'Close Rear side windows' message - Mercedes Benz SLK Forum
SLC General Discussion SLC 180,200,300,250d,43 AMG
 13Likes
#1 Old 03-02-2017
MaryTay's Avatar
Vehicle: Jan 2017 SLC 250D Sport in Hyacinth Red with a few extras. Delivered 30th Jan 2017
Hi Everyone
I have a new SLC 250D. I sometimes get a message on the screen when I switch off the engine that advises me to 'close rear side windows'. This is when I haven't had the top down (weather still not dry enough!). There is a button to close ALL windows under the flip up cover in the centre console - where you can also put the top down and up. When I press that the message doesn't go. Also, the rear windows (I assume the little triangular shaped ones?) are not down, as far as I can tell.
Can anyone enlighten me, please?
Thanks.
Cheers,
Mary
MaryTay is offline
#2 Old 03-02-2017
Vehicle: Audi TTRS MY2017
Other Toys: Whyte Prst-1, MY2017 Audi A6 allroad Competition, 1/50th Twin Squirrel, 2006 Fabia vRS Hybrid
Quoted: 619 Post(s)
Sounds like a sensor issue.
The car obviously thinks the windows are open, even slightly. If the windows are indeed closed then it needs a sensor replaced or adjusted.
You can try resetting them. Hold the centre switch down for 5 seconds (count 1-elephant, 2-elephant etc.) then pull it up for 5 seconds.
If that doesn't clear it then I'm afraid it's back to the dealer!
Avel Du, stagwcb and DaveR. like this.
wja96 is offline
#3 Old 03-05-2017
Vehicle: 2016 SLC250d
Other Toys: 2017 AMG SL65 2016 A180d Sport
Hi Mary. I had exactly this message appear on the screen. Whilst I am not yet fully familiar with this car or its idiosyncrasies, I did solve the issue by cycling the window states using the centre switch
Good luck
Tim
Tim Apps is offline
#4 Old 03-10-2017
Saska's Avatar
Vehicle: 2016 SLC43 AMG
I have had that message as well. Also occassionally when I put my drivers window down and then close it again the back little side window stays open and I don't know how to close it unless I operate the open/close roof function. I haven't done many miles in the car and should take it back to the MB dealers but would love to hear if anybody else has had the same problem or if there is a way to independently open and close the rear little windows? Thanks.
Saska is offline
#5 Old 03-10-2017
Quoted: 6460 Post(s)
With the SmartTop!
https://www.slkworld.com/general-disc...ing-about.html
#6 Old 03-10-2017
Saska's Avatar
Haven't got a clue what that is? I clicked on the smarttop link but it's all too complicated. I guess going back to the dealers is my easiest option.
Saska is offline
#7 Old 03-10-2017
did you read the thread?
Smarttop is a 'mod' one buys to get all those feature
did you see the 2 videos at the top of the thread?
did you watch them?
#8 Old 03-10-2017
Quoted: 619 Post(s)
The SmartTop might look complicated but it's basically what the SLK/C should come set up as from the factory.
The main benefit is you can raise or lower the roof from the key fob from as far away as you can unlock the car.
It also drops and raises the rear windows, makes you coffee on cold days - all sorts of stuff. Get one. I resisted for years. And then I succumbed and now I'm a very strong proponent.
jbanks15, bastivock and Avel Du like this.
wja96 is offline
#9 Old 03-10-2017
If I remember, you were my toughest 'nut' to crack!
#10 Old 03-10-2017
Vehicle: slc 43 2016
Quoted: 82 Post(s)
I've had that notice , I've also been aware of the rear quarterlights being down when I didn't know they were , I just held the window switch held up and they went up . But you probably shouldn't pay any attention to me as I plugged an I pod into the car and after 5 mins of trying to make it work it didn't and I got bored so I went to the supermarket and bought a cd instead , that works fine !
Tech passed me by
MartinatMersea and Pres like this.
Paulwirral is offline
#11 Old 03-10-2017
Quoted: 2213 Post(s)
Tech passed me by
That'll be the 'Wirral Way'
#12 Old 03-10-2017
Quoted: 82 Post(s)
Angry
:[QUOTE=Avel Du;3440009]That'll be the 'Wirral Way' [/QU
old blokes blokes way I don't get where the 43 knockers are coming from tech wise , I just turn it all off if I want some fun , factory lsd , traction off completely , and it really is off much to the dismay of 55 owners , gearbox in manual and it sits on the limiter instead of changing up unexpectedly , sounds like a drivers car to me ? Maybe the 55amg owners are lacking in certain departments
trptman likes this.
#13 Old 03-10-2017
[quote=Paulwirral;3440097]:
You do know that the 55 has manual too?
As for the wind up?
Nice try.
You should check my background out.
You'll see why I laugh at sports car drivers with ego.
The thrill is to enjoy the car that we choose in the way that we choose.
