How to remove/replace 2 serpentine belts on R170 230? - Mercedes Benz SLK Forum
 4Likes
#1 Old 08-23-2012
Post How to remove/replace 2 serpentine belts on R170 230?
(Post edited 12/15/2012)
Dear fellow members,
I just changed my serpentine belts today! I must say it's an easy job! The hardest part is to "build" an extension
I read this post by Bazzle from Benzoworld.com too =)
http://www.benzworld.org/forums/r170...ml#post2187392
There are 2! serpentine belts on my SLK 230, So I think it's better to replace it at the same time. I drive it for about 40,000 miles and hell knows when these were changed. They look good though. My friend took a look at it and said they were a little dry, and that they need to be changed every 70,000 miles. He showed me his and it looked pretty much of the same condition, and he is at 70,000 miles on it and is about to replace his.
The 2 belts I need will total me $52 + shipping, so it's not that expensive and will avoid my guessing when the hell will they tear apart =)
So, here we have our tension pulleys:
Passenger's side:
Driver's side:
And here's a diagram described in the manual on How to position! belts properly: NOTE: Please take a picture anyways before your proceed and remember the location of the belts and how they are installed!
Again, left side:
Right side:
Ok, Tools you'll need:
1) Torx socket E10 as Bazzle recommended. However, I didn't have one and used 8mm socket and it worked just fine for me!
2) Extension or long bar to get a strong grip and make it easier to pull the tensioner.
My hand built extension =) I digged in my friends tools bucket and found a bunch of extensions, so I just assembled them together and mounted a socket at the end LOL =) I don't remember the size of the socket but enough to fit the handle of the wrench
I think my programming skills of assembling things together work in reality too
You can go ahead and search for tools online. I found some pulley belt tensioner tools for around $15-$20 but why pay extra when you just replace those once in 70k?!
So, to release the tension you should pull to the left, as if you're unscrewing it (counter-clockwise) NOTE: Be careful and watch you grip and fingers! Make sure they don't slip. I used a cutting glove for that purpose to protect me from injury!
You should start with the left side, since that belt sits towards to the front and you will need to slip this one off first before you get to the bigger (back one).
Left side:
Right side:
When the tension is released simply slip the belt off. Left then right one. Get your new shiny belt =)
This is how mine looked in comparison to the old one: (The old one on top. It proudly says "Made in Germany". The new one is on the bottom. Notice that it's from Romania But the quality seems to be identical. It came from MB dealer... =) )
I got mine from Mymercedesparts.com for $50 for both. Really good service! Fast and quick responses! Switched to these guys after Getmercedesparts.com didn't reply any of my emails. They do ship products your order and they are fast too, but no online customer support =(
Back to our sheep =)
Put the bigger belt (this is going to be the back one) first. Apply tension and slip it over the tensioner pulley! NOTE: CHECK that all groves are sitting properly!
Slip the smaller belt (front one) the same way. CHECK for groove sitting!
Now, after you have checked and grooves seem to be sitting correctly, start the car and immediately shut if off! (as Bazzle from Benzoworld suggested). Go check the belts! Is everything looks alright? Congratulations! You just performed 5-10 minute job worth of couple $$$'s!!!!!
Whew... hope I described it in details =)
The Following 5 Users Say Thank You to JaysonM For This Useful Post:
#2 Old 08-23-2012
Quoted: 6496 Post(s)
moving to r170 general discussion section
#3 Old 08-23-2012
leapyfish's Avatar
Here's a link from another forum
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#4 Old 08-23-2012
Thanks! I missed that one! =)) Hopefully will update this thread into DIY after I'm done!
#5 Old 08-23-2012
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
I did mine about 1,000 miles ago, bought new mercedes belts (: you will need an inverted torques and a braker bar.....Slip that on and turn it...i forgot witch way to go...but you will see! Than slip the old belt off and reverse the procedure! (58,000)
Bradley61496 is offline
#6 Old 08-23-2012
leapyfish's Avatar
A great idea.
Thanks.
#7 Old 08-24-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
There is no specified change interval on the belts. However, they are to be "checked" every 60,000 miles.
Len
1999 E300D 215,000 miles
sokoloff is offline
#8 Old 08-24-2012
So, just check for cracks or anything like that? Mine seems fine, except my friend told me it looks kind of dry and it seems to be just the time to replace it.
#9 Old 08-25-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Well it's not supposed to be wet.
Yes, check for cracks, shiny spots, ribs wearing off, etc. Rule of thumb I use is about ten years or 100,000 miles. Throw your old one in the trunk in case of emergency.
Len
sokoloff is offline
#10 Old 08-26-2012
why does your supercharger look so different?
#11 Old 08-26-2012
Bradley, I would assume that it's the matter of MB SLK "prelift" and "postlift" versions. Since I've read that even when you install Halo head lights you need special adapter harness for you "prelift" SLK, whereas "postlift" models (like mine) doesn't require one! Mine was plug and play! I think they slightly changed couple things.
#12 Old 08-27-2012
Mine was plug and play...it already had the adapter in it before from factory....Is your fitting rectangle as is with no adapter? Mine is circle than a Mercedes adapter than the rectangle hole!
#13 Old 08-27-2012
They were probably thinking...."These headlights are really ugly....lets give this guy the adapter so he will have no issues with aftermarkets down the rode!" Germans...always thinking ahead (;
#14 Old 08-27-2012
I think you just got lucky =)) LOL! Glad you've got your adapters with the head lights! Mine are of a rectangular shape. One side has sharp angles and the other is curved.
#15 Old 08-29-2012
Heres mine (: Looks a wee bit different!
#16 Old 08-29-2012
Indeed! Well great to know what to expect! Thanks for pics!
#17 Old 08-30-2012
No problem! (: anytime!
#18 Old 01-16-2014
Vehicle: 2000 slk230
Other Toys: Motorcycle & Miata
reply
That Help a lot thanks for the pic
Richard
JaysonM likes this.
r&kslk230 is offline
#19 Old 05-09-2017
Vehicle: 1998 Mercedes Benz SLK230
Are both belts the same or do I have to get two different belts
Mrots3 is offline
#20 Old 05-09-2017
who are you asking?
thread s 3 years old
use the 'quote' button at the bottom of any post oyu wish to reply to, ask a question of, or reference
Thinking of installing Tuning chip on SLK 230 R170 TimPonken Performance MODS for the R170 7 12-20-2013 02:05 AM
Fully Smoked LED Tail Lights for R170 (SLK 230 or 320) JaysonM General Modifications R170 18 09-04-2012 02:48 AM
Were 2 Different Auto Gearboxes made for the Pre Facelift 230 Kompressor R170? miurasv SLK R170 General Discussion 0 11-24-2008 08:07 PM
