Slk 230 cabin filter replacement - Mercedes Benz SLK Forum
 9Likes
  • 6 Post By foreign freak
  • 2 Post By Elfrank
  • 1 Post By jbanks15
#1 Old 07-03-2011
Vehicle: 2004 Slk 230
SLK 230 2004
Was getting funny odor in cabin. Replaced filter and smell vanished.
The replacement is similar to this helpful post for the 350, but different enough to make another post.
I replaced filter with this Bosch Charcoal Air filter
Tools needed:
Phillips screwdriver
Instructions:
1. Go to passenger side
2. Locate the back panel with several holes
3. Locate and unscrew the right screw
4. Then the left...
5. Gently let the front panel swing down
Locate the cabin filter cover on the left. (it is a slim rectangle closest to center console) Slide the front clip off towards you and the back clip off away from you. Be sure to hold the cover when removing the 2nd clip.
Remove cover and gently guide/ pull the filter out.
Remove air filter noting its position. Replace with compatible filter
Installation is reverse of removal.
Enjoy.
Feel free to ask questions or give feedback.
foreign freak is offline
The Following 9 Users Say Thank You to foreign freak For This Useful Post:
#2 Old 07-04-2011
Vehicle: 2001 Silver SLK230
Chats: 2
Replaced the filter several months ago as well and it sure reduced the bad smells!
GusSLK is offline
#3 Old 07-15-2011
Vehicle: Slk230 2001, Fiermist red and two tone beige and black interior
Other Toys: None yet
this rocks cause my cabin smells like L.A. and sweat so I gotta change this up... Thanks for the post this rocks. LMAO at the dealer here in l.a. they wanted 200 to do this!
ultrabri is offline
#4 Old 08-12-2011
Firm's Avatar
I just did this last night, twice actually: I bought a new active charcoal filter from autopartsway.com (excellent experience btw) for mine. So I pulled mine out and it actually looked pretty clean! I put the new one in anyway, then I went over to my brothers `98 230....pulled it out and the filter came out completely filled with leaves and debris. I couldn't believe the amount of crap in there! So I put my old one in his car.
Pretty simple job, took about 20 minutes to do both cars....Wosrt part is wrestling the new filter back up into the slot.
Firm is offline
#5 Old 08-12-2011
Vehicle: 1999 slk 230
Quoted: 519 Post(s)
FF, thx a million for the post very well done easy to understand and great pics. Keep up the good work.
Berliner Heckflosse is offline
#6 Old 08-01-2012
V6SLK's Avatar
Vehicle: 2003 SLK 320 Magma Red
Other Toys: Honda Valkyrie motorcycle
The instructions were great and very helpful. To make the job a little easier I used a mirror on the passenger floorboard and a drop light. It allowed me to see and remove the two cover screws while just kneeling outside the passenger side door. Once the screws were removed I lowered the cover and unhooked it from the front of the floorboard. It came out fairly easy and gave a little more room to get the filter in and out. Space is limited and takes a little maneuvering to get the filter in. If you leave the cover hooked on you risk tearing the insulation material attached to it.
V6SLK is offline
#7 Old 08-02-2012
Thanks for the great feedback. Unfortunately I don't have this ride anymore, hence the lack of posts, but I have been shopping craigslist for my next slk.
For those who are a bit timid about fixing things yourself. I know how you feel. I started out with no experience but the ignition switch was locked. I refused to pay the $1200 the dealer wanted so this led to my first car repair. I stumbled through it (and lost the pics on my android, hence no tutorial) but after figuring it out, using the web all other repairs (horn, filter, brake light switch etc) came easily and actually were a lot of fun.
So bottom line, is if you are new and never thought of yourself as the mechanic type, just take a deep breath and realize you are not disarming a bomb. As long as you Use safety measures like disconnecting the battery and learn how to raise the vehicle using jacks/lifts etc. Otherwise, just have fun. Take your time and take pictures of every part as you remove them so you leave yourself a safety map so worst case scenario you just put the part back the way it was. You will soon realize that Once you get the first little repair done it will come naturally.
This is what I wish someone would have told me in the middle of my first repair... when I was staring at the interior completely stripped of the dashboard
The Following User Says Thank You to foreign freak For This Useful Post:
#8 Old 08-07-2012
Vehicle: 1998 SLK 230 Kompressor
Other Toys: Motorcyles
I changed the filter thanks!
DeadHead
deadhead is offline
#9 Old 03-26-2018
Vehicle: Slk 320 2003
That was very helpful for me.
Thanks a lot!
I only got my slk 320 a few days ago and
I am looking forward to start “taking care” of her ..
Elfrank is offline
#10 Old 03-26-2018
Quoted: 6490 Post(s)
Thanks a lot!
FYI
This thread is about 5 years
M4rCu5 likes this.
New SLK 230 owner here. :) Koru_Kinshi New Members Introduce Yourself Here 12 01-23-2011 12:43 PM
01 280 SLK bumper fit a 01 230 Slk? ziagroup SLK R170 General Discussion 4 07-25-2008 05:14 PM
