R170 Service Indicator won't reset - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By sokoloff
  • 2 Post By lilred320SLK
  • 1 Post By lilred320SLK
#1 Old 05-24-2011
Vehicle: SLK 320 (R170)
Hi all,
I'm trying to reset the service indicator on my MY2001 UK spec R170 (320). I've followed the instructions in the manual very carefully, and all seems to go fine, but the indicator just won't reset.
It's displaying a negative number of days, meaning it's past its service. It has of course been serviced, but the indicator hasn't been reset.
Any information on how to reset it?
G Howlerson is offline
#2 Old 05-24-2011
Quoted: 6498 Post(s)
If you haven’t, please post an introduction in the ‘new members introduce yourself here’ section.
Do a search to reset fss
Thank you,
Sergeant-at Arms
#3 Old 05-24-2011
I thought if one is past service due date, it will display + and not - ; Correct me if I am wrong (not familiar with R170).
#4 Old 05-26-2011
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
I would say that 99% of the time the problem is operator error. Clear your mind of what you think they want you to do, get in, close the door and follow the instructions exactly.
Len
Idiot101 likes this.
Len
1999 E300D 215,000 miles
sokoloff is offline
#5 Old 06-14-2011
Thanks for the reply. If that were the case, why is the negative number increasing every day?
#6 Old 06-14-2011
Len
Thank you for the suggestion. While I agree with you that this is the most obvious answer, I have tried (again!), with the same result.
Maybe I am misunderstanding a step.
#7 Old 06-14-2011
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Yeah, I had the same problem on my 210 chassis when I first tried it. Went through the steps a couple of times until it worked and I remember thinking to myself, "Oh, so that's what the Germans meant by that."
Len
Len
sokoloff is offline
#8 Old 10-12-2015
An older thread, but I was still looking for the answer to this . . .
Normally the indicator is counting down to the expected service (certainly in miles, I would assume that days would follow the same pattern) so it is saying 500 miles to go, 400 to go, 300, 200, 100, 0. Then, the only way they could differentiate it once past that point was to go negative -100, -200, -300 etc. meaning past due. Certainly they could have chosen either direction, but I haven't seen any indication that it is user selectable.
I had the same issue with trying to get mine to reset but I JUST got mine to work. You really do have to follow the instructions exactly. (At least that is how mine worked. I just reset it though, I didn't change modes!)
So, to review:
1) Turn the key to position 2,
2) Quickly press the odometer reset stalk in twice. (In no more than 4 seconds.)
The current setting will show,
3) Then quickly turn the key back to off. (In no more than 10 seconds.)
Now,
4) Press the odo reset stalk in and hold it.
5) Turn the key to position 2,
6) Wait for a bit and the display will turn to 10000. (For US miles.)
I can't remember hearing the beep . . . I was just surprised that it now showed 10000. When I cycled the key back to 0 and then restarted the car, no more indicator! (I'll see in 9000 miles or so if it worked properly.)
Hope that helps.
jbanks15 and tich65a like this.
lilred320SLK is offline
#9 Old 10-12-2015
Thanks! but yes, an old thread as
G Howlerson has not been back on since: Last Activity: 06-14-2011
#10 Old 10-13-2015
I saw the dates . . . just didn't see an answer!! Ok,maybe I should have said . . "Hope that helps someone . . . anyone . . . (Bueller? Bueller?) else!"
Service query nakulan7 SLK R171 General Discussion 10 03-09-2011 08:35 PM
Can't reset FSS at Service A level (oil/filter change) Alan Lukes General Discussion 6 02-05-2011 05:48 PM
Service message reset LudoMcGurk United Kingdom Region 4 04-06-2010 07:56 AM
Help - I Think I Reset the Service Indicator Twice! mizzerd SLK R171 General Discussion 3 06-29-2009 12:04 AM
Reset Service Indicator BrianS SLK R171 General Discussion 1 04-21-2008 05:21 PM
