Brake light Switch replacement - Mercedes Benz SLK Forum
#1 Old 07-03-2011
Vehicle: 2004 Slk 230
For SLK 230 R170 chassis
Brake light switch was faulty causing back lights to burn out and weld to chassis. I saw another link on this with diagrams. Thought these color pics would make it a bit easier.
You will be replacing this:
You can buy it here.
DETACH NEGATIVE CABLE from BATTERY TERMINAL. Using 10mm socket. Wait 2-5 mins.
Step 1. Remove lower panels as described here:
Step 2. Locate brake light switch near brake pedal.
Step 3.
Detach the two wires from brake light switch (note where they were attached.)
Step 4. Press clip on brake light switch and twist out of bracket. I demonstrate motion for removal in this
. (For my fellow visual learners)
This is the metal bracket without the brake light switch. You will install the new switch back into this bracket.
Installation is reverse of removal.
Last edited by foreign freak; 07-03-2011 at 01:06 PM. Reason: Specify model & include battery detachment step
foreign freak is offline
The Following 3 Users Say Thank You to foreign freak For This Useful Post:
NoRegret4Life's KLEYMAN Flashing 3rd Brake Light Module SLKman SLK R170 General Discussion 54 11-13-2016 06:58 PM
Brake Light switch removal firecam SLK R170 class DIY 12 03-17-2016 11:40 PM
brake Bulb Replacement (Even if welded stuck) foreign freak SLK R170 class DIY 2 11-05-2011 02:11 PM
SLK 230K Third Brake light LED replacement EnthusedSLK SLK R170 General Discussion 3 12-05-2009 07:46 PM
