Garmin Sat Nav Question - Mercedes Benz SLK Forum
SLC General Discussion SLC 180,200,300,250d,43 AMG
  • 1 Post By TonyS3
#1 Old 04-30-2017
Pyecrust's Avatar
Vehicle: SLC 250d Sport in indium grey, March 2017
Other Toys: Skoda Yeti 170 & K1 Racing dinghy
Quoted: 64 Post(s)
Hi All,
I have the Garmin sat nav SD card in my SLC. Works well and comes with free software and traffic updates for 3 years.
Trouble is if I remove it to put say a music SD card in then the sat nav stops working and insists that it must have the SD card in to operate. Kind of makes the SD slot useless for anything else. Is there a way of downloading it to the cars memory so I can use the SD card slot for other things? Can’t find anything helpful in the manual. Does the car actually have a memory for loading in sat nav info? Any advice appreciated.
Cheers.
Pyecrust is offline
#2 Old 05-01-2017
Vehicle: 2016 SLC 250d AMG line, Hyacinth with toys
Other Toys: 1967 triumph Vitesse 2.0
Don't think so Pyecrust its just the guts out of a portable sat nav that you would put up on the dash top...
pimp my merc is offline
#3 Old 05-03-2017
TonyS3's Avatar
Vehicle: 2013 SLK55 AMG
Quoted: 336 Post(s)
Pyecrust
Doesn't the car have a built in music hard drive? Download your music from your SD card onto that then replace the satnav SD card.....
TonyS
Pyecrust likes this.
TonyS3 is offline
#4 Old 05-03-2017
Pyecrust's Avatar
Quoted: 64 Post(s)
Originally Posted by TonyS3 View Post
Pyecrust
TonyS
Thanks Tony,
I tried to do that from a USB stick but it only imported track titles and details still needed the USB stick in place.
Could try it again from the SD card though.
Cheers, David
Pyecrust is offline
#5 Old 05-03-2017
TonyS3's Avatar
Quoted: 336 Post(s)
Originally Posted by Pyecrust View Post
Thanks Tony,
Cheers, David
I downloaded my tracks from ITunes onto SD card and popped it in the slot, the car did the rest with some prompts
TonyS
TonyS3 is offline
#6 Old 05-03-2017
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Just a comment but I do everything from my Smart Phone, the car is really just an amplifier with volume control and speakers. This includes hands free phone (needed to add a microphone), engine parameters & diagnostics, GPS with live traffic reports , and about 500 albums. Most can use voice for instructions. And I have exactly the same thing & use the same phone in my other cars. One $45/month subscription to manage.
Only real difference is three of them have Bluetooth, others (including my '70) use an aux jack. Even have Bluetooth in the travel trailer & can stream TV with an HDMI output.
Phone has a 128GB SD card, am told a 256 works but have not tried. One device to control them all.
Started thinking this way in '12 and works for me.
Padgett is offline
#7 Old 05-03-2017
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
I have a GLA with the Garmin Nav that also uses the SD card for the maps. If I remove the SD card the Nav will not work. It appears that the Nav does not save the maps with in the system. Do not see anything that the entertainment system has a hard drive to save anything, either uses the SD card or USB or Bluetooth connection to a device.
Gbarringer100 is offline
#8 Old 08-28-2018
SLK World Junior Member
Could you tell me where the SD slot is located please - searched hi and low, I have a 2017 SLC250D - thanks
saf1 is offline
#9 Old 08-28-2018
Quoted: 6435 Post(s)
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300, 320, 350, 55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. Click this: https://www.slkworld.com/new-members-...yourself-here/
#10 Old 08-28-2018
Pyecrust's Avatar
Quoted: 64 Post(s)
Ah good question, it's on the front dash sort of under the under the CD slot.
Mine is occupied by my sat nav SD card which is a bit of a pain as sat nav only works if the sd card is in, (stupid MB)!
So my music USB drive is in the USB slot under the central arm rest.
Got to admit the MB music system is a bit **** to navigate compared to other cars I have had.
But hey one gets used to it!
SLC 250d Sport
Metallic paint, sat nav, heated seats, reversing camera, dimming and folding mirrors, rain sensors, cup holders, dark carbon trim.
Pyecrust is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > SLC General Discussion
Ten year old sat nav Royston SLK R171 General Discussion 6 04-21-2016 05:36 AM
NTG2.5 Sat Nav update Konicky SLK R171 General Discussion 29 02-25-2014 12:40 PM
SAT NAV Aerial and M6 Toll Tag daj SLK R171 General Discussion 2 08-01-2007 06:07 PM
Sat Nav Nita General Modifications R171 6 04-20-2007 09:03 AM
