Accelerator Pedal Removal - Mercedes Benz SLK Forum
 5Likes
  • 5 Post By Highpowerjeff
#1 Old 12-26-2013
Vehicle: 2001 SLK 230
For those who are going to replace the Accelerator Pedal in their R170 and have read where it is difficult to remove the washer located under the 10mm nut, I have a tip. I removed the pedal assembly and replaced with a new one in less than 15 minutes. Here is how I did it.
1. Remove cap covering the nut and remove the nut.
2. After looking at the washer and probing it with a pick I realized the washer had plenty of room to be removed over the threads of the bolt, but was being wedged to one side by the pedal assy. itself. When I pushed forward on the pedal the washer would be very loose.
3. I took a piece of thin cardboard and rolled it into a tube shape that would go over the bolt threads and reach down to the washer and taped the cardboard so it would hold that shape.
4. Next, take a small piece of duct tape and lay it over one end of the tube so the sticky side is up, then take more tape (masking tape or something similar) and wrap around the tube to hold the duct tape in place.
5. Cut an "X" into the duct tape so the tube will go down over the bolt threads.
6. Once over the threads and applying downward pressure to make the duct tape stick to the washer I pushed forward on the pedal assy. to relieve the pressure against the washer.
7. Slowly turn the tube counter clockwise and lifting up gently as if you were unscrewing the washer from the threads on the bolt. IMPORTANT: Keep the forward pressure on the pedal assy., in order, to keep the washer from being wedged against the threads. This is a feel as you go kind of thing. It took me two tries to get it, and walla!! it lifted the washer out.
8. The rest of the replacement was simply pulling the pedal assy. aft and out, unplugging the two wire connectors and replacing with a new pedal assy.
9. don't forget to reset the computer using the instructions on this site and in the manual.
A Pic of the Tube.
etyu, jbanks15, Stinger and 2 others like this.
Highpowerjeff is offline
The Following 5 Users Say Thank You to Highpowerjeff For This Useful Post:
#2 Old 12-26-2013
Very good tip Jeff
#3 Old 12-26-2013
Nice write up, thanks for the how to thread.
#4 Old 09-27-2014
Why the replacement
wHY DID YOU NEED TO REPLACE THE ASSEMBLY? i THINK I MIGHT NEED TO DO MINE. tHANKS
carguy23 is offline
#5 Old 09-29-2014
Accelerator assy. replacment
The car would hesitate when pressing on the gas pedal. I would do the reset procedure, but it would begin to hesitate during acceleration almost immediately. After reading several threads on the issue I replaced the Acc. Assy. and it fixed the issue. Now my car runs like new. I found a place to buy the OEM new part at half the price the dealer wanted.
New-Part.com - Import and Domestic Auto Parts and Accessories
good luck
#6 Old 09-30-2014
Thank
Thanks for the help ill keep you posted once i install my new assembly
carguy23 is offline
DIY: R171 Washer Reservoir Removal Durkatlon SLK R171 Class DIY 70 2 Weeks Ago 12:04 PM
Dash Console Removal and Paint Stripping RSR General Modifications R170 49 11-13-2018 08:34 PM
DIY - SLK R171 head unit removal (youtube by benzwerks) Stinger SLK R171 Class DIY 2 10-02-2015 01:31 AM
seat removal slk320chick SLK R170 General Discussion 5 07-17-2013 09:52 PM
DIY: SLK55 R171, Exhaust Manifold Removal, Repair, Replacement lebmingling SLK R171 Class DIY 10 02-26-2012 02:21 AM
