Add audio input on R170 Alpine CM1910 - Mercedes Benz SLK Forum
 5Likes
  • 5 Post By atlakehaven
#1 Old 02-26-2014
atlakehaven's Avatar
Vehicle: 2001 SLK 230
Other Toys: Ronix Mana, '95 Subaru
Here is an instruction to add your own audio input to an Alpine CM1910 from an R170. I performed this upgrade to the MB stereo in my '01 SLK 230 over a year ago. The pictures were so annoyingly fuzzy I had not planned on publishing; however, was PM'd asking for details. I've not done enough posts to PM, so here it is for everyone. (yeah, i know, welcome a dozen or so new members and i can pm; i'll do that one day)
- This mod does require an empty cassette in place to keep the audio flowing.
- Find an old earbud cord and snipped off the ear ends.
- Salvaged a pair of 1000 ohm resistors from your spare parts bin.
- You will need a couple of screwdrivers and a fine tip soldering iron.
- Red markings in pictures note areas of interest.
1. Remove the metal top cover from stereo receiver head unit.
2. Remove cassette drive unit. Thread the new audio cord through any convenient opening. The circuit board on back end of cassette drive is where connection is made.
3. Picture is looking at the circuit board on the back of the cassette drive unit. Note the left 3 soldered pins starting a uniform row near the top of the board. These are left, right, and ground for the audio input connection.
4. Cable-tie the audio cable to a metal hole on the lower left corner for strain relief. Put a couple layers of electrical tape over the circuit board between the cable-tie and the 3 pins of interest. Solder a 1000 ohm resistor between the pin I marked "L" and one of the audio wires of the cable. Solder a 1000 ohm resistor between the pin I marked "R" and the other audio wire of the cable. Solder a wire from the pin I marked "G" to the shield wire (i.e. ground wire) of the audio cable. Carefully add some electrical tape to ensure no uninsulated wires touch anything.
5. Return the cassette drive unit into the stereo assembly using caution not to pinch the audio cable. Replace the metal cover.
6. Happy listening!
jbanks15, JaysonM, drp643 and 2 others like this.
atlakehaven is offline
The Following 4 Users Say Thank You to atlakehaven For This Useful Post:
#2 Old 03-04-2014
Jeffrey's Avatar
Vehicle: 2001 SLK 230 Sport
Other Toys: 2005 C230 Kompressor Sport, 2013 E350
Thank you for this post. I plan to do the same mod to my Alpine head unit.
Jeffrey is offline
#3 Old 11-30-2018
Joseph Sager's Avatar
Vehicle: 2001 Mercedes SLK 230
Thank you for this guide and especially the photos!
I made this modification to my CM1910 radio last night following this guide mainly but also a few others. Other ones suggested cutting traces to things like the cassette head, motors, and internal amplifiers, but I wanted to keep my changes reversible. However I did end up de-soldering the (+) power from the cassette motors because - geez - those things are loud with the cover off.
I used a longer input wire with thicker gauge wires so the resistors were dropped after a test fitting revealed the audio too quiet.
Thank you again.
Joseph Sager is offline
#4 Old 12-23-2018
Update: don't disconnect the tape motors
#5 Old 05-26-2019
jkc
Vehicle: 1999 SLK 230 Kompressor R170
Wow! Great guide!
Nice write up with added pictures! I hope to try this with my own car later this month when I find time. Thanks for sharing!
jkc is offline
AUX input for Audio 20 ildoctore SLK R171 General Discussion 14 09-30-2012 09:50 AM
Easiest and most affortable way to use the PHONE system and add AUX input to my car michaelszx SLK R171 General Discussion 5 06-08-2012 01:34 PM
Audio aux input problem w/ Comand unit jkenty SLK R171 General Discussion 2 07-18-2009 10:21 PM
Alpine VehicleHub ssoji General Modifications R171 0 09-07-2006 11:13 AM
