DIY oil change pics - Mercedes Benz SLK Forum
 32Likes
#1 Old 06-30-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
DIY oil change pics
For inquiring minds...
mb911, 24996, ezeman200x and 5 others like this.
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#2 Old 06-30-2010
Sulley007's Avatar
Chats: 444
I 'stuck' this thread at the top as it should certainly be a help to others for common oil changes to the SLK.
Sulley007 is offline
#3 Old 06-30-2010
Nice DIY post
#4 Old 07-01-2010
Las VegasCop's Avatar
Vehicle: 2001 SLK 230 Auto
I agree...nice job. Question? I personally do oil changes by the old fashion way, thru the oil pan drain plug. Just feel more comfortable knowing I got it all out. Yes, I understand that the way it is shown in the pics above is the way the dealer and the manual says to do....but still, anything wrong with that?
Las VegasCop is offline
#5 Old 07-01-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
I certainly don't see anything wrong with it, other than having to crawl under the car to remove all the coverings and such. That and I've heard mention of crossthreading the oil plug(s).
In all this would have taken about fifteen minutes(without the photojournalism)
It should be noted that the car should be brought up to operating temperature to suspend particulates before using the suction technique.
Glad I could help. It really IS pretty simple.
Margie and Terry
tcrankwa is offline
The Following User Says Thank You to tcrankwa For This Useful Post:
#6 Old 07-02-2010
yeah...true, but I got a full lift at the house so its easy and gives me A chance to look over for any leaks or problems ya know?
#7 Old 07-02-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Oustanding! Wonder if I can talk the wife into a lift?
Margie and Terry
tcrankwa is offline
#8 Old 11-19-2010
SLKen's Avatar
Other Toys: Mx5, Golf V5 (for work)
Never seen one of those suction vessels are they easy to get hold of?
SLKen is offline
#9 Old 11-19-2010
Quoted: 6568 Post(s)
google it my friend
#10 Old 11-21-2010
SLKen's Avatar
google it my friend
Just found one on flea bay, a little disappointed that I could not find one with a capacity of more than 4ltrs with the 320 having a greater consumption.
Just have to empty it and start again though I suppose
SLKen is offline
#11 Old 12-02-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Hi Ken,
You might try looking into "marine" oil changes. That's typically where these are used.
I've got the Mityvac 7300 (see pics) which holds about 8.8 liters. It runs about $96US at amazon.com
Margie and Terry
tcrankwa is offline
#12 Old 12-06-2010
rhusbands's Avatar
Vehicle: 2002 SLK 320 Sport
I picked up a Pela PL-14 to chage the oil in my 320. This unit holds 14 Liters. With shipping it was about $120. I can change the oil in my car, and my girl friends car without having to go by the recycler. off the internet... Below is a link to the site I ordered it from.
Pela Oil Pump: PL-14
olrum likes this.
rhusbands is offline
#13 Old 12-27-2010
Vehicle: 2004 SLK320
Ausgezeichnet! Thanks for the recommendation on the Pela PL-14! The hard part as others pointed out was finding a receptacle capable of containing the 8.5 qts from the SLK320. I've been doing the changes the old fashioned way (and will probably continue to do so as it gives me a chance to inspect the undercarriage), but this could give me a head start by draining most of the oil.
milesofsmiles is offline
#14 Old 01-01-2011
Vehicle: SLK230 R170 1999 62kKm 39kMl
Other Toys: House
MilesofSmiles......
Reckon you could do a similar post for your technique.
I'm inclined to do things the hard way....eg:
put car on ramps/lift....where to remove shroud bolts...etc.
prefered type of oil....climate (Im in Australia)
you can add photos next time you change it....
b22b
Billy22Bob is offline
#15 Old 04-27-2011
Vehicle: 2001 SLK 230 Sport
I'm using my Android phone, and I'm not able to find a posting with the start to finish link to changing the oil for my SLK 230. Ie: Tools we'll need to remove the cover, step by step pictures etc...
Q
thanks,
Jonathan m
JonathanE46 is offline
#16 Old 05-14-2011
LIL DON SLK's Avatar
Vehicle: 2009 SLK 55 AMG White 8 cylinder
Quoted: 146 Post(s)
I did not know that my SLK took 8 quarts to change the oil? Mobil 1 oil should last 10-14k between oil changes per service adviser at MB. DON
From Sacramento Valley SlK Enthusiasts
LIL DON SLK is offline
#17 Old 07-21-2011
Thanks for this thread and posting the photos. I recently started changing my oil in my SLK.
Question: how often should I change my oil filter?
(My SLK has 88,000 miles, mostly driven on highways. The last time I changed my oil, I used full synthetic-Royal Purple Oil and a K&N oil filter. I noticed that my engine temp was cooler on the really hot days here in Texas.)
JaysonM likes this.
#18 Old 07-26-2011
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Since they're not that expensive I'd suggest every oilchange (10,000 miles).
BTW, Welcome Aboard!!
Margie and Terry
tcrankwa is offline
#19 Old 11-20-2011
Vehicle: 2002 SLK320 Silver/Black
I also use a Mityvac oil evac unit similar to the one shown for oil changes on my 2002 SLK320 and love it. I was initially skeptical about it getting all the old oil out. But even after driving it a few days the new oil is still as clear and clean as when I put it in.
Numerous family members and friends have used the Mityvac since I bought it (it holds 8 US Qts and was $75 on Amazon) and 3 friends have bought Mityvacs for themselves. One of my sons used it on his Corolla a couple weeks ago and the oil was drained out literally in less than 3 min. Another son has used it on his Corvette with no hesitation.
No more jacking the car and crawling underneath for me. The only issue is none of them I saw held as much oil as my SLK so I do have to stop part way thru and empty the Mityvac. Small price to pay though compared to the oil sloshing around draining into a pan, emptying that, etc.
DarkHalo is offline
#20 Old 11-21-2011
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Not to mention not having to take off the cover or worrying about cross-threading the plug!
Margie and Terry
tcrankwa is offline
Nice day for a spin (Pics) Ynot General Discussion 38 01-01-2011 07:28 AM
OFFICIAL SLS AMG Pics Before Official Launch Date. Check It Here ;) Twisted McLaren SLR/SLS 15 09-09-2009 09:18 PM
Have any pics of your car Airbourne? SLKman General Discussion 9 04-17-2007 04:35 AM
Some Mars Red SLK350 on Brick Pics.... RacerCub68 SLK R171 General Discussion 10 11-28-2006 04:03 AM
