DIY: Custom trunk inserts - Mercedes Benz SLK Forum
  • 1 Post By CaliCoop
#1 Old 02-01-2011
CaliCoop's Avatar
Vehicle: 2008 SLK 280
This cost under $30.00 to do.
Items needed for install:
Pencil
Paper
Scissors
Thin cardboard
Painters Tape
Hot melt glue gun
Fabric of choice....1/2 yard of fabric 1/2 yard of 1/2 inch batten or filler
It uses about 1/4 of a yard but you have extra for mistakes or redoing
another trunk. Just use Faux Fabric. Its cheaper.
Faux Leather, Suede, Emu, Alantra, ect from your fabric store.
Plan a couple of hours
Tape paper over the large and small areas you want to make inserts for.
Using the side of the pencil lead, trace the lip of the trunk lightly going back and forth. You will see the line form in the paper. Dont press too hard.
Carefully remove the paper and cut out the traced area on the line and trace onto the thin cardboard. On one side of the paper mark it Right and on the other side mark it left. This way you only have to trace 1 small and 1 large.
Next you need to cut out the template. When you do this, you need to cut the cardboard 1/4" larger. This is what holds it in place in the trunk.
Trace the batten using the paper pattern you made and cut it out.
Apply hot melt glue to the thin cardboard and then put the filler in place and let it cool. This is what yours should look like. You can use 2 layers if you want a puffy look if you are using a thin fabric.
Using the template, trace on the back side of the fabric. Trim fabric leaving a 1/4" surplus all around.
Turn the cardboard facing up with the batting. To get a good seal, apply the hot melt glue to the middle of the 1/4" surplus with a single bead of glue. Quickly put the fabric over the batting and press the fabric into the glue all the way around. Should look like a Calzone. LOL
Now trim off the excess fabric back to the cardboard.
Now your ready for the install.
Take the insert and cup it a little bit. Slip the insert into the recessed area starting with the small corners and slowly work your way around until the insert pops in. Keep watching as you go. You might have to trim a little as you go so it fits. Take your time here, don't cut too much or it won't cover the entire hole when it pops into place.
I used faux Emu like the Spyker autos used. Its really unique.
The end product looks great!!! Enjoy
Please post pics of your custom trunk inserts
Thank you....Jerry
JaysonM likes this.
CaliCoop is offline
#2 Old 02-02-2011
Trunk/Boot Lid inner foam inserts
I did something similar quite a while ago in terms of getting the pattern, but did not post as I didn't think it was of interest to others. I also covered the round hole that houses the satellite radio antenna with the same material.
I used 1/2-inch thick (3/4-inch will work also) flat packing urethane foam sheets (grey colour) found in packing fruits or electronic parts and equipment. I used a heated hobby knife (soldering iron with a special attachment for blade #11 hobby knife) to effect a clean cut on the foam. The cut foam is then inserted unto the triangular and round spaces. The grey foam makes it look OEM.
Hope the photos help:
etyu is online now
#3 Old 02-02-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
So I just couldn't match the Green, but you get the idea!
UK-C200 is offline
#4 Old 02-02-2011
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by uk-c200 View Post
so i just couldn't match the green, but you get the idea!
Nor could I !! . . . . . .
Woolly is offline
#5 Old 02-04-2011
Materials and Tools photo, pdf file of pattern
To better illustrate the trunk lid inner lining foam inserts, I've included a photo of the 0.5-inch thick foam sheet , heated knife to effect a clean cut, and the pattern; green urethane foam may be available from the local grocer
Originally Posted by UK-C200 View Post
I'll see if I can convince Louise to plot out some templates and post 'em up.
I've also attached the scanned pattern for the 2 triangles in pdf format (print at 100%) to save members some time (just flip the pattern to create the mirror-image for the other side). The large triangle is split into two scanned images with 3 lines drawn as an aid in aligning the pattern; these two pieces can then be taped together. The pattern takes into account (i.e., included) the 1-cm lip of the areas-of-interest.
If one is following CaliCoop's method, then allow 1-cm less space all-around for the inner batten/filling.
Some minor trimming or fine-tuning may be required in the final fitting, as stated by CaliCoop.
etyu is online now
DIY : R171 Trunk Struts Replacement Caboz SLK R171 Class DIY 178 11-02-2018 02:53 PM
DIY: Custom trunk inserts CaliCoop SLK R171 Class DIY 26 05-04-2018 01:24 AM
Trunk Rattle Solution! B55 SLK R171 General Discussion 100 02-19-2017 07:54 AM
Trunk Liner Sensor Location gpp SLK R171 General Discussion 10 08-10-2010 10:37 PM
Need Help - Trunk full of water mcat SLK R171 General Discussion 31 07-20-2006 08:11 PM
