How to fix turn signal hyperflashing if you have LEDs - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By JaysonM
  • 1 Post By Durkatlon
  • 1 Post By FCE LFT
  • 2 Post By jbanks15
#1 Old 08-27-2014
Post How to fix turn signal hyperflashing if you have LEDs
Hi there fellow members!
Telling the truth, this problem was bugging me for a while. I have changed all my lights to LED ones and like it! I have used error-free red LED for rear turn signal lights and there are no issues. The only problem were 1157 switchback LED bulbs in the front. When the parking lights are on they shine bright white, but when turn signals are used then they turn to amber color. One famous solution with LED lights is to use load resistors to eliminate hyper blinking. And I did, it works fine. All you need to do is install these load resistors and find a good spot form them under the hood. Now, over time (a little over a year) since these resistors are cheap, they started to give up and intermittently I would get hyper blinking with my turn signal lights. So, I started researching what else could be done and came across LED flasher relays.
Long story short, you need a EP27L LED Flasher relay, which I got from SuperBrightLeds.com. It was only $12
Here's a link:
EP27L LED Bulb Electronic Flasher | Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs | Super Bright LEDs
It's a 5-pin relay and works perfect!
The only issue here is that it's a little bit bigger than OEM relay and simply doesn't fit back into the fuse box. So, here's the modification I made to it - I simply extracted the board and cut down the case =)
Here's how I did it:
Tools you'll need:
1) side cutters
2) pliers
3) file (tool) Not a computer file
4) Plastic JBWeld
5) some quick grips
6) patience
On the R170 (US model) The turn signal relay is located on the driver's side in the fuse box under the hood. You'll need to remove the top cover, and then remove the 2nd "surrounding cover"which is secured by 4 tabs. It's the same area where you put your SmartTop relay in.
From this picture you can see where it's located. Yellow is the wiper relay, and the black one in the middle is the turn signal relay. On the right you can see my SmartTop module relay
Now, when the relay is removed you can see it's of a different size.
And when you put LED one in then the 2nd "surrounding cover" won't close =(
First, you need to extract the board form the casing. Carefully use something like a flat head screwdriver. Be careful not to damage the board!
Now get your side cutters and make 4 cuts right on the corners of the casing. You need to cut up to the wording "12 volt", or otherwise another guide is - there's a locking tab on one side of this relay. You need to cut up to this point.
You can see I already removed excess plastic from 3 other sides and I went bit by bit and my first cuts weren't made far enough.
Now take you pliers and carefully bend the plastic outwards an backwards. It will snap right off Do it with all 4 sides.
Then file it down so it's nice, smooth and even. Here's the end result of this procedure:
Take your quick grips and secure the board inside the cut case. DO NOT squeeze it like you mean it The pressure should be just enough in order to keep the board from falling off the case . Take your Plastic JBWeld (can be picked up at any local auto parts store), read the instructions on how to use it, and apply it evenly around the casing. You will have about 15 minutes to work with it before it starts hardening.
After application let it sit 3-4 hours for full cure. I left mine overnight.
Then use a file to even it out and file down the excess. Here's the finished result. It might not look esthetically pleasing due to color of the JBWeld but it works perfect! You can even paint it if you like But why bother since it's going to be inside the fuse box.
Here's the final comparison picture. You can see there's still difference in size but it will fit nicely and you can put the covers back on.
Now you can remove error resistors for blinkers (if you have them of course). Or you don't need to worry about error resistors for blinkers when switching from regular to LED bulbs
Hopefully it will help someone one day if they don't want to mess with resistors
Durkatlon and MikeWest like this.
#2 Old 08-27-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Very nice write-up!
JaysonM likes this.
Durkatlon is offline
#3 Old 09-04-2014
Vehicle: 2001 SLK230
Other Toys: missing many W123s, still loving '11 Audi A3 TDI, '66 Bronco (needs vario roof!), '73 Ranchero GT
Thumbs up Best hyperflash solution without resistors!
Awesome - s/b sticky! Maybe add "best" to main title..? I almost missed this because I'm all too familiar with resistors and thought, "duh." I just installed them in my slk, and so wish I had done this instead. It might look a bit laborious, but I am embarrassed to admit I probably spent more time hooking up, realizing my leads were too short to get the hot little buggers away from everything, thinking I should solder (but maybe later...) fretting over where to mount, not wanting to drill, looking for perfect hardware, feeling proud of my disc magnet w/ bolts solution - now feeling so lame for not spotting this far cleaner solution!
JaysonM likes this.
FCE LFT is offline
The Following User Says Thank You to FCE LFT For This Useful Post:
#4 Old 09-04-2014
Quoted: 6492 Post(s)
Stuck per request
Stuck per request
JaysonM and FCE LFT like this.
#5 Old 03-03-2015
Quoted: 20 Post(s)
still need the canbus LED's
You still need the canbus LED's so you don't get the bulb out indicator.
Joeb77 is offline
Turn Signal issue Saphykitten SLK R170 General Discussion 12 05-06-2015 12:55 AM
98 SLK230 turn signal problem yachtdude SLK R170 General Discussion 3 03-27-2014 11:26 AM
Right Turn Signal Problem onenobx New Members Introduce Yourself Here 12 07-25-2013 12:00 PM
3357A Turn Signal Bulbs Versus PY21W? mb911 General Modifications R171 2 11-15-2012 12:38 PM
Turn signal in mirror, right - Malfunction gdb069 SLK R171 General Discussion 8 03-05-2012 01:21 PM
