How do you re-glue the door panel? - Mercedes Benz SLK Forum
  • 1 Post By simplyslk
  • 1 Post By Alex 3
#1 Old 08-23-2014
Vehicle: 2001 SLK 320
The driver side door panel has come loose in the 2001 320. It was not completely loose but about maybe 3/4 of it from about the door pull on back was loose. Yesterday I tried some of that "liquid nails" stuff which was the only glue that had been mentioned in posts on this site that was available locally. I only put the glue on the top strip inside the panel as that was the only area that appeared to be made of metal and was flat. Checked it this morning after letting it sit over night and the top seems to be holding but every time I pull on the handle the bottom of that panel pops out some so that is putting torque on that top strip so it will likely eventually come loose again. What is the correct way to fix this so that it will hold? Should I try to get some glue of some sort in through the bottom of the panel? The top of the door pull seems to be anchored to the door but the bottom is just a molded part of the door panel with no anchor to the door so any yank on the handle seems to put a lot of stress on any glue holding the panel. Would that 3M 90 stuff which is a spray work better? Being a spray though how do you get it to the right places without making a huge mess?
SLK320Bob is offline
#2 Old 08-23-2014
simplyslk's Avatar
Other Toys: '13 GLK350
Quoted: 236 Post(s)
This will help you remove the panel:
use a 2 part epoxy.
JaysonM likes this.
Marykay
simplyslk is offline
#3 Old 08-26-2014
Quoted: 11 Post(s)
as said don't try and glue it in situ it must be removed and the parts that are coming away re glued with 2k epoxy then refitted
beerbelly is offline
#4 Old 08-26-2014
dpoppitt's Avatar
Vehicle: 1999 SLK230
I used JB Weld (6 minute hold version) on my SLK230 door and it's holding up fine...
dpoppitt is offline
#5 Old 10-17-2014
Other Toys: Traded them all!!
Quoted: 110 Post(s)
Gorilla glue works too but I would agree. Take the door panel off and work on it on a flat surface.
FatherGlen likes this.
Alex 3 is online now
#6 Old 10-17-2014
Deberd99's Avatar
Vehicle: 99 SLK 230 AMG SPORT 5sp
Quoted: 15 Post(s)
Mine has a bed clip but a small piece of Velcro did the trick
Deberd99 is offline
Carbon Fibre Panel Glue Advice Halifax SLK AMGs 9 05-27-2014 04:36 AM
Fault Codes On a Used SLK 230 I'm looking at jimithing60089 SLK R170 General Discussion 16 09-02-2013 12:58 PM
Black glue from 2012 R172 roof BACnSLK SLK R172 General Discussion 46 07-31-2012 10:20 AM
regluing door panels fiasco rogermursick SLK R170 General Discussion 1 07-05-2012 04:04 PM
