Oil separator change with all hoses (r170 2001) - Mercedes Benz SLK Forum
  • 1 Post By Kolandr
#1 Old 11-05-2011
Vehicle: 2001 SLK 200
Post Oil separator change with all hoses (r170 2001)
It's 111 EVO engine.
If u see this picture under the hood (oil stains) and mileage more than 60.000 mi - u need to replace oil separator and O-ring on oil cover.
All parts that u need:
A1110940283 - oil separator
A1110182682
A1110182882 - hoses
A1110183282
A1110180080 - O-ring
You will need the following tools:
Specific tool there is only one - Torx E10.
Remove airfilter cover and unscrew 2 torx on separator:
loosen the screw:
Detach all hoses from separator: (at this pic we see why you need to change the hose - it's already not a rubber, and it breaks)
Detach oil separator with butterfly valve:
Detach butterfly valve and O-ring (!) - it should be moved to a new separator.
Install all parts in reverse order. Use silicone spray for rubber parts, it helps to attach tubes to the separator.
Replace O-ring on oil cover.
JaysonM likes this.
Kolandr is offline
The Following 5 Users Say Thank You to Kolandr For This Useful Post:
#2 Old 08-25-2015
Vehicle: 2003 SLK230 K R170
Hi! great info on here. I need to get my oil separator as well as my MAF sensor replaced on my 03' r170. I'm curious, how much did you pay for the oil separator parts?
OGdivina is offline
#3 Old 08-25-2015
Quoted: 6479 Post(s)
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
#4 Old 10-25-2015
Vehicle: 2003 SLK 230
You don't need to buy a new oil separator, just remove it and clean it with cleaner or detergent that will not melt plastic.
Also, the elbow connected to the valve cover comes off with the unit. Do not try to pry it off by itself; it will break. Carefully remove it with the entire oil separator.
springsman is offline
Tags
oil leak, oil separator
oroboras
R170 supercharger oil seal replacement cossiroger SLK R170 General Discussion 6 11-08-2010 04:20 PM
Idiot oil light for 2001 320? garagegods SLK R170 General Discussion 7 11-11-2009 04:36 PM
Blackstone Lab oil report - 2005 SLK350 fgwinn SLK R171 General Discussion 12 08-10-2009 06:11 PM
