DIY - Instrument cluster removal for R170 without telescoping steering - Mercedes Benz SLK Forum
  • 1 Post By dpresser
#1 Old 12-03-2009
Vehicle: 2003 SLK 230. Speer pulley kit. Depo euro headlights with led. Led taillights
DIY - Instrument cluster and light bulb R&R for R170 without telescoping steering
In order to replace the instrument light bulbs the cluster has to be removed.
This is a procedure for removing the instrument cluster from a left hand drive R170 w/o telescoping steering. Removing the steering wheel is not required.
File Type: pdf Instrument cluster removal on R170 without telescoping steering.pdf (602.4 KB, 1257 views)
Mantist is offline
The Following 7 Users Say Thank You to Mantist For This Useful Post:
#2 Old 02-20-2010
Vehicle: SLK32 AMG
Other Toys: Chevy dragrace car, BMW M3
Thanks for the descriptive procedure!
Roger and Out is offline
#3 Old 02-20-2010
Quoted: 6547 Post(s)
Roger and Out,
And finally, if you find something useful on your visit here today, please consider donating to offset development and operating costs. Even $5 is welcome! Thanks!
#4 Old 05-16-2010
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Thanks for a great tutorial , just what I was looking for !! Cheers.
curro101 is offline
#5 Old 05-16-2010
curro101,
In addition, if you haven’t, please post your questions in the appropriate discussion forum for a quicker response.
And finally, if you find something useful on your visit here today, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! Thanks!
#6 Old 07-05-2010
Vehicle: 2004 SLK320SE
Smile
Just wanted to add my appreciation for the very well written and documented .pdf instructions. I doubt I would have tackled this job without it, and paid the $240 to replace the instrument lamps. One note of caution to those attempting this procedure. I discovered that the dash plastic was painted (grey, over light primer, over black plastic) and easily damaged if hard tools are used. If you are temped to pry, do so with much caution. Damaged areas really stand out. Happily mine ended well.
dpresser is offline
#7 Old 11-28-2010
hydron's Avatar
Vehicle: 2000 r170 230k
I followed these instruction to change one bulb from my panel and it worked very fine, problem was when i mount it back my fuel gauge didn´t came up. NOw i dont know how mutch fuel i have on deposit.
Anyone know any solution plx
Thx
hydron is offline
#8 Old 11-28-2010
Vehicle: 2006 Mercedes SLK350
Is there a DIY for the r171 for this? I searched but can't find anything...
Clinterific is offline
#9 Old 08-02-2011
Vehicle: 2004 Crossfire 3.2 Auto Coupe
Other Toys: 06 ISUZU RODEO DENVER MAX . RETIRED RACE HORSE (Wifes)
Has anyone tried this with an adjustable steering column?
Does it make it easier as it gives more space between binnacle and back of steering wheel?
I have 1 bulb out so wa thinking about changing the 3 main pods to blue leds.
Opinions please, I have already changed the interior bulbs to blue leds and looks good refelcting off of the metal centre console.
MR KILMOUSKI is offline
#10 Old 08-04-2011
Our SLK320 has an adjustable steering wheel and I had no issues with clearance when performing this job. I can only assume that this is easier than attempting it without the ability to telescope the wheel away from the cluster. My biggest issue was some very stubborn clips that required persistence. Again be careful of using anything that might scratch the thin layer of paint. I wound up purchasing special dash paint to touch up my mistake. Still very happy that I did the job myself. Would have given up without the great instructions here.
montanelas likes this.
dpresser is offline
#11 Old 08-04-2011
dpresser,
Thank you,
Founding Member/Moderator
#12 Old 08-05-2011
Thanks dpresser,
It's good to know that it was easier, I have been putting it off for a year, but I may be moving on to a 171 sowant to get bulb sorted before I sell it.
Cheers and welcome to the forum
#13 Old 08-07-2011
Vehicle: 2001 Silver SLK230
Chats: 2
Sorry if I'm hijacking the thread, but I on my 230, the plastic cylinder (not sure what it's called) that sits right behind the steering wheel and holding the lights and cruise control switches has become loose. It moves right and left whenever I want to activate the turn signal. I'm clueless as what I can do to fix it. Anyone have a clue?
GusSLK is offline
#14 Old 08-15-2011
finally got around to changing the blown bulb. Used instructions very good but did not seem to remove as many parts to gain access. had all the blue leds ready and then found that generic type doesn't fit. warning do not buy off of ebay you'l just be wasting time and money. any how luckily I had a spare for the blown bulb, first time in 18 months that I've had a fully lit dash. Changed the 501's again in interior light now to bright white smd leds and looks less boy racery as the wife puts it.
Moral of the story Merc knows best and makes it difficult to mess with perfection. On the upside got loads of leds to spec up brothers jap crap car
#15 Old 09-09-2011
KonstaKoo's Avatar
Vehicle: SLK 230K
Other Toys: Saab 9-3 SC TTiD, Saab 93F
Thank you so much for a detailed guide. Could not have done without!!
KonstaKoo is offline
Instrument cluster replaced w4jeh United States 15 06-27-2012 05:06 AM
DIY: rear spoiler removal and install, part 1 dltslk SLK R171 Class DIY 0 03-12-2009 12:55 PM
New updated instrument cluster installed w/ lap timer nmslk SLK R171 General Discussion 4 07-10-2008 04:58 PM
Change instrument cluster to display digital mph chris_m SLK R171 General Discussion 30 07-17-2006 05:02 PM
