A pillar trim removal - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By notanumber
  • 1 Post By SJGavey
  • 1 Post By jbanks15
  • 1 Post By M4rCu5
  • 1 Post By stu32
#1 Old 05-09-2010
Vehicle: SLK230 1996
Other Toys: Mercedes 500SL 1989; Jensen Interceptor 1973; Jaguar XJ-S 1989; Mercedes CLK 320 2003
I have a 1996 SLK and would like to remove the A pillar trim for repainting. How do I do that?
Van
van883 is offline
#2 Old 05-09-2010
Vehicle: 2000 SLK 230
Is this what you're after ?
notanumber is offline
The Following 2 Users Say Thank You to notanumber For This Useful Post:
#3 Old 05-09-2010
No, thats not what I meant- I realise i should have been clearer.
I meant the panel on the outside of the car which I wish to repaint.
Thanks for your reply though.
Van
van883 is offline
#4 Old 05-09-2010
I hadn't realised there was a removable trim piece next to the windscreen but I've found the instructions for removing it .
M4rCu5 and Ukballer14 like this.
The Following 4 Users Say Thank You to notanumber For This Useful Post:
#5 Old 05-09-2010
Really appreciated!
Van
van883 is offline
#6 Old 03-27-2018
Vehicle: R170 200 Kompressor 2002
Similar question. Is it also possible to get the rear roof pillar off in the same way? I need to either repaint or replace one where rust is coming in the rubber trim area.
LIL DON SLK likes this.
SJGavey is offline
#7 Old 03-27-2018
Quoted: 6516 Post(s)
Hi old member!
you never made an intro in 2008 so we will let you slide
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
but we do need you to update your vehicle profile with model year 1996-2004
we assume since you are posting in r170 you have one
here is the c pilar removal for the r171. though you have a r170, we think, the procedure should be the same
https://www.slkworld.com/slk-r171-cla...rim-cover.html
#8 Old 03-27-2018
Quoted: 2264 Post(s)
Subtle differences in model years may matter.
That's why we ask for year in details.
Avel Du is online now
#9 Old 06-05-2018
M4rCu5's Avatar
Quoted: 248 Post(s)
Guys, I may be wrong and I hold my hands up if I am but I seem to recall that there is no outer removable trim on the R170 C pillars, the bit that holds the rear screen is all one piece with a recess for for the bonded screen.
M4rCu5 is offline
#10 Old 06-05-2018
you might be correct
I have not had a r170 in 13 years
Maybe one of our r170 experts will jump in
#11 Old 06-05-2018
M4rCu5's Avatar
Quoted: 248 Post(s)
And strangely enough, I've had mine for 13yrs Jeff
All glass was removed for respray purposes approx 5yrs ago now and I do seem to recall rubbing down a couple of rust spots in the area mentioned. Almost positive that there was no outer removable trim but I've been to bed since then and it was a long time ago
M4rCu5 is offline
#12 Old 06-05-2018
Got involved with a post on the subject a while back.
Pretty sure the experts said same.
Let's give them a shout:
@Mn car guy @efair @stu32 @savcom @Turdo2 @Padgett @Australian
#13 Old 06-05-2018
Other Toys: Ginetta G32
Quoted: 92 Post(s)
This is correct and the only way is to remove the rear screen and correct the rusty area's. It would of course be possible to replace the whole section (rear window frame) if a good one could be found as picture.
stu32 is offline
Broken B pillar panel cover Zut SLK R171 General Discussion 25 03-04-2015 03:48 AM
door trim cleaning ZeroZero Caring for your SLK 5 04-17-2010 04:35 PM
Possible issue with drilling behind fascia trim? ghostdunks SLK R171 General Discussion 1 11-28-2009 11:10 AM
