JB4 Tuner? - Mercedes Benz SLK Forum
SLC General Discussion SLC 180,200,300,250d,43 AMG
  • 1 Post By LeonardoDaBenz
  • 1 Post By jbanks15
#1 Old 03-26-2019
Vehicle: 2018 SLC 43 AMG
JB4 Tuner?
Anyone installed a burger motorsport jb4 on a SLC 43AMG?
Rabioso is offline
#2 Old 03-26-2019
Quoted: 6435 Post(s)
what makes you think they make a tuner for your car? just askin?
No one else does....no Kleemann at least
#3 Old 03-26-2019
LeonardoDaBenz's Avatar
Quoted: 1012 Post(s)
I only see for C-class??
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#4 Old 03-26-2019
I ask them and they told the Mercedes one will work for my car.
Our Mercedes JB4 works.
2015+ W205 Mercedes C-Class Stage 1/JB4 tuner | BurgerTuning.com
Rabioso is offline
#5 Old 03-26-2019
well good luck with that
not an expert by any means but the slc 43 did not come out until 2016 so they are saying a 2015 version for a different non bi turbo will work on your car?
#6 Old 03-26-2019
Crazy they reply it will work... I will find out, I don't thinks a single turbo will work for a bi turbo....
Only tuner I saw for this car is this:
https://www.racechip.com/shop/merced...0kw-520nm.html
Rabioso is offline
#7 Old 03-26-2019
Money back guarantee?
LEN
(Moderator)
#8 Old 03-26-2019
don't waste your time
read the reviews
https://www.trustpilot.com/review/www.racechip.de
even Kleemann does not make anything for your engine
https://catalog.kleemann.dk/catalog/...arger-kit-113/
LeonardoDaBenz likes this.
#9 Old 03-27-2019
Quoted: 205 Post(s)
It seems there are a lot of people chiming in that don't even know who Burger is. I have a JB4 on my 335Xi and they work pretty well. You just have to remember what it is, it is a piggyback system. If you are looking for a moderate boost in performance and that is it, they it works very well. They make it for the C43, so I am sure the engine controls are the same as the SLC43. They have a very good forum you can check out and see what the reviews are. The Mercedes section doesn't seem very used, but the BMW section is. I know I saw some of the development they were doing and the gains were impressive. Go with the JB4 too, not the stage 1.
https://www.n54tech.com/forums/forumdisplay.php?f=38
Another option is a reflash. It will normally be smoother, but the JB4 is more flexible and you can change it.
https://www.eurocharged.com/products...ngine-software
jet_fl is offline
#10 Old 03-27-2019
Vehicle: Stock 2018 SLC 43
jet_fl get's it :-) I've sent several emails back and forth with BMS to get info. I'm paling to order their c43 intake system for my slc 43. If the intake didn't fit, they' take it back.
After talking with several tuners now, you can be pretty confident that a tune that works on a M276 dela 30 will work on the slc 43.
Anthony Bracamonte is offline
#11 Old 03-27-2019
my comment was referring to race chip
#12 Old 03-28-2019
Quoted: 205 Post(s)
Honestly I would probably go with a flash tune. The gains are higher and it should be smoother and drive more like stock. The JB4 is basically a cheater box, it takes your airflow inputs and cheats the car in to thinking more air is coming in, so increase fuel. It says the boost is lower than it is. so it increases boost. It balances out pretty well, but the problem is as part throttle it doesn't always match 100% since you aren't in boost. My BMW was certainly tolerable, but it wasn't factory smooth.
jet_fl is offline
#13 Old 04-01-2019
That's good to know. For the most part, I was planning to use it for "bragging numbers" and would probably run it stock or one their lowest map most of the time.
I want to use it mainly to run race fuel and their 6.5 map on some sticky tires to see what sort of 0-60 and 60' times can be had from the SLC 43.
The only downside of the tunes available is that their all or nothing, no options yet to swap back and forth, like say a Cobb tuner.
#14 Old 04-02-2019
Quoted: 205 Post(s)
If switching maps is a priority, then yes JB4 is the way to go. I have a map set for a 35% blend of E85 that I ran most of the time (comes out to 97 octane), but can switch to a 93 octane map in 10 seconds. Map 2 is solid and is very stable, for the 335i at least. Map 1 is just a very slight increase in power. Map 0 is a pass through and basically shuts off the JB4.
jet_fl is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > SLC General Discussion
British Tuner Launches World's Most Powerful Jaguar F-Type Berliner Heckflosse Off Topic 1 04-25-2016 09:43 PM
Tuner Buchman is back Berliner Heckflosse Off Topic 0 04-13-2015 03:20 PM
Satellite Tuner in the Trunk? Bassman62 SLK R171 General Discussion 2 08-25-2014 05:58 PM
Sirus Tuner not working/trouble shooting? pctravel SLK R171 Class DIY 3 09-07-2009 04:55 PM
Tv Tuner Windy General Modifications R171 5 10-09-2008 12:04 AM
