seats are isolated to the door being open. With the key on, they both work fine. With the door open and key off, they are dead. I can hear the relay click in the dash when the door switch is pushed. Could a faulty K24 relay still be causing this situation?
Update: Saw a couple of people say to hit the bottom of the dash. So I did and the seats started working! So maybe it is the K24 relay? I can't explain why I heard the relay (or maybe it was a different relay) clicking, but the seats still wouldn't work. Something was going on in there. Chances are, it's the relay. I never did actually see the relay, so will have to dig deeper behind the insulation. I'll see if the suspect solder joint is cracked and repair it.
hamrt is offline
#14 Old 09-27-2014
Vehicle: '02 SLK32 AMG in "naked" MB color that was used for getting a car's weight to be under a HIGH number
Other Toys: bike as in road bike, 13lbs. A beautiful machine!
Quoted: 46 Post(s)
Is A440203 the part Number which I see imprinted on the side of the relay cover, MB only I suppose? My body would not want to have to do the DIY more than once so new for this guy! Mark
Sweet04 is offline
#15 Old 09-27-2014
Quoted: 43 Post(s)
No, the actual part number is A 002 542 22 19
#16 Old 11-11-2014
Vehicle: SLK 320, 2001
JaysonM,
the instruction at
are not available. Could you repost them please.
thanks
SLK622 is offline
#17 Old 11-11-2014
That site has been down for a long time.
#18 Old 11-11-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 525 Post(s)
Originally Posted by SLK622 View Post
JaysonM,
the instruction at
thanks
Check out " Dissasemble " here :
SLK Home Page
curro101 is offline
#19 Old 11-12-2014
Can anyone post the instructions for how you remove the dashborad to get to the relay. they are no longer available at the url listed in JasonM instructions.
thanks
SLK622 is offline
#20 Old 11-12-2014
curro101's Avatar
Quoted: 525 Post(s)
Try reading the post just above yours ....
curro101 is offline
Electric Seat Adjustment Problem optimistique1 SLK R170 General Discussion 6 09-21-2011 04:07 PM
Seat adjustment problem dVb SLK R171 General Discussion 22 01-11-2011 08:30 PM
