What wheels fit my SLC 300? - Mercedes Benz SLK Forum
SLC General Discussion SLC 180,200,300,250d,43 AMG
#1 Old 10-29-2016
Founding member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 25 Post(s)
I was looking for a "winter wheel" for my SLC. I usually buy from TireRack, but they don't have the SLC listed yet. And I talked to a parts guy at the dealership and he says he doesn't know either and just orders by a part number so wouldn't know what wheels would fit.
I was looking at:
Sport Edition
SE-17
FRONT AND REAR:
Size: 17x7.5 (O.E. Diameter)
Finish: Silver Painted
Weight: 21.0 lbs.
Offset: +35mm
Backspacing:5.59"
Bolt Pattern:5-112
Rec. Tire Size:225/45-17
Will that work?
I guess I should double check the tires with you guys too.
Bridgestone
Blizzak WS80
Studless Ice & Snow
I was going to have same size front and back. That is what I did with the SLK 350 as TireRack recommended not offsetting the wheels and using the same size front and rear so that I wouldn't be making wider tracks through the snow.
mtiede is offline
#2 Old 11-16-2016
Founding member #7
mtiede's Avatar
Quoted: 25 Post(s)
Wow, it has been a while and no one has any suggestions or information?
mtiede is offline
#3 Old 11-16-2016
Quoted: 2214 Post(s)
It probably disappeared from view.
There are definitely folk on here with the answers, just not many.
The comment about not having an offset I have read before and makes sense.
Have you thought of asking MBUSA what they recommend?
That would give you the sizes they think work and you could just source similar.
Considering you want a winter wheel I wouldn't focus on look over function too much.
Avel Du is online now
#4 Old 11-16-2016
Vehicle: 2006 SLK 280 Black
Other Toys: None
Quoted: 101 Post(s)
I think it's a pretty good bet that your SLC takes the same size wheels and tires that the previous few years' type 172 did. TireRack.com has a recommended winter tire/rim package for the 2012 SLK. They're 16x7" wheels all the way around with a taller section on the tires (215/55H16). They also allow you to pick and match if you prefer 17" or 18".
Your owners manual should also have a listing for "same size" wheels/tires to use (with wheel offset listed), if you want more specific particulars. (The type 171 manual for the 2006 cars does, anyway...)
G
Godfrey is offline
#5 Old 11-16-2016
Quoted: 533 Post(s)
What Godfrey says. Here you''ll find the official list of MB http://www.mercedes-benz.de/content/...172_160629.pdf
No difference between SLK/SLC R172.
Oh amd for the AMG's here http://www.mercedes-benz.de/content/...017_161005.pdf
Sneaky Pete is online now
#6 Old 11-16-2016
#FullDragon's Avatar
Vehicle: R171 2006 SLK 200 kompressor
Quoted: 89 Post(s)
Check THIS site mate, you can choose what you like and it will tells you everything about the wheel and tire sizes.
#FullDragon is offline
#7 Old 11-17-2016
Vehicle: Audi TTRS MY2017
Other Toys: Whyte Prst-1, MY2017 Audi A6 allroad Competition, 1/50th Twin Squirrel, 2006 Fabia vRS Hybrid
Quoted: 619 Post(s)
If you want to be 100% that they'll fit then 18 x 7.5J ET42 CB 66.6mm
I know they fit for a fact because that's what I have in mine with 225/40/R18 Michelin Latitude Alpin tyres. Mercedes winter wheel set is basically 4 of what you have on the front wheels.
I have to be honest, I can't see a 16" wheel fitting. The 18" wheels have only tiny clearance with the front brakes. 17" might go on, but I can't see how 16" will fit.
wja96 is offline
#8 Old 11-25-2016
Founding member #7
mtiede's Avatar
Quoted: 25 Post(s)
Got the new wheels and tires where I assumed 2016 SLK and 2017 SLC would be the same. They seem to fit well.
When I was putting the first one on, I jacked up the car and spun the left front wheel to make sure it was off the ground. When I did that, I noticed a piece of plastic hitting the wheel. There was a 3" by 5" or so plastic panel hanging down from the wheel well and hung on by a thin plastic thread. Turns out it is the panel that is behind the headlights. When I picked up the SLC, the left front radar sensor was loose in its hole on the bumper. I suspect the shop took the wheel off (because it was on tight as hell) and then reached the radar sensor through that hole. Then they didn't put it back right. You have to have the bottom in and push the top part in the opening and then slide it down. I suspect they didn't slide it down sufficiently.
mtiede is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > SLC General Discussion
Tires for 8.5" wide wheels (front) conleyjb Tires, Wheels, Brakes & Suspension 21 03-09-2019 12:07 AM
R171 With Upgraded Brakes - What Wheels Will Fit? grantwils Tires, Wheels, Brakes & Suspension 9 10-01-2013 07:05 AM
Will CLK 209 wheels fit on SLK? TJer Tires, Wheels, Brakes & Suspension 7 10-20-2009 01:09 PM
18" AMG five star wheels from C350 fit SLK? casper SLK R171 General Discussion 5 06-15-2009 06:20 AM
Do SLK32 AMG wheels fit on a SLK 350? tai230k SLK R171 General Discussion 1 01-21-2007 05:32 PM
