brake Bulb Replacement (Even if welded stuck) - Mercedes Benz SLK Forum
#1 Old 07-02-2011
Vehicle: 2004 Slk 230
For SLK 230 R170 chassis
This is a DIY for brake bulb replacement even if bulb is welded to chassis due to overheating.
My bulb housing became welded to chassis because of a faulty brake light switch which kept brake lights constantly on. Overheated and welded light housing to chassis.
Note: A.Bulb removal on left side of car requires trim
removal tool used to remove "pins" without scratching up your
plastic. Replacement of right side bulbs only requires pulling
plastic cover off (no trim tool required) and reaching up and twisting
out housing.
B. If your bulb is not stuck step 1 should be enough.
Tools used:
Pliers
Used masking tape, an old shop rag and scissors to. Cut strips of rag. Wrapped rag around pliers (pic above) to provide padding and enough grip to twist bulb housing out of chassis without cracking it.
Trim Removal tool (Autozone $10)
Bulb used: Sylvania 1156 LL
DETACH NEGATIVE CABLE from BATTERY TERMINAL. Using 10mm socket. Wait 2-5 mins.
Step 1. Left side is covered and sealed with trim "pins". Use trim removal tool to pop "pins" from plastic cover. You may need to move carpeting out of the way to get a full grip on the pins. The right side has no pins to remove. Just remove cover and reach up and twist out.
View of left side after cover is removed.
Step 2.
Pop pin from upper trim closes to light housing. This is just above the "black bristles."
This pin is just above the black bristles..
Step 3.
Pry the plastic away carefully just enough to get direct access to the bulb housing. Brake light bulb housing is the highest light. This is the view from top.
Step 4.
Reach up under the lower opening with modified pliers and reach from up top through the bristles. With both hands and pliers grip firmly and twist out. This may require some wiggling. Be careful even with padded pliers not to crack the housing when gripping.
Step 5.
When housing is removed, push and twist bulb from housing. Replace with new bulb. Installation is reverse of removal.
foreign freak is offline
The Following 3 Users Say Thank You to foreign freak For This Useful Post:
#2 Old 11-05-2011
Thanks for the useful info. Only spilled a little blood on pointy plastic parts . Had to re-seat bulb and housing after first try but everything went into place second time around. Thank you for this forum!
2004 SLK 230
Shannon is offline
#3 Old 11-05-2011
Quoted: 6490 Post(s)
Shannon,
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last.
Thank you,
Founding Member/Moderator
Left brake light out - bulb is fine benzer102 SLK R170 General Discussion 47 08-26-2018 12:01 AM
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
How do u install rear right upper brake bulb? razr-01 SLK R171 General Discussion 26 02-14-2011 01:03 PM
R170 Brake pad replacement Elvis Shmelvis SLK R170 General Discussion 8 09-08-2009 04:25 PM
