Differential fluid change - Mercedes Benz SLK Forum
#1 Old 10-12-2011
Thanks to str8pryd for this great pdf
#2 Old 04-17-2012
Vehicle: 1999 Slk230 original owner, 105k miles
Just an FYI on gear oils and my experience 99 SLK
Just wanted to follow up and let folks know what I experienced with my 99 SLK differential fluid change. I used Royal Purple and after 3-4 days I was getting leaks around the seals as I drove. Checked the fill and drain plugs as thought maybe I had not done a good job putting them back. No - they were all tight.
So I called the parts guy at the local dealership and asked him if they had the Mercedes gear lube for a 99 SLK differential. He said even they don't use Mercedes fluid for differentials, they use NAPA part SL2472, STA - LUBE NAPA AUTO PARTS which is a 80w-90w GL-5 gear lube that cost about $11.00 per qt (after my Vet discount).
Four days of driving with the NAPA STA-LUBE and no leaks - hard to believe my SLK did not like drinking Royal Purple.
I also had this happen on my 2001 Harley, used Red Line Gear oil and started to get leaks around the gaskets after 3-4 days - changed back to regular gear oil and no leaks.
Anyways, your milage my vary and this is just my experience - you should always use authorized Mercedes products that cost lots of money to avoid any issues - this is not advise (legal disclaimer).
usmc_guy is offline
#3 Old 06-15-2014
Post
Another link I've found:
Same procedure and idea:
http://www.pelicanparts.com/techarti...Oil_Change.htm
Automatic Transmission Fluid Change midget fidger SLK R171 General Discussion 5 05-01-2018 02:39 AM
Fluid change - whats best fluffy01016 SLK R170 General Discussion 8 10-11-2011 03:53 AM
7sp AT fluid change... Galo SLK R171 Class DIY 4 05-28-2011 02:03 PM
Change Automatic Transmission Fluid? ClemsonB General Discussion 5 01-22-2011 02:19 PM
NEED HELP! Transmisson fluid change sikslk99 SLK R171 General Discussion 6 04-18-2009 10:07 AM
