Front oil seal - Mercedes Benz SLK Forum
 8Likes
  • 3 Post By Livefreeordie
  • 1 Post By JaysonM
  • 4 Post By ITAdrian
#1 Old 06-23-2012
Front oil seal
Well i finally got around to changing the front oil seal. Here are a couple of pictures of the old/new seal. Overall the job was simple, the hardest part was removing the crank pulley and the belts.
jbanks15, Gregg and ajberrow like this.
The Following 6 Users Say Thank You to Livefreeordie For This Useful Post:
#2 Old 09-02-2012
Livefreeordie,
Do you have the part number for this seal? And what are the symptoms indicating that it needs to be replaced?
#3 Old 09-03-2012
Sorry i do not have the part number. I figured it was the seal after cleaning the oil pan and making sure all the pan bolts were nice and snug. What i noticed was one very small stream of oil making its way down the front of the pan directly behind the crank pulley. At this point i was either the oil pan gasket or the chain case seal, i pulled the crank pulley and got lucky when i saw it was the seal.
#4 Old 09-05-2012
Alright, I'll check mine when I get to change my oil =) Just want to know what to expect )
Bradley61496 likes this.
#5 Old 09-14-2012
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
Engine looks clean inside (:
Bradley61496 is offline
#6 Old 09-14-2012
Part number 1209970346 $11.50 had my parts booklet next to me (: Number 3
The Following 3 Users Say Thank You to Bradley61496 For This Useful Post:
#7 Old 05-29-2013
Question Crankshaft seal
Hi
In what way do you "hold back" the crankshaft when unscrewing the bolt?
Is the treads left or wrigth?
Blarsson,SLK 2.3-2000 Mod.
Blarsson is offline
#8 Old 05-29-2013
Quoted: 6490 Post(s)
Blarsson,
Want to post a picture? Start a new thread or make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
#9 Old 05-29-2013
Originally Posted by Blarsson View Post
Hi
Welcome from New Hampshire.
I used a pry bar to hold the crank pulley in place while turning the large nut counter clock wise. If you look at the pulley there are slots in the back, slide the bar through the slot and hold against the block. This will take a few tries before you find a good secure spot that will hold without breaking anything.
#10 Old 06-07-2013
Vehicle: SLK AMG 230 1999
Could you tell me if you found oil spot on the floor when the car was turned off (after 1 day or so) ? I'm pretty sure I have the same problem.
bars is offline
#11 Old 12-10-2013
Vehicle: 2000 SLK 230 Sport
Other Toys: Yes (cars, bike)
2000 SLK 230 Crank seal replacement with details
In addition to the nice write up of this thread I would like to add some helpful hints and photos to make things even easier.
The bolt is 27 mm; it comes of best using an impact wrench (air or power - I have both but I started loving my battery powered better).
Extracting the balancer is very easy using an extraction tool as shown in my photo.
For the final torque adjustment, there are a couple of ways to go:
You could take the car in to your MB dealership and ask them to do the torque adjustment (they do that for free in less than two min. at our MB), you could do the pry bar against a spot on the engine method, or you could build yourself a tool to keep, out of a 2" steel pipe. I will not exclude the purchase of such tool .
You will get to a dealership (or any shop) with the bolt tightened with the impact wrench with no problem.
Also the easiest way to "build" a tensioner tool is to place a ratcheting 8 mm wrench with the open end into a 21 mm socket, position it using a wine cork (cut) and securing with some duct tape. (Photo)
I will show photos of the engine with the old seal on only to show how dirt builds up. It is very important to clean the engine BEFORE removing the old seal!!! Please secure the opening and clean the engine carefully. I use GUNK - Original engine degreaser after that rinse with water, remove the old seal and go ahead installing the new seal. Please be very careful when installing the new seal since it is very tight (doing something wrong at this point will bring you back where you were before starting the job (will leak!!!). Use a rubber hammer and a piece of flat wood to bring the new seal to position. Clean the balancer before installing it.
I hope people will find my 2 c useful.
jbanks15, JaysonM, BluBenz and 1 others like this.
ITAdrian is offline
The Following 7 Users Say Thank You to ITAdrian For This Useful Post:
#12 Old 12-10-2013
Nice job, the extra pictures are a big help.
#13 Old 12-17-2015
ichris93's Avatar
Quoted: 89 Post(s)
Do you know the torque spec on the bolt and if it supposed to be replaced?
ichris93 is offline
#14 Old 12-26-2015
SLK World Junior Member
Vehicle: SLK 200 Kompressor (R170)
Hi there!
I have the same problem and I'm thinking to take my car to the MB dealership.
I really would like to do it but I'm a bit scared of getting in something I can not handle. Do you know of any step by step tutorial?
Many thanks and best regards from Brussels.
Ciao
Cristiano G
cristiano78 is offline
#15 Old 12-28-2015
I don't know of any step by step instructions out there, I'm sure if someone knows of any they will most likely post it for you.
Front side markers, remove/replace procedure etyu SLK R171 Class DIY 90 05-18-2017 03:23 PM
R170 supercharger oil seal replacement cossiroger SLK R170 General Discussion 6 11-08-2010 04:20 PM
