Radiator Coolant Expansion Tank Replacement - Mercedes Benz SLK Forum
  • 2 Post By SLKman
#1 Old 10-29-2013
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
Mercedes Dealer told me this has become a common Problem.
Over time the Plastic gets brittle and cracks if you "bump" the hose.
The break happens where the hose is clamped to the plastic. It is reinforce with a copper insert but is still able to crack and drip.
Over time the dripping can ruin your radiator fan motor.
This is an easy fix.
Dealer wanted $460 to repair it.
BAP auto parts store $100 (in stock)
Ebay Brand New Genuine OEM part $68 (had to wait a week to get it)
30 minute of my time.
Hope this helps.
SLKman
jbanks15 and ajberrow like this.
SLKman is offline
The Following User Says Thank You to SLKman For This Useful Post:
#2 Old 10-29-2013
Nice job Brent, thanks. That sure beats the inflated dealer price.
#3 Old 11-12-2013
Slk200Tr's Avatar
Vehicle: 1997 SLK 200
Other Toys: WW Passat 1.4 FSI; Renault Clio IV 1.5 HB DCI
Great job man.
I had the same problem with my SLK200 and bought a new tank. It costs about 70$ in here. I changed it in the garage and now it works fine.
Slk200Tr is offline
#4 Old 05-26-2015
Vehicle: 2004 SLK 320 Special Edition
I found this thread after I noticed white residue on the expansion tank for my '04 320 while I was cleaning under the hood and promptly broke whatever fragment of plastic was still holding the barb on.
I reinserted the brass nipple and took it for a test drive. Although it wasn't going to blow out, it was leaking pretty good without the bit of crust it had.
Pelican had an OEM tank for $96 (it's where the washer fluid is warmed smh) so I'm waiting for it to get here. Meanwhile, I thought I'd share a tip:
As a stop gap measure I took about 3/4" of teflon tape, wrapped the brass nipple 3 turns and put it back in the hole. It's doing the job so far. YMMV.
THIS IS NOT INTENDED AS A REPAIR.
j4strngs is offline
#5 Old 05-26-2015
Because I can't edit the other post for clarity: washer fluid warming is a secondary function. It uses heat transfer from the coolant.
j4strngs is offline
Windscreen / windshield washer pump / motor replacement Simon SLK R170 class DIY 12 04-17-2016 12:20 PM
Coolant Reservoir carpetman SLK R170 General Discussion 16 09-22-2013 10:05 PM
Ford recalling 465,000 2013 models to check for fuel tank leaks jbanks15 Off Topic 0 06-03-2013 03:30 PM
R172 Windshield Replacement slickBenzGirl SLK R172 General Discussion 8 01-02-2013 01:06 AM
removal of expansion tank dmbooth SLK R170 General Discussion 6 12-31-2010 07:12 AM
