How to strengthen signal with the R170 Antenna - Mercedes Benz SLK Forum
  • 1 Post By dsb
#1 Old 12-05-2007
dsb
Vehicle: '06 slk55
What:
How to strengthen signal reception with the R170 Antenna
Who:
For those of us that can't stand the look of the R171 long whip antenna but do not wish to sacrifice a ton of reception using just the R170 short antenna.
Why:
Why not? I for sure hate being limited to a few feet when I want to lock/unlock my doors. Plus, I spent good money on a Roof Module. From 50+ feet away, I want to walk to my car all the while it's roof is being lowered. By the time I get there, it's ready.
When:
How about now? It only takes about 20 minutes.
Disclaimer:
I am not an electrician and realize there's probably a better way to do this mod. Then again, this worked for me and that's what counts. Right? I was introduced to this mod from another member, (thanks Ikarus), and decided to put a quick tutorial together. I can say that I've already noticed a vast improvement in signal strength. Please note, I have only tested the lock/unlock range. I really don't listen to radio but I'm sure that signal has improved as well. What was the difference? Well, prior to the mod, I was able to lock/unlock at a maximum of 25 feet. That has grown to 120ft! So, in my experience that's 5 times better!
Tools required:
-Soldier gun and solder (RadioShack Model: 64-2802 $7.99)
-22 gauge wire (RadioShack Model: 278-1224 $5.99)
-R170 Antenna (MB part#A170 820 06 75 approx $70)
-Allen Wrench
-Pen
-Ruler
-Razor Blade
Steps
1) Assuming you already have the R170 antenna installed, remove the antenna's upper section. This upper section is hollow plastic and is simply pulled off the base. I found that it's easier to leave the lower section screwed onto the vehicle. Pry the upper section off while slightly bending it. It should come off fairly easy.
2) Remove the lower section using the supplied Antenna 'Gear'
3) Take two strands of wire and begin wrapping them in a spiral around a small pen or allen wrench. The top section can be folded over. As you proceed, switch to a thicker pen. I used my child's paintbrush. The idea is to have a wire spiral that fits into the antenna cavity. I was able to utilize about 15" of length.
4) Next, strip the ends of the wire. Also, strip a small section of the antenna. Solder one piece to the inner section of the antenna and the other to the lower section.
5) Carefully fit the spiral wire onto the base of the antenna. Next, snap the Antenna's upper section back into place.
6) Reattach the antenna to your vehicle. Again, use the 'gear' to get a tight fit.
That's it! Test it out and see the results for yourself. So far, I am happy with the improvement. I will conduct so more tests if I get the urge. For now, I am done. My biggest gripe with the small R170 antenna is now gone.
JaysonM likes this.
dsb is offline
The Following User Says Thank You to dsb For This Useful Post:
#2 Old 02-12-2013
MAR84's Avatar
Vehicle: 2003 SLK 230 Komp. R170
Other Toys: Air Freshener
Im doing TONS of changes to my car and I think this is an awesome one, have you done more test to this? Or have you figured out another solution?
MAR84 is offline
#3 Old 02-12-2013
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
If you search the site you will find another thread that is quite long with tons of research on wire sizes, lengths, etc. https://www.slkworld.com/diy-section/...0-antenna.html
I did the mod and while it looked a lot better on my R171, the loss in radio reception was too serious for me to keep, as I drive 35 miles a day to work and I lost one of my favorite radio stations half way there. That said, the reception for my Key fob was a lot better.
It's a lot of fun to do - learning how to solder well , etc.
Best Wishes,
Gene
REB_TN_06 is offline
#4 Old 02-12-2013
Quoted: 6568 Post(s)
mar84, you probably figured this out already, but the original post was over 5 years ago!
#5 Old 02-12-2013
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
Five years old but still good info on how to mod the antenna. SLKSTORE use to sell them with the mod done. Last time I checked they no longer do the mod and you have to DIY now.
Gbarringer100 is offline
#6 Old 02-12-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Best Wishes,
I noticed in your garage photos you have the whip aerial ! If you're still using it you might want to consider one of these , looks great with no loss of signal !!
http://www.ebay.co.uk/itm/2611440121...84.m1438.l2648
curro101 is offline
hidden antenna? oilmonstr General Modifications R171 17 01-29-2010 06:22 AM
My R170 Antenna Installation Impressions garylight General Modifications R171 2 04-10-2009 04:24 PM
R170 Antenna Mod??? WhyBeGood General Discussion 8 02-09-2009 07:44 PM
