Good time to upgrade to a SLC? - Mercedes Benz SLK Forum
SLC General Discussion SLC 180,200,300,250d,43 AMG
 16Likes
#1 Old 02-18-2019
Vehicle: SLK250 AMG (2012)
Hello,
As SLC's are getting over 3 years old, I see a few for sale now under 20k.
Is it worth the upgrade from a R172?, apart from the revised styling, don't see much difference.
Must say the R172 looks more sporty too
Appreciate any comments from those that have made the change.
slk200AMG is offline
#2 Old 02-18-2019
Quoted: 112 Post(s)
Depending on what Model Year SLK you refer, you may get upgraded 9 speed transmission, color instrument cluster, and of course, the newer infotainment system.
The engines of the SLC are also newer and more eco friendly.
You might also find SLC's still under warranty.
You should also take into consideration that, while you may find SLC's under 20k, they may lack many options that you could otherwise find on an SLK under 20k.
As you also said, and as a personal preference, I think the SLK looks more muscular, with the edgy shapes, rather than the curved shaped SLC.
As the SLC is a refresh/facelift, I would normally say go for it, but since, from design point of view, the SLK looks better, and most of the things found in the SLC can be found in the SLK, I would personally go with the SLK.
Wilhelm Sorban is online now
#3 Old 02-18-2019
Thanks, so the SLK250d engine is different to the SLC250d engine?
Do you know the differences, assuming both have 9 speed Transmission.
#4 Old 02-18-2019
Quoted: 6460 Post(s)
SLK 250 BlueEFFICIENCY 2011- 1,796 cc (110 cu in) I4 turbo (M271 DE 18 LA) 204 PS (150 kW; 201 hp)@5500 310 N⋅m (229 lb⋅ft)@2000-4300
SLK 250 CDI BlueEFFICIENCY 2012- 2,143 cc (131 cu in) 16V I4 2-stage turbo (OM651 DE 22 LA) 204 PS (150 kW; 201 hp)@4200 500 N⋅m (369 lb⋅ft)@1600-1800
SLC 250d 4 cylinders, 2.1L turbodiesel 204 PS, 4,4 l/100 km, 114 g/km, 0100 km/h in 6.6s, 245 km/h
250 7 speed
slc 250
9G-Tronic automatic gearbox, except for the 180 and 200 in which a manual 6-speed gearbox is standard,[17] although the automatic is available in option.
Wilhelm Sorban likes this.
#5 Old 02-18-2019
so the 2016 slk250d and 2016 slc250d have same engine?
#6 Old 02-18-2019
There probably is no 2016 slk 250d AND 2016 slc 250d... one or the other was made
#7 Old 02-18-2019
Delucas's Avatar
Quoted: 1133 Post(s)
The new SLC are now named 173 models .
Update : i was informed wrongly by a new SLC owner ( and some websites are showing the SLC as the new 173 model .??!!
So its still a 172 which i always thought it was but was informed wrongly .
Delucas is offline
#8 Old 02-18-2019
no they are not they have r172 in their vin numbers and wdd
2016 slc WDD1724042F1344347
Delucas and Wilhelm Sorban like this.
#9 Old 02-18-2019
Quoted: 2214 Post(s)
Price rises are another consideration in the UK.
Some are adding a 'you pay an extra 10% post Brexit, if required'.
https://www.slkworld.com/off-topic/5...rice-rise.html
This may or may not impact second hand prices in either direction.
Avel Du is online now
#10 Old 02-18-2019
Plenty for sale on Autotrader, both with 9 Speed Auto Transmission.
#11 Old 02-18-2019
only thing i can say is that in uk/overseas, as an example, the r171 came out 2004 but years for r171 are 2005-2011
same for r172...came out by you in 2011 but in usa 2012
or autotrader be wrong
if 9 speed cannot be slk...just saying
#12 Old 02-18-2019
Less shipping time to UK?
#13 Old 02-18-2019
or those selling in autotrader don't know if 2016, they have an slc and not an slk
#14 Old 02-18-2019
#15 Old 02-18-2019
title says 7 speed - just shows they do not know what it has
Mercedes-Benz SLK 2.1 SLK250d AMG Sport 7G-Tronic Plus (s/s) 2dr
This car has the later 9G Tiptronic gearbox in the new model, not the 7G normally in this model.
maybe it had trans issues and owner got a 9g as a replacement
#16 Old 02-18-2019
LOL, I've seen dozens of SLK250d' from late 2015 and 2016's with 9 speed boxes.
https://www.bigmotoringworld.co.uk/u...mg-sport-27473
#17 Old 02-18-2019
well to put this issue to bed
late 2015 is practically 2016 and 9g came in 2016s
#18 Old 02-18-2019
the debate was if the slc and slk 250d's build in 2016 had the same engine.
#19 Old 02-18-2019
Trev5's Avatar
Quoted: 305 Post(s)
The CarWow website has good SLK/SLC comparison Pictures & the a brief write up of the changes:
Details: https://www.carwow.co.uk/blog/mercedes-slc-vs-slk
Though I'm not sure the COMAND is that much better, though agree the 9G box is very slick..
Update : I was informed wrongly by a new SLC owner ( and some websites are showing the SLC as the new 173 model .??!!
So its still a 172 which I always thought it was but was informed wrongly .
My 2018 SLC has a WDD1724662F~~~ vin number as well..!!
But if You Google R173 it does comes up with loads of SLC pictures..!!
Rorywquin and LeonardoDaBenz like this.
Trev5 is online now
#20 Old 02-18-2019
which look exactly the same as the car is the same and those 173 links are uploaded by people that haven't a clue
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > SLC General Discussion
Heads up - Daylight Savings is here Change your clock time (UK Mar 25 1 am) jbanks15 Off Topic 17 03-25-2018 08:00 AM
Heads up - Daylight Standard is here USA Nov 5th 2 am (UK Oct 29th 2 am) jbanks15 Off Topic 17 11-05-2017 06:01 AM
Good Time kuratsunade U.S. Midwest Region 0 10-11-2013 11:31 AM
Not a good time to check your fog lights! Mensra Off Topic 4 09-05-2013 02:36 PM
Good Idea or waiste of time..... phillikl Off Topic 4 12-30-2006 01:35 AM
