Mercedes Benz SLK 230 Head Gasket Remove & Replace - Mercedes Benz SLK Forum
 4Likes
  • 3 Post By Livefreeordie
  • 1 Post By Luis Alvarez
#1 Old 09-25-2011
Thanks to Ben Kokes for this great DIY
http://www.kokes.net/slk/Engine_head...ead_remove.htm
#2 Old 09-25-2011
Wow, what a great write-up! I certain do not hope that I will need to do this job anytime soon, but if I do, there will be a print out of this diy right next to me.
Raindog is offline
#3 Old 09-25-2011
Yup, i have the same feeling. Ben did a great job with this.
#4 Old 07-07-2015
Vehicle: 1998 230 slk
Head gasket replacement
Thanks Ben for a great work guide and thanks admin for including it on this site. Just a couple of things that I think might be helpful to others.
Firstly = Putting back together the intake camshaft gear proved to be difficult because it just would not line up correctly. The front part of the gear would line up but the notch on the back plate would not line up with where it needed to be. Then I realised that the internal, centre section of the gear twists and can be pushed back into the gear housing itself and then line up is easy. I know that sounds complicated but anyone putting this gear back together would understand what I mean.
Secondly = Ken did a great job with the chain tensioner explanation however it still proved very difficult to get into place. On another site I found a tip to mount the outer section of the chain tensioner first and then fit the inner section later. This proved to be much easier, still awkward, but easier. Thanks again Ken, it was like having a big brother beside me telling me what to do. Martin
Martin Miles is offline
#5 Old 01-30-2017
Vehicle: 2003 SLK230 Kompressor Black
Blown Head Gasket
Thanks Ben for a great DIY with great photos.
I have rebuilt a 57 Stude Hawk, 73 F250, 65 Buick, 04 Escape but am just too old now to tackle the hotrod 03 SLK 230.
Enjoyed the heck out of reading your DIY and will now have enough knowledge to not get BS'd by Mercedes who is doing the work this time. They estimate $2800 which is high as hell
Fasterhorses is offline
#6 Old 01-30-2017
1978L82's Avatar
Vehicle: 1998 MB SLK230
Quoted: 111 Post(s)
I too must say thanks as I used his procedure to change the head gasket on my car. Something else to note is that you need to shine a light into the head bolts to make sure they are not full of gunk. If you do not, the 12star bit will not sit completely inside and strip the bolt. Then you'll have to drill them out. Luckily they are not too hard to drill out .
1978L82 is offline
#7 Old 06-17-2017
Vehicle: 1999 SLK 230 2.3 SC Manual
Other Toys: Eclass 320 i6
Great read ! There is just one problem hopefully someone can help me out as I'm going to take her apart today, what are the special tools we need to do this job and what are the specs for torque on bolts and do we need to use some sort of silicon on the head gasket? Basically just the specs and special instructions or a link to a shop manual would be great, thanks guys!
LIL DON SLK likes this.
Luis Alvarez is offline
#8 Old 06-17-2017
Quoted: 6496 Post(s)
First please update your location and vehicle (Put Looking!)(year?: 1996-2017, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#9 Old 05-30-2018
Vehicle: 2000 slk 230
Site Suspended - This site has stepped out for a bit
Link not working
davidmeloni is offline
#10 Old 05-30-2018
Originally Posted by davidmeloni View Post
Link not working
True
thread is also 7 years old
#11 Old 05-30-2018
https://www.slkworld.com/slk-r170-cla...ets-w-pic.html
2008 Mercedes SLK Accessory Lineup Announced alroumi SLK R171 General Discussion 7 02-20-2008 06:26 AM
Pleasanton: Mercedes Benz SLK roadster owners meet easty MB Events 0 08-11-2006 10:11 AM
