DIY: Replacing Trunk Limit Switch - Mercedes Benz SLK Forum
#1 Old 04-26-2015
Vehicle: 2004 SLK 32 AMG - Silver
So a few weeks ago my roof wouldn't come up. I thought it was the cylinders and I prepared myself for pain.
Something odd though, everything seemed to function OK, the trunk would reverse open and then the whole process would freeze. The roof would sometimes go up if I let go of the button and tried again, or if I jiggled the trunk.
Low and behold, the trunk limiter switch. It's a small switch just behind the tail light and under the plastic trunk cladding on the passenger side of the trunk.
Pelican parts and most DIY will tell you that you need to remove the entire trunk liner. But I'm generally very lazy so I started looking at options. If you look at the part, there aren't any places for screws which means I wouldn't have to shove screws into tight places. Good for me. Also, the back of the part looked like it slid into place and one of the little clips looked like a button. Also good for me.
So I pulled the plastic bolt out of the top side of the passenger side trunk liner, and pulled out the panel behind the CD changer to have a look. All you do is press the back "button" and slide the sensor downwards. I pulled it out from behind the CD changer, unplugged it from the power cable, plugged the new one back in, and slid it back into place.
Easy peasy!
Top going up and down without a hitch so far, so hopefully that solves all my problems.
Since the only DIY I saw advocated removing the entire trunk liner, I figured I'd post here.
Cheers!
Kyngfish is offline
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Kishkumen
R171 : DIY : How To replace steering wheel switch covers brother123 SLK R171 Class DIY 17 04-05-2017 12:05 AM
Top stalls out after trunk is open PsyDoc SLK R170 General Discussion 18 10-23-2013 10:53 PM
replacing marker bulb on 2006 - any DIY outthere? Daniel Florida SLK R171 General Discussion 8 04-28-2013 09:26 PM
Trunk Liner Sensor Location gpp SLK R171 General Discussion 10 08-10-2010 10:37 PM
How to clean corrosion from limit switch [email protected] SLK R170 class DIY 2 04-11-2009 12:43 PM
