SLK230 Roof Hydraulic Pistion Replacement - Mercedes Benz SLK Forum
#1 Old 12-08-2009
Vehicle: 2009 280SLK
Other Toys: Jeep Wrangler Rubicon
I had recently sold 1998 SLK230 to a good friend of mine, Chuck. He recently repaired it himself, and when I mentioned I wanted to publish his work in the forum he was nice enough to tear down again just to take pictures... thanks to Chuck, I'm posting this article for all to benefit...
Chuck:
I changed my front locking cylinder on my 1989 Mercedes 230 SLK for under $500 with no special tools.
Start early as this can take several hours to complete this task.
Step 1: Retract the hardtop half way.
Remove the headliner: 3 Philips screws in the front and 3 screws on each side.
Step 2: remove the cylinder bracket -- 3 star screws hold the bracket and 2 clamp ring and rods hold the cylinder to the bracket.
thunderstrike is offline
#2 Old 12-08-2009
Step 5: The hydraulic lines do not com off the cylinder; you have to disconnect the lines from the pump located in the trunk. There are several clips and clamps that have to be undone to remove the line.
Step 6: To get to the pump you must open the trunk like the top is to be lowered. Then you must remove the safety lid, the right rear wheel cover and metal bracket over the pump.
#3 Old 12-08-2009
Step 7: Remove the lines from the pump by cutting the black tie and twist the unlock level.
Caution: watch that all lines do not pop out.
#4 Old 12-08-2009
This is where you will need to fill hydraulic fluid.
Replace cylinder in reverse order... this completes the job.
The headliner was stained and had to be reupholstered with new material. A local shop did it for $50.
#5 Old 02-29-2012
Vehicle: Red 2001 SLK 230
Other Toys: Sailboat
What about the rear pistons ? at the side of the trunk, by the antenna ...
frankycordero is offline
SLK 230 Hydraulic Roof actuator repair Thud57 SLK R170 General Discussion 347 06-21-2019 06:16 AM
SLK230 Roof Hydraulic Pistion Replacement thunderstrike SLK R170 class DIY 19 09-18-2015 07:35 PM
SLK230 Roof Does Not Open Properly, zero dollar fix. Peter J SLK R170 General Discussion 4 05-10-2011 05:43 PM
SLK230 roof issue Thud57 SLK R170 General Discussion 4 08-30-2009 12:06 PM
