Window Stop Repair - Mercedes Benz SLK Forum
  • 2 Post By El_Toro_33809
#1 Old 07-27-2015
El_Toro_33809's Avatar
Quoted: 86 Post(s)
Window Stop Repair
I've seen a number of threads about this topic. When we got our SLK the window would go up too far. Through this forum I learned about the "L" bracket that can come unglued from the window. Low and behold, after removing the door card and the speaker, I found the stop loose at the bottom of the door. Working through the speaker hole, I cleaned off the old glue in the window and then did the same to the bracket. I got some epoxy, put the bracket back in place, then clamped it until the epoxy cured. Looked like I had it fixed, but within a week, the epoxy failed and I had to start over again.
There is a matching bracket on the outside of the glass that I suppose acts as a support to the inside bracket (they don't overlap completely due to the glass being in between and the brackets being identical. A better design would be to have the bottom of the outside "L" be a little longer). The bottom of the "L" has a small hole in each of them. Not sure what the purpose was, but I "repurposed" them by puttIng a small screw in place to act as a backup to the glue I did have to slightly elongate the hole one the bracket to get them to line up.
I did this all with the window completely lowered in the door. Well yesterday I had the glass removed and it gave me the perfect opportunity do document it in photos.
Hope this helps someone sometime.
jbanks15 and ichris93 like this.
El_Toro_33809 is offline
#2 Old 09-06-2015
Vehicle: 1998 230 SLK and 2008 E320 Bluetech
Other Toys: Bike, many past boats, four airplanes; now cars are main interest.
Yes, this is a real pain. The dealer wanted $1500 to fix the right side. I did it myself but it was a bear to do and the fix lasted 3 months. If epoxy and roughing the glass won't do it, it seems hopeless. How big a job is it to get a new window with the metal brackets already on and replace the entire window? It also looks to be a monster job, maybe better to just get a whole door from a salvage yard. Any help here?
John
Ellisj is offline
Side window question Dr Tomato SLK R170 General Discussion 13 06-22-2017 02:23 PM
Window problem it only goes one way and the solution Vilse.se SLK R170 General Discussion 4 06-21-2017 12:13 PM
stop signs, stop lines & cameras bobl Off Topic 9 09-17-2013 11:17 PM
Window Stop ormesby Where to get R170 SLK Items 1 06-04-2010 05:58 PM
