SLK230 Roof Hydraulic Pistion Replacement - Mercedes Benz SLK Forum
  • 1 Post By thunderstrike
#1 Old 12-08-2009
Vehicle: 2009 280SLK
Other Toys: Jeep Wrangler Rubicon
I had recently sold 1998 SLK230 to a good friend of mine, Chuck. He recently repaired it himself, and when I mentioned I wanted to publish his work in the forum he was nice enough to tear down again just to take pictures... thanks to Chuck, I'm posting this article for all to benefit...
Chuck:
I changed my front locking cylinder on my 1989 Mercedes 230 SLK for under $500 with no special tools.
Start early as this can take several hours to complete this task.
Step 1: Retract the hardtop half way.
Remove the headliner: 3 Philips screws in the front and 3 screws on each side.
Step 2: remove the cylinder bracket -- 3 star screws hold the bracket and 2 clamp ring and rods hold the cylinder to the bracket.
thunderstrike is offline
The Following 2 Users Say Thank You to thunderstrike For This Useful Post:
#2 Old 12-08-2009
Step 5: The hydraulic lines do not com off the cylinder; you have to disconnect the lines from the pump located in the trunk. There are several clips and clamps that have to be undone to remove the line.
Step 6: To get to the pump you must open the trunk like the top is to be lowered. Then you must remove the safety lid, the right rear wheel cover and metal bracket over the pump.
#3 Old 12-08-2009
Step 7: Remove the lines from the pump by cutting the black tie and twist the unlock level.
Caution: watch that all lines do not pop out.
#4 Old 12-08-2009
This is where you will need to fill hydraulic fluid.
Replace cylinder in reverse order... this completes the job.
The headliner was stained and had to be reupholstered with new material. A local shop did it for $50.
#5 Old 01-17-2010
Vehicle: Red 2001 SLK 230
Other Toys: Sailboat
Trying to add liquid to the pump.
Hello ! Depressureize is needed in order to add liquid ? I tried to unscrew the cap for adding the hidraulic liquid but it did not moves, do not want to peel or brake anything so I stop until further advise. Any hint ? Thanks !
frankycordero is offline
#6 Old 01-17-2010
Sulley007's Avatar
Chats: 444
Thanks for posting up! I'm going to move this to the DIY and 'stick' for future reference!
Sulley007 is offline
#7 Old 01-19-2010
It is that star headed driver. If they use anything other than that star tool with a socket wrench, then they could strip the plug.
Make sure you have the right tool (correct fitting) and nothing will brake. If you do not, then you will run into problems. They over tighten this fitting from the factory, this is a known problem.
#8 Old 01-20-2010
Thanks ! I have the star shaped tool for wrench use. Gonna put more strength in the effort, do I have to depressurize first ? Have a nice day ! Franky
#9 Old 01-20-2010
No, just unscrew it with firm downward force as not to strip it as it has been tightened too much from the factory.
#10 Old 01-21-2010
Thanks again. I added a little more tork to the task and its DONNNE !!! Working perfectly but... found a severe leakeage in the roof , so thats the next project. Have a nice day ! Franky
#11 Old 07-18-2011
Vehicle: SLK 230 1998
Hey,
Can you tell me the part number for the cylinder and where u purchased it.
Did you keep the cylinder that was replaced? If so I would like to purchase it if for sale how much?
Terry SLK in sunny FLA
twestenberger is offline
#12 Old 09-18-2015
Vehicle: 2001 slk 230 6-speed black
Quoted: 9 Post(s)
thank you.
are thee any photo's
alido pavan is offline
#13 Old 09-18-2015
Quoted: 6568 Post(s)
Originally Posted by alido pavan View Post
thank you.
are there any photo's
this thread is at least 4 years old. who are you asking for photos?
please use the 'quote' button at the bottom of anyone's post you wish to ask a question of or refer to their post otherwise they and we do not know who you are talking to. FYI
#14 Old 09-18-2015
I found the pics. Not sure where to put them so I can link them to this thread. Please advise.
#15 Old 09-18-2015
post 1-4 is where they were. or just em add em in the correct order here
#16 Old 09-18-2015
No URLs to post since pics are on my hard drive.
#17 Old 09-18-2015
i will send you a pm with my email if you want to send em to me
#18 Old 09-18-2015
pics....................
#19 Old 09-18-2015
more pics......
#20 Old 09-18-2015
last pics......
SLK 230 Hydraulic Roof actuator repair Thud57 SLK R170 General Discussion 347 06-21-2019 06:16 AM
SLK230 roof issue Thud57 SLK R170 General Discussion 4 08-30-2009 12:06 PM
Hydraulic Fluid for Roof Pump cw4bryant General Discussion 1 07-31-2008 06:30 PM
Hydraulic roof leak being fixed nmslk SLK R171 General Discussion 13 05-30-2007 08:30 AM
