Post Facelift SLK 230 Supercharger Oil Change - Mercedes Benz SLK Forum
 8Likes
  • 6 Post By ichris93
  • 1 Post By ichris93
  • 1 Post By beegood91
#1 Old 12-16-2015
ichris93's Avatar
Quoted: 89 Post(s)
I have been afraid to do this job for some time, but it turned out to be very easy. Just do not forget to put the belt back when you are finished.
Sorry for the poor images, my phone was in a zip lock bag to protect it.
First thing to do is remove the belt for the supercharger.
Then remove the air box. Undo the three clips on the top of the air box.
Once the top half is removed, the bottom half just pulls up and out.
Now you can pull out this little air guide.
Loosen this hose clamp and remove these two bolts.
Now there are some oil separator and crankcase ventilation hoses to remove. Be careful, I broke the crankcase ventilation hose but luckily the local dealer had them in stock.
Now the oil separator and the breather assembly connected to it can be pulled up and off. Because of the electronic butterfly valve, I just set it of to the side by the fan.
Next remove these six bolts and loosen this hose clip.
Now that part can be pulled off and removed.
Next remove these four bolts.
And the supercharger can be removed.
Tilt upside-down to remove all the oil.
Installation is reverse and I used blue loctite on all the bolts.
Refill oil while it is back on the car until overflows.
Do not forget the hoses and belt during reinstallation!
Good luck!
Chris
ichris93 is offline
The Following 5 Users Say Thank You to ichris93 For This Useful Post:
#2 Old 12-16-2015
Quoted: 6496 Post(s)
Great job Chris! Was that on your car or your dad's?
#3 Old 12-16-2015
ichris93's Avatar
Quoted: 89 Post(s)
Thank you!
This was on my girl. I've been spending so much time on his lately, I had to find something to do to mine after a wash.
ichris93 is offline
#4 Old 01-15-2016
Vehicle: SLK 230K 2000
Thank you for your helpful post ;o)
ichris93 likes this.
beegood91 is offline
#5 Old 01-15-2016
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
#6 Old 01-18-2016
Vehicle: 2001 SLK 200 Kompressor
Quoted: 20 Post(s)
Originally Posted by ichris93 View Post
Thank you!
Hi Chris, thanks for the really detailed post. What oil did you use for the supercharger? Also did you just pour the oil out of the drain/fill plug when it was out of the car? And lastly did you notice any difference in the car for changing the oil?? Sorry for all the questions haha! I'm looking to do it on mine, all other posts have made it out to be much more difficult to remove the supercharger though!
chas000 is offline
#7 Old 01-18-2016
ichris93's Avatar
Quoted: 89 Post(s)
You're welcome.
ACDelco supercharger oil.
Yes. I poured it out and tried to suck it out when it was off the car. Not sure if you can really get it all.
Not sure if there was any difference. I did not drive the car for about two weeks after I changed the fluid.
ichris93 is offline
#8 Old 06-25-2019
Vehicle: 2003 Amber Red Metallic SLK230 Auto
Thank you ichris93
your post is inspirational. I also need to get this done. You have answered all my fears of taking on this task.
Thank you again
p { margin-bottom: 0.1in; line-height: 120%; }
Kim Baril is offline
SLK 200 M271 Kompressor Oil Change WilsonTHarv SLK R171 General Discussion 2 05-05-2013 09:07 AM
1999 SLK 230 - burning oil MB-Geek General Discussion 2 04-09-2012 09:02 AM
Where to take an SLK for an Oil Change?? dukesup1978 SLK R172 General Discussion 4 03-07-2010 07:45 AM
