R170 Hydraulic Cylinder Install Video - Mercedes Benz SLK Forum
 12Likes
  • 7 Post By houllahan
  • 1 Post By Lackew
  • 1 Post By houllahan
  • 1 Post By Lackew
  • 1 Post By Lackew
#1 Old 08-13-2015
houllahan's Avatar
Vehicle: 1999 230 SLK
Other Toys: 94 Volvo 850R Wagon 19T Turbo ARD Tune IPD Suspension.
I have been meaning to shoot some more shots and add titles to clean this video up but I have been busy with work so i decided to put up a V1.0 video for now.
houllahan is offline
The Following 5 Users Say Thank You to houllahan For This Useful Post:
#2 Old 09-24-2016
Lackew's Avatar
Vehicle: 2003 SLK320 CABRIO SCHWARZ/BALTIC BLACK/EUCALYPTUS/SIAM
Other Toys: Regal Sebring Cuddy Cabin
Quoted: 29 Post(s)
I guess I should make a video of how to remove the cable lines from the pump since I cannot find one anywhere online! I will do this once I figure out how to remove them!
Idiot101 likes this.
Lackew is offline
#3 Old 09-26-2016
houllahan's Avatar
I think there was a segment in the video about the hydraulic lines and removing them from the pump, the guys at Top Hydraulics did mention that there is a stamped metal clip which is locked in place by a blue plastic retainer. You can remove the retainer and just turn the stamped metal clip and the lines can be removed, so fairly simple to do. I ended up removing the hex nut in the middle and removing the metal clip in the video which was more effort than is actually required.
I assume that is what you are referring to? The hydraulic lines?
I have not had the extra time to update the video with some of the notes Top Hydraulics gave me as to doing the job, I plan on doing some work on my R170 soon, bigger brakes and the ASP pulley etc. and I will try to shoot some addendum video about the hydraulic replacements for the vario top.
The video has played more than 500 times as of today so hopefully it has helped a few people out.
Lackew likes this.
#4 Old 09-26-2016
Lackew's Avatar
Quoted: 29 Post(s)
Thumbs up Stilettos to OverAlls
I am certain your video has helped 100s including myself when it comes time to replace the top latch. I was merely frustrated by trying to unscrew the couplings for a couple of hours, DUH . I watched dozens of videos on removals & rebuilds but none addressed removing the cable from the pump. I follow instructions pretty good & think this would help other women who may want to try a DYI. So if there is one that addresses the cables & pump it would have spared my entire Saturday afternoon! I spent 3 hrs on videos, 2 hours on cables then 2 minutes removing them AFTER I put on my hubbys glasses to see the plate!
houllahan likes this.
Lackew is offline
#5 Old 09-26-2016
houllahan's Avatar
I am glad the video helped out!
I am going to get around to updating it with some areas that need clarification and I will put the pump line removal on the list!
Lackew likes this.
#6 Old 09-26-2016
Lackew's Avatar
Quoted: 29 Post(s)
Let me know if I can be of assistance altho I am clueless to what, perhaps a rough translation from a mechanic to the mechanically challenged or a printable direction in a large font for those like myself who is too stuburn to wear her granny glasses,
Past60 likes this.
Lackew is offline
#7 Old 12-06-2016
AlecG's Avatar
Vehicle: Black 2001 SLK 320 (R170)
Other Toys: Jeep Wrangler 2002
Houllahan,
Awesome job recording your job. It is very helpful to see what the job entails. I do have a few questions. If only my front roof actuator is leaking - can i only repair the one. How do I determine if it is the locking actuator or the other two. Should i replace all three.
Another Question: Is drilling the hole so I can get the clip out? Can anyone provide details or video on removing the clips. Seems like a difficult process.
Thank you for the help,
alec
AlecG is offline
#8 Old 12-07-2016
houllahan's Avatar
You could certainly replace - repair only the front locking cylinder. In fact on my car it was the only one leaking but I chose to replace all five.
There is no need to drill anything on the car to remove and replace any of the hydraulic cylinders.
There are two ways to do this job, the way I chose was to buy a set of replacement cylinders from Top Hydraulics and just replace all five.
You can also get a rebuild kit and that entails drilling out the clips or pins which hold the cylinders together so you can replace the seals. I chose to get rebuilt cylinders from a top rated rebuilding shop because they were recommended and I had a limited time to do the job and did not want to run into an issue with a cylinder with the car apart.
As far as removing other Cir-Clips which hold the pins on the ends of the cylinders that is fairly straight forward, I usually use a fine flat head screwdriver and apply a magnet to the Cir-Clip to keep it from getting lost, i.e. down the vent or under the seats.
-Rob-
#9 Old 12-07-2016
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Our NC/SC SLK Group had a met where we replaced the "O" ring in the top cylinder on several 170's one Saturday. I would suggest to do the "O" ring replacement over removing the cylinder and lines. If you are a DIY it is a simple replacement. There are many post of do this. Generally it is only the front top that goes bad.
Gbarringer100 is offline
Smartphone Integration with COMAND NTG1 Dimi190E SLK R171 General Discussion 230 04-22-2019 12:56 PM
vario roof hydraulic cylinder repair twestenberger SLK R170 General Discussion 1 07-26-2012 06:37 AM
r170 top cylinder replacement help!! murat orhan SLK R170 General Discussion 5 03-09-2012 11:21 AM
98 slk leaky power top hydraulic cylinder repair mike jackson SLK R170 General Discussion 4 10-23-2011 09:32 PM
Noise/rattle from excessive hydraulic cylinder play? hummingslk SLK R171 General Discussion 4 09-27-2011 06:59 PM