The truly fast get involved with motorsport.
Look around the site and check out what they use.
There'll be a reason why they choose that engine.
Long live the Wirral Hundred (& I don't mean the pub )
#14 Old 03-11-2017
Saska's Avatar
did you watch them?
Tks and yes I did but it's not what I am looking for as it's not necessary in this model. In the spec of the SLC 43AMG it states < The rear, side windows can now be operated independently, even if the roof is open> Hence my question of how do you operate them independently? Cheers
Saska is offline
#15 Old 03-11-2017
WhiteRabbit's Avatar
Vehicle: 2012 SLK 350 (R172)
Quoted: 67 Post(s)
Inside of the handle that lowers and raises the top is a switch (looks like a door's window switch) that operates all four windows at once.
Use that switch to lower all four windows at the same time and raise all four windows (the front windows close first and then the rear windows close).
Note that in SLK models you can't have the rear windows up with the top down unless you have a smartTop module installed.
Don't know if the SLC models work the same way.
2012 SLK 350, Mars Red, Ash, 7G Automatic, Premium Pkg I, Lighting Pkg, Multimedia Pkg, Sport Pkg, Digital Dual Zone Climate Control, Panorama roof, Air Guide Windstop, Chrome Bonnet Fins, smartTOP roof module v1.42, Akebono ceramic front brake pads, TRW ceramic rear brake pads, DIY Backup Camera
Other Ride: 2016 GLA 250 4Matic, Cirrus White, Ash, Premium Pkg, Multimedia Pkg, Panorama Sunroof, Bi-Xenon Headlamps, Blind Spot Assist
WhiteRabbit is offline
The Following User Says Thank You to WhiteRabbit For This Useful Post:
#16 Old 03-11-2017
Saska's Avatar
Tks I had posted earlier today that I found that lever to operate all windows. As you say it wasn't on the SLKs so it's new to me. Cheers and many thanks.
Saska is offline
#17 Old 03-11-2017
Quoted: 82 Post(s)
[quote=Avel Du;3440145]
As for the wind up?
Nice try.
I wasn't shaking your chain , I served my time in the stock car world , I spent many years on the ovals , albeit only turning left
I've got no ego but do enjoy a laugh .
#18 Old 03-12-2017
Vehicle: 2017 AMG SLC 43 - Brilliant Blue
On the SLC with the top down, closing the window switches closes the door windows and leaves the quarter windows down. Closing with the the switches again and holding them close the quarter windows. With the roof up and the windows closed, first hit lowers door windows, second lowers quarter windows.
Hope this helps.
Avel Du and DaveR. like this.
trptman is offline
The Following User Says Thank You to trptman For This Useful Post:
#19 Old 07-22-2017
Vehicle: 2017 SLC 200 Sport,Manual,Petrol
Other Toys: Bicycle
Hi,This being my first reply on this forum,on any forumcome to think of it.Yes I'm technologically challenged!I have a "diamond silver"metallic 200 Sport,manual,petrol.I picked it up on March the 2nd.from Cheshire Oaks with a couple of toys a Garmin Map Pilot and reversing camera.Last month I had the black fabric standard seats re upholstered in red/black leather.Very flash it looks too.
As to your issue with the mini windows I have also had the warning light on the dash,maybe six times in the 1500 miles that I have done.The car is going in to MB for a free health check next month I will mention the issue then.I am off to Portsmouth/Santander/Spain and Portugal September so the health check is a great scheme.
I have a strange issue with my engine oil dipstick,removal of the dipstick reveals oil well over the maximum,as per instructions I wipe the dipstick and insert,turning slowly for four seconds.Here's the drama removal of the dipstick shows oil above maximum,then a dry no oil section and lower down oil up to halfway.In effect oil,no oil then oil.Any ideas.Of course I have periodically checked the level,the bonnet lever is the most used part of my car!There doesn't seem to be an electronic oil level warning system fitted as there was on my previous MB.Apart from minor design flaws this is a very nice car.
If Diamond Silver is silver then Man.Utd's home shirts are purple?.
Why fit a glass sunroof with a solid roof liner?(yes I know that other types of roof are extras)
Why fit a chrome(plastic?)fin to the side wing louvre leaving the "cheese grater"bonnet louvre fins as an optional extra?
SLCSPORT is offline
#20 Old 10-13-2017
Vehicle: SLC 180 AMG line
Hi everyone,
I think MB must be aware of the side windows issue.
I have a SLC180 and had the message a few times.
Anyone already been at the MB dealer? What do they say about it?
Herman
Bubblegum is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > SLC General Discussion
How To Raise Rear Windows and Lock Trunk/Boot After Manual Top Operation: Guide LoveMeSomeSLK SLK R170 class DIY 0 08-07-2016 02:30 AM
Keeping rear side windows or quarter windows down with roof up OutEast SLK R170 General Discussion 21 07-23-2016 11:21 PM
