DIY refill Mercedes Benz R170 hydraulic roof fluid - Mercedes Benz SLK Forum
#1 Old 10-16-2009
Sulley007's Avatar
Chats: 444
Thanks to user Thud57 for this great information.
Filling the roof pump is not as complex as it appears. Don't waste your time (as I did) with the fill screw on the side of the pump facing you. Here is what you need to do.
1) depressurize the system using the hex wrench that is attached to the plastic access panel. If it isn't there you'll have to find one that fits - I'm sorry, I forgot the size. Follow the owner's manual instructions and rotate the brass colored screw (I don't have it in front of me, but I think it says counterclockwise) all the way.
2) on the top of the pump where all the hydraulic lines go in there is a filler hole that makes life so much easier. You can't really see it very well because it lies on the upper far right hand side on the top of the pump in that same area. I think it takes a 5mm hex wrench. If you feel with your fingers you will find the cap screw there on the far side of the lines. It loosens counterclockwise and it may take some effort as it is torqued down kind of tight. BE VERY CAREFUL WHILE LOOSENING. Once it is loose remove the wrench and unscrew it with your (dry non-greasy) fingers making sure that when it is finally free you don't drop it in the pump access cavity. If you do you will never see it again as it will drop way down into the car body interior.
3) Home Depot sells 1/4 inch OD rubber tubing (20ft for 2.00) get it and find a baby syringe at a grocery/drug store. The nipple of the syringe should fit perfectly into the tubing.
4) cut about a 2 ft length of tubing, insert it into the filler hole (you should be able to go in a few inches), take out the syringe plunger, pour a portion of the special hydraulic fluid into another small shot-glass size container and pour that into the syringe that is attached to the hose a little at a time. Repeat procedure until the fluid level is between the two lines you see on the plastic pump reservoir. It shouldn't take much fluid.
5) once at the level VERY CAREFULLY reinsert the filler screw and hand tighten with the hex wrench. Now you're good to go.
6) find out why you are loosing fluid - I understand headliner droop is a tell-tale sign. Also look for run lines inside the trunk under the two roof actuators.
Good luck!
Sulley007 is offline
#2 Old 01-21-2010
Thanks, I'll try this way!!! Xcllent!
Archie37 is offline
#3 Old 01-25-2010
98slk230's Avatar
Vehicle: Silver 98 SLK230 / Salsa Red/Black Interior
Other Toys: Nothing as of now but hoping to add to the collection. Look for updates hopefully.
Send a message via AIM to 98slk230
What kind of fluid did you use and where did you get it from?
98slk230 is offline
Mercedes Benz SLK Black Projector Halo Headlights R170 fluffytigra Performance MODS for the R170 14 05-02-2013 04:56 PM
R170 roof vs R171 roof? atebit General Discussion 1 05-27-2009 10:44 AM
Hydraulic Fluid for Roof Pump cw4bryant General Discussion 1 07-31-2008 06:30 PM
Mercedes Benz Clubhouse Corkscrew General Discussion 9 01-21-2007 08:22 AM
